3 Replies Latest reply on May 30, 2013 1:24 PM by ChiakiUSA
    InDesign & RR Bowker
    ceilr Level 1
      Hi everyone,
      RR Bowker is the company that brings us ISBN numbers.  I updated my numbers just today, because of the new book I'm producing in InDesign.
      What puzzles me is that Bowker wants a .jpg of the front cover, which I've created in a separate InDesign doc.  It would be so much easier to upload a .pdf!  So I thought I'd ask here if there might be a way to save the front cover in a .jpg format, other than getting out the camera or scanning a hard copy?
      Thanks!
        • 1. Re: InDesign & RR Bowker
          Les ONeill Level 2
          Use 'File/Export' and Jpeg exists as one of the various format options.
          Les
          • 2. Re: InDesign & RR Bowker
            Michael Gianino Level 4
            You can also open a PDF in Photoshop and save it as a jpeg, which may allow you to control different aspects of the transformation.
            • 3. Re: InDesign & RR Bowker
              ChiakiUSA
              Adobe's help:
              JPEG uses a standardized image compression mechanism to compress full-color or grayscale images for onscreen display. Use the Export command to export a page, spread, or selected object in JPEG format.
                    If desired, select an object to export. (You do not need to select anything to export a page or spread.)
                Choose File > Export.
                Specify a location and a filename.
                  For Save As Type (Windows) or Format (Mac OS), choose JPEG, and click Save.
              The Export JPEG dialog box appears.
                In the Export section, do one of the following:
              Selection
              Export the currently selected object.
              Range
              Enter the number of the page or pages you want to export. Separate numbers in a range by using a hyphen, and separate multiple pages or ranges by using commas.
              Select All
              Export all pages in the documents.
              Spreads
              Export facing pages in a spread to a single JPEG file. Deselect this option to export each page in a spread as a separate JPEG file.
                For Quality, choose from a range of options that determine the trade-off between file compression (smaller file size) and image quality:
              Maximum includes all available high-resolution image data in the exported file and requires the most disk space. Choose this option if the file will be printed on a high‑resolution output device.
              •   Low includes only screen-resolution versions (72 dpi) of placed bitmap images in the exported file. Choose this option if the file will be displayed onscreen only.
              •   Medium and High include more image data than Low, but use varying levels of compression to reduce file size.
                For Format Method, choose one of the following options:
              Progressive displays a JPEG image in increasing detail as it is downloaded to a web browser.
              •   Baseline displays a JPEG image after it has been downloaded completely.
                Select or type the resolution for the exported JPEG image.
                Specify the color space of the exported file. You can choose to export as RGB, CMYK, or Gray.
                Select any of the following items, and then click Export.
              Embed Color Profile
              When this option is selected, the document’s color profile is embedded in the exported JPEG file. The name of the color profile is displayed in small text to the right of the option. You can select the desired profile for the document by choosing Edit > Assign Profiles before exporting to JPEG.
              If Gray is chosen from the Color Space menu, the Embed Color Profile option is disabled.
              Use Document Bleed Settings
              If this option is selected, the bleed area specified in Document Setup appears in the resulting JPEG. This option is disabled if the Selection option is chosen.
              Anti-Alias
              Anti-aliasing smooths the jagged edges of text and bitmap images.
              Simulate Overprint
              This option is similar to the Overprint Preview feature but works for any of the selected color spaces. If selected, the JPEG file that InDesign exports simulates the effects of overprinting spot inks with different neutral density values by converting spot colors to process colors for printing.
