1 Reply Latest reply on Jun 2, 2013 7:19 PM by Sham HC
    Problems with cURL: 500 internal error
      Hi all
      As there is no chance of getting daycare support  to take this request seriously I have taken to the forums; here is my issue I dont expect a resolution but would love if you could point out areas that are involved in this process or easy mistakes to make, here goes:
      What i am trying to achieve:
      to setup a script that will build and package and download it to the local server from the local server
      server details:
      aws ec2 instance
      red hat os
      plenty of system resource
      I have created an empty package with the filters: /content/mobile
      This is the command I am running:
      curl -u admin:pass -X POST http://servername:4502/crx/packmgr/service/.json/etc/packages/backup-test.zip?cmd=build
      servernames I have tried (I would prefer to use localhost):
      server author url (this utilises rewrites and may be problematic)
      server ip
      This is the output of the command:
      Internal Server Error
      This is also logged in /CQ5UATStorageBlock/adobe/cq/author/crx-quickstart/logs/crx/error.log:
      29.05.2013 13:24:22 *WARN * CRXSessionCache: Unable to retrieve session: javax.jcr.LoginException (CRXSessionCache.java, line 98)
      However, when running these from an external source i.e my laptop:
      curl -u admin:pass -X POST http://server ip:4502/crx/packmgr/service/.json/etc/packages/my_packages/backup-test.zip?cmd=build
      curl -u admin:pass -X POST http://serverurl:4502/crx/packmgr/service/.json/etc/packages/my_packages/backup-test.zip?cmd=build
      curl -u admin:pass -X POST http://serverurl/crx/packmgr/service/.json/etc/packages/my_packages/backup-test.zip?cmd=build
      The response is:
      {“success”:true,”msg”:”Package built”}
      Please let me know your ideas I hope this is enough details to get the ball rolling.
      look forward to hearing from you
        • 1. Re: Problems with cURL: 500 internal error
          Sham HC Level 7
          Hi Sam,
          There should be additional errors apart from warning LoginException.  Could you please find the same in <cq_home>/crx-quickstart/logs/crx/error.log and attach the logs.  Command looks right. Is it cluster environment?
          P.S:-  Daycare team will definitely help you & make sure you have set right priority in the ticket.
