19 Replies Latest reply on May 29, 2013 3:27 PM by A.T. Romano
    Elements 11 will not playback video
    wadeleverett3
      just installed elements 11 and have added an mpeg4 file.  all appears good but can not playback the video.  only a white screen where the video should play.  if i double click the clip the edit window  behaves the same.  How do I get the video to play?  no error messages are displayed.  and the audio plays normally.
        • 1. Re: Elements 11 will not playback video
          A.T. Romano Level 7
          wadeleverett3
          What computer operating system are you running Premiere Elements 11 on (including 32 or 64 bit)?
          Is your video card driver up to date?
          What are the properties of your .mp4 file? If you do not know, please get a MediaInfo properties readout
          http://mediainfo.sourceforge.net/en
          We are looking for:
          VIdeo compression (that .mp4 is just a wrapper format not the video compression)
          Audio compression
          Frame Size
          Frame Rate, including interlaced or progress; if interlaced, upper or lower field first
          Pixel Aspect Ratio
          Duration
          for starters
          Does the file playback OK in your computer players?
          Do you have similar problems with other video of its kind or other kinds? Is the problem specific to this one video?
          The answers to the above will prove helpful to finding the reason for the problem.
          What you might want to try is renaming the file extension to: mts, .m2t, .m2ts, .avi, or .mov to see if the renamed file imports into Premiere Elements 11 and displays its video.
          Thanks.
          ATR
          • 2. Re: Elements 11 will not playback video
            the_wine_snob Level 9
            Welcome to the forum.
            The answers to ATR's questions will be very important. Please pay close attention to the question about your video driver - the more detail that you can provide, the better.
            I have one more: do you have the latest version of Apple's QuickTime Player installed?
            • 3. Re: Elements 11 will not playback video
              wadeleverett3 Level 1
              Answers are interspersed below:
              Sent: Tuesday, May 28, 2013 2:30 PM
              To: wadeleverett3
              Subject: Elements 11 will not playback video
              created by A.T. Romano <http://forums.adobe.com/people/A.T.+Romano> in
              *Premiere
              Elements* - View the full
              discussion<http://forums.adobe.com/message/5359199#5359199
              • 4. Re: Elements 11 will not playback video
                Unfortunately, the answers did not attach. You might have to use Copy/Paste into the Reply window, instead of the method that you used.
                If you are accessing the forum via a phone, or email, you might need to access via a computer and a browser.
                • 5. Re: Elements 11 will not playback video
                  (including 32 or 64 bit)? Windows 7 64 bit I7 q720 @1.60Ghz with 8Gigs of
                  memory.
                  Video is Nvidia Quadro FX 880M
                  We are looking for:
                  General
                  Complete name                            : F:\2013_5_20_8_26_15.mpg
                  Format                                   : MPEG-PS
                  File size                                : 2.32 GiB
                  Duration                                 : 1h 2mn
                  Overall bit rate mode                    : Variable
                  Overall bit rate                         : 5 309 Kbps
                  Writing library                          : ArcSoft MPEG-2 NTSC
                  Video
                  Format                                   : MPEG Video
                  Format version                           : Version 2
                  Format profile                           : Main@Main
                  Format settings, BVOP                    : Yes
                  Format settings, Matrix                  : Custom
                  Format settings, GOP                     : M=3, N=13
                  Duration                                 : 1h 2mn
                  Bit rate mode                            : Variable
                  Bit rate                                 : 4 980 Kbps
                  Maximum bit rate                         : 7 500 Kbps
                  Width                                    : 720 pixels
                  Height                                   : 480 pixels
                  Display aspect ratio                     : 4:3
                  Frame rate                               : 29.970 fps
                  Standard                                 : NTSC
                  Color space                              : YUV
                  Chroma subsampling                       : 4:2:0
                  Bit depth                                : 8 bits
                  Scan type                                : Interlaced
                  Scan order                               : Top Field First
                  Compression mode                         : Lossy
                  Bits/(Pixel*Frame)                       : 0.481
                  Time code of first frame                 : 00:00:00:00
                  Time code source                         : Group of pictures header
                  Stream size                              : 2.18 GiB (94%)
                  Color primaries                          : BT.470 System M
                  Transfer characteristics                 : BT.470 System M
                  Matrix coefficients                      : BT.601
                  Audio
                  Format                                   : MPEG Audio
                  Format version                           : Version 1
                  Format profile                           : Layer 2
                  Duration                                 : 1h 2mn
                  Bit rate mode                            : Constant
                  Bit rate                                 : 224 Kbps
                  Channel(s)                               : 2 channels
                  Sampling rate                            : 48.0 KHz
                  Delay relative to video                  : 147ms
                  Stream size                              : 100 MiB (4%)
                  compression)
                  Audio compression
                  Frame Size
                  field first
                  Pixel Aspect Ratio
                  Duration
                  for starters
                  Does the file playback OK in your computer players? Yes
                  kinds?noIs the problem specific to this one video?
                  no
                  problem.
                  Elements 11 and displays its video.  The video imports to elements fine
                  with no errors and renders fine with no errors.  In the playback window it
                  shows the video when paused.  When I move the time line cursor the video
                  window reacts as you would expect by showing the frames as you move past
                  them.  The issue is when you click play under the playback window, it turns
                  white and you hear the audio with no video.
                  Sent: Tuesday, May 28, 2013 2:38 PM
                  To: wadeleverett3
                  created by Bill Hunt <http://forums.adobe.com/people/the_wine_snob> in
                  *Premiere
                  discussion<http://forums.adobe.com/message/5359167#5359167
                  • 6. Re: Elements 11 will not playback video
                    A.T. Romano Level 7
                    wadeleverett3
                    Have we established that you have the latest version of QuickTime installed on your computer? If not, please do so and download and install QuickTime latest version for your computer.
                    http://www.apple.com/quicktime/download/
                    About your video card
                    NVIDIA QUADRO FX 880M
                    is that in a Dell Computer with your Windows 7 64 bit operating system and Premiere Elements 11 installed?
                    If you go to Device Manager/Display Adapters/ with final destination the Driver Tab for your video card properties, what is the version and date for the video card driver that you currently have installed?
                    Have you gone to the web site for NVIDIA or your computer manufacturer to verify that your video card driver is up to date?
                    Thanks for the follow ups.
                    ATR
                    • 7. Re: Elements 11 will not playback video
                      I have not checked the version of quick time will do so.
                      Regarding your other questions:
                      It is a Lenovo ThinkPad W510.  It does have the latest Nvidia Drivers as of
                      yesterday.  The version is : 9.18.13.1100 dated 1/10/2013
                      Yes, the video card is reported as up todate using the web site tool.
                      Wade
                      Sent: Wednesday, May 29, 2013 12:06 PM
                      To: wadeleverett3
                      *Premiere
                      discussion<http://forums.adobe.com/message/5362231#5362231
                      • 8. Re: Elements 11 will not playback video
                        A.T. Romano Level 7
                        Wade,
                        That seems to sound like good news with regard to the video card driver updating.Thanks.
                        Let us see if the QuickTime install which is a must helps us any.
                        But, I have something else for you to look at also.
                        From what I read in your posts here, you are dealing with a MPEG2.mp4 video file. If I am correct on that....Wherever you have the file saved on the hard drive, go there and rename the file extension of the file only. Then import the variations into Premiere Elements to determine if one of them will import without issue
                        MPEG2.mpg
                        MPEG2.avi
                        MPEG2.mov
                        We will continue to watch for your results.
                        Thanks.
                        ATR
                        • 9. Re: Elements 11 will not playback video
                          I have now updated to the latest quicktime drivers.  No Change.
                          I notice when I startup elements 11 and load a project that the play back
                          window is white.  If I click It, it will show the video currently under the
                          cursor.  Then if I move the cursor back and forth the images will change.
                          But it still will not play.
                          wade
                          To: wadeleverett3
                          *Premiere
                          • 10. Re: Elements 11 will not playback video
                            A.T. Romano Level 7
                            wadeleverett3
                            Thanks for checking for the latest version of the QuickTime software.
                            Did you get a chance to look at renaming just the file extension of the source video?
                            In my previous post, I had asked you to try renaming just the file extension of your video (believed to be MPEG2.mp4) to see if that .mp4 wrapper format made a difference in the results. I have been thinking that you have MPEG2.mp4 because of your opening post where you ask about the addition of your MPEG 4 file.
                            I just went back to review your whole thread and noticed that your MediaInfo properties readout shows a video file with a .mpg not .mpeg4 file extention. Based on the MediaInfo properties reading, you appear to be dealing with a MPEG2.mpg file not a MPEG2.mp4 file. Could you say what brand and model camera your problem file is coming from so we can check that out further?
                            Thanks.
                            ATR
                            • 11. Re: Elements 11 will not playback video
                              Yes, I did say mpeg4 because I have tried a coup of different capture
                              programs to bring this data in.  so far they all have the same result.
                              Currently I am using ArSoft ShowBiz to capture the a live feed from a 8mm
                              camera and specifying MPEG.  The video/audio out of the camera as it plays
                              is being captured by a USB-Live 2 made by Hauppauge.  The captured video
                              file plays well on windows media player.
                              I just reloaded the video file into ArcSoft and it still plays there.
                              When I load the .mpeg file into elements 11 it shows only one video slide
                              on the time line.  In earlier versions I remember seeing the frames shown
                              all across the time line.  Not sure it is related to the issue here.
                              wade
                              Sent: Wednesday, May 29, 2013 1:37 PM
                              To: wadeleverett3
                              *Premiere
                              discussion<http://forums.adobe.com/message/5362533#5362533
                              • 12. Re: Elements 11 will not playback video
                                A.T. Romano Level 7
                                wadeleverett3
                                I believe I can explain what you are seeing in the Timeline content.
                                The video tracks and audio tracks come with a choise of Track Style types.
                                Look to the left of where it says, for example, Video 1. You should see a filmstrip looking icon. You can toggle that to get 4 different styles of a video track:
                                1. just a vertical line running across the video portion of the clip
                                2. one thumbnail with image only at the beginning of the video clip
                                3. one thumbnail with image at the beginning of the video clip with only one other at the end of the video clip
                                4. thumbnails each with an image across the whole video clip
                                For the audio clip display style, my recollection is that there are 2 styles
                                1. With waveform
                                2. just a vertical line running across the audio portion
                                The case of the audio, the icon to the left of, for example, Audio 1 should look like a speaker.
                                I will think about your recent details some more.
                                Thanks.
                                ATR
                                • 13. Re: Elements 11 will not playback video
                                  Thanks for the input.
                                  I looked in the elements 11 movie themes\slideshow folder and saw there
                                  were many mpg files.  I tried dropping various ones onto the time line and
                                  play them.  I see the same result.  So I think that the problem is in the
                                  playback of Elements or the video system on the Lenovo thinkpad laptop.  It
                                  appears to be with elements because windows media player can play all files.
                                  Wade
                                  Sent: Wednesday, May 29, 2013 3:22 PM
                                  To: wadeleverett3
                                  *Premiere
                                  discussion<http://forums.adobe.com/message/5362880#5362880
                                  • 14. Re: Elements 11 will not playback video
                                    Wade,
                                    There are some major differences between simple playback (say with VLC player), and then playback of a Clip on the Timeline, ready for editing.
                                    While testing a file with simple playback is a good first step, one should not develop a false sense of security. That is but a first step in testing.
                                    I will read back up the thread, looking to see exactly what your video card/chip is, and also what the number and date of its video driver are. If you have not posted those data, please do so.
                                    [Edit] OK, I see that you have:
                                    But, I did not see the number and date of the video driver. Have you posted that, and maybe I missed it?
                                    • 15. Re: Elements 11 will not playback video
                                      Thanks Bill, not making any major assertions just saying that a clip that
                                      comes with your product shows the same symptoms.  Also that the same clip
                                      works in windows media player.
                                      Thanks for your help
                                      Wade
                                      Sent: Wednesday, May 29, 2013 3:32 PM
                                      To: wadeleverett3
                                      *Premiere
                                      discussion<http://forums.adobe.com/message/5362943#5362943
                                      • 16. Re: Elements 11 will not playback video
                                        Wade,
                                        To make sure that there is no confusion, none of us works for Adobe. We are just users, trying to help other users.
                                        Since most of us do not have the playback issues, that you are experiencing, we are trying to find out what is different between our successful playback of similar material, on our computers.
                                        As the "white screen" is a classic manifestation of a bad or obsolete video driver, I wanted to find out if that was the problem in your case.
                                        Some programs, like Premiere, the latest Photoshop, After Effects, 3D rendering applications and CAD programs, must interface much more closely with the video driver, than almost any other program that one is likely to have, with the exception of the newest extreme games. Even simple players do not rely so heavily on the video driver.
                                        The nVidia Quadro can have drivers supplied from two sources: directly from nVidia, or in some cases, in a specially re-wrapped version from the computer mfgr., such as Dell, HP, Lenovo, Toshiba, and a few more. Those first three usually do a great job of taking the latest nVidia driver, and then re-wrapping it for their specific version of the nVidia chips and their specific version of the OS.
                                        If you driver is more than a few months old, and especially if you have updated your OS, it is likely that it is obsolete, and if so, perhaps the latest version will fix that white screen.
                                        That is the reason for my question about the video driver.
                                        • 17. Re: Elements 11 will not playback video
                                          Thanks Bill, appreciate your help.
                                          I do have the most recent drivers installed.  I also went to the device
                                          manager and clicked update driver and it says I am at the latest release.
                                          The driver is dated 1/10/2013.
                                          Is there any way to get support from Adobe?  Seems like I have tried all
                                          the common ideas.
                                          wade
                                          Sent: Wednesday, May 29, 2013 4:00 PM
                                          To: wadeleverett3
                                          *Premiere
                                          discussion<http://forums.adobe.com/message/5363026#5363026
                                          • 18. Re: Elements 11 will not playback video
                                            Unfortunately, the OS will almost always be at least 6 mos. out of date.
                                            You might check out this page on the nVidia Web site: http://www.nvidia.com/object/quadro-notebook-win8-win7-64bit-320.00-whql-driver.html
                                            It shows a new driver for the Quadro FX880M w/ Win7-64 from 05/03/2013.
                                            As you have a Lenovo, if you have any trouble installing that nVidia driver, I would check on their Web site.
                                            As there is much more control over nVidia chips in the Quadro line, it would be logical that Lenovo would not re-wrap the nVidia drivers, and that nVidia would have the latest.
                                            • 19. Re: Elements 11 will not playback video
                                              A.T. Romano Level 7
                                              wadeleverett3
                                              I would offer to look first hand at one of your problem video clips. However, when I tried to do a one on one comparison with your testing that I quoted above, I could not confirm your result.
                                              What I did was to copy the "weddingdoves_prv.mpg" file to the computer desktop from the Movie Themes program files area and import it into Premiere Elements 11. It played back fine using my Premiere Elements 11 on Windows 7 and 8 64 bit. There were about two flashes of white in the run of the clip in the Premiere Elements 11 monitor, but those appeared to be related dip to white transitions between the scenes involved.
                                              The video card and its driver angle to this seems the obvious way to go although we might be surprised to find it is not.
                                              You might want to get Adobe as well as Lenovo involved in this. Adobe first, especially if you are within a month of purchase.
                                              Let me ask you this. At the present time, putting aside .mpg and .mp4, is there any video format that you can import into Premiere Elements and get an acceptable display of itsTimeline content in the Edit Mode Monitor?
                                              Let us know if you think we can help further.
                                              Thanks.
                                              ATR
