6 Replies Latest reply on Nov 14, 2013 12:10 PM by SueBachanDobe
    Problems installing CF 10 with Apache 2.2.24 (or 2.4) on RHEL 6.4
    SueBachanDobe
      Built Apache using openssl 1.0.1e (updated LD_LIBRARY_PATH to reflect the correct openssl libs) and pcre. Configure for build was:
      configure --enable-ssl=shared --with-ssl=/usr/local/ssl  --enable-so --with-included-apr --with-pcre  --with-perl
      Also downloaded and built the connector from http://helpx.adobe.com/coldfusion/kb/rhel-connector-configuration.html after the vanilla CF install didn't work. I get the following when I try to start up CF:
      [root@web01 logs]# /etc/rc.d/init.d/coldfusion_10 start
      Starting ColdFusion 10 server instance named cfusion ...
      The ColdFusion 10 server instance named cfusion is starting up and will be available shortly.
      nohup: appending output to `nohup.out'
      Running the ColdFusion 10 connector wizard
      Configuring the web server connector (Launched on the first run of the ColdFusion 10 start script)
      Running /usr/local/apache2/conf connector wizard...
      There was an error while running the connector wizard
      Connector installation was not successful
      ColdFusion 10 server instance named cfusion has been started.
      ColdFusion 10 will write logs to /opt/coldfusion10/cfusion/logs/coldfusion-out.log
      The wsconfig.log contains the following:
      [root@web01 wsconfig]# cat wsconfig.log
      # Created by ColdFusion on 05/28 15:15:23
      05/28 15:15:23 info Tomcat Connector
      05/28 15:15:23 debug command line: -ws Apache -bin /usr/local/apache2/bin/httpd -script /usr/local/apache2/bin/apachectl -dir /usr/local/apache2/conf -v
      05/28 15:15:23 info Red Hat Enterprise Linux Server release 6.4 (Santiago)
      05/28 15:15:23 debug Using Apache binary /usr/local/apache2/bin/httpd
      05/28 15:15:23 info Server's Module Magic Number: 20051115:31.  Supported major magic numbers on this platform are 20020628 and 20020903.
      05/28 15:15:23 info Attempting to build connector from sources
      05/28 15:15:23 info Server version: Apache/2.2.24 (Unix)
      05/28 15:15:23 debug Using Apache control script /usr/local/apache2/bin/apachectl
      05/28 15:15:23 debug Parsing Apache configuration file /usr/local/apache2/conf/httpd.conf
      05/28 15:15:23 debug Exec'ing chmod 777 /opt/coldfusion10/config/wsconfig/1
      05/28 15:15:23 debug Set permission to 777 on /opt/coldfusion10/config/wsconfig/1
      05/28 15:15:23 debug Exec'ing chmod +x /opt/coldfusion10/config/wsconfig/1/mod_jk.so
      05/28 15:15:23 debug Set permission to execute on /opt/coldfusion10/config/wsconfig/1/mod_jk.so
      05/28 15:15:23 debug Created file /opt/coldfusion10/config/wsconfig/1/mod_jk.so
      05/28 15:15:23 debug Wrote file /usr/local/apache2/conf/httpd.conf
      05/28 15:15:23 debug Added ColdFusion configuration to Apache configuration file /usr/local/apache2/conf/httpd.conf
      05/28 15:15:23 debug Created file /opt/coldfusion10/config/wsconfig/1/README.txt
      05/28 15:15:23 debug Wrote file /opt/coldfusion10/config/wsconfig/wsconfig.properties
      05/28 15:15:23 debug Exec'ing /usr/local/apache2/bin/apachectl restart
      05/28 15:15:23 error Error running "/usr/local/apache2/bin/apachectl restart": exit code was 1
      05/28 15:15:23 error Error restarting Apache server.  The web server must be restarted to complete this operation.
      com.adobe.coldfusion.connector.connectorinstaller.WebServerException: Error restarting Apache server.  The web server must be restarted to complete this operation.
          at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.restartWS(ApacheInstall er.java:480)
          at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.installConnector(Apache Installer.java:269)
          at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.installConnector(Con nectorInstaller.java:340)
          at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.doIt(ConnectorInstal ler.java:284)
          at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.main(ConnectorInstal ler.java:741)
      05/28 15:16:37 info Tomcat Connector
      05/28 15:16:37 debug command line: -ws Apache -dir /usr/local/apache2/conf -bin /usr/local/apache2/bin/httpd -script /usr/local/apache2/bin/apachectl -cfide /opt/coldfusion10/cfusion/wwwroot/CFIDE -v
      05/28 15:16:37 error This web server is already configured for ColdFusion.
      com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstallerException: This web server is already configured for ColdFusion.
          at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.installConnector(Apache Installer.java:187)
      I've searched and tried just about everything I could find relating to the error info.
