3 Replies Latest reply on May 30, 2013 2:02 AM by sivacse24rep
    ArgumentError: Error #2173:(how to get values from java object)
    sivacse24rep Level 1
      I am very much new to flex. I want to do flex work in Adobe flash as 3.0. On a flex sample file i saw they use
      [RemoteClass(alias="com.aaa..bbb")]  meta tag... and socket amf3 connection to send values from flex to java.
      for the above flex code i found the equalent code on adobe flash as3 registerClassAlias(""com.aaa..bbbt",bbb);
      i send same socket am3 connection its sucess and i got result from server too....
      when i try to read the response object it shows error
      function onSocketDataa(ev:ProgressEvent):void
           var o:Object;
           o          = sock.readObject();
           for(var i in obj)
                trace(i,"-->",obj[i])
      ArgumentError: Error #2173: Unable to read object in stream.  The class flex.messaging.io.ArrayCollection does not implement flash.utils.IExternalizable but is aliased to an externalizable class.
                at flash.net::Socket/readObject()
                at socket_sample_fla::MainTimeline/onSocketDataa()
      received
      RangeError: Error #2006: The supplied index is out of bounds.
      I am not able to understand what kind of communication happen between client and server. I want to receive the objects from the server. How to do that on Adobe flash as3?
      Siva
