1 Reply Latest reply on May 29, 2013 8:10 AM by Josh_Corey
    Using PDF expert on the iPad with FormsCentral
    AlexanderLexiJones Level 1
      I would like to have an evaluation form (created using Forms Central) to be completed on the iPad using PDF Expert.  I can open the form, complete it and when submit it it says 'Completed' - but nothing shows up in the responses panel.
      Is this possible?
        • 1. Re: Using PDF expert on the iPad with FormsCentral
          Josh_Corey Adobe Employee
          Hi;
          FormsCentral PDF forms have to be filled out using Adobe Reader or Adobe Acrobat, on the iPad using Adobe Reader you can submit our PDF forms.  I will have to check out what happens with PDF Expert, it should not tell you it completed successfully, but I can say that we do not expect any other PDF viewer applications to be able to submit our forms, only from Adobe Reader/Acrobat.
          Josh
