2 Replies Latest reply on May 29, 2013 11:32 PM by M V SHAJI
    Indesign XML-IN workflow - Anchoring issues
    M V SHAJI Level 1
      Hi all,
      We are using Indesign CS5.5 and CS6.
      For XML-IN workflow, we have developed a in-house tool for automation.
      Marginal Notes: Using Script we drag the content from the XML tree and anchor it in Margin as per layout.
      The issue here: In Pagination if they release the anchor the marginal content become Non-XML and wiped out from the XML tree.
      Is there is any work-around to handle these types of issues.
      Please advice.
      Shaji
        • 1. Re: Indesign XML-IN workflow - Anchoring issues
          Vamitul Level 4
          Hello Shaji.
          As far as i know there is no solution for this. I'we been struggling with it for a while now. The only "workaround" i found was to use copy-paste instead of releasing the anchor:
          Select the anchored frame, copy it, paste it in place, then remove the old anchor. It should create a new Story element in the XML tree.
          It's not hard to script, if all you need is to release all anchors from the document/story, for example
          • 2. Re: Indesign XML-IN workflow - Anchoring issues
            M V SHAJI Level 1
            Hellow Vamitul,
            Thanks for the response.
            I also tried searching for the answer but did't suceed.
            Since we are having complex jobs in XML-IN workflow. This is hard to have such a issue like this.
            Hope Indesign will fix in near future.
            Shaji
