3 Replies Latest reply on Oct 25, 2007 1:58 PM by kglad
    Setting variables in the main timeline
    dawndawg
      I am trying to customize a flash component that I purchased. It is a flip-book which some of you may be familiar with. The component works just fine, but I want to use input and output/dynamic text fields. I can't assign the variable names to the instances, because they are created dynamically, so I want to set the Vars and names etc using the main timeline. In English this is what I think I need to do:
      on loading the movieclip called "input1", create an input text field called "input"
      on loading the next movieclip called "output1" create a dynamic text field. in this text field, load variable from text field called "input".
      any assistance would be greatly appreciated, even to get me going in the right direction. Thanks!
        • 1. Re: Setting variables in the main timeline
          Noah_B
          I typically run dynamic text out of text documents using:
          &text= blah blah blah
          &textLoaded=OK
          As far as placing the text in the document, I have only done that once. You can use PHP to grab the dynamic text and force it into the document with the current time and date. I'm sorry I don't have some source code to share with you, but if you look up PHP and Flash at www.flashkit.com, I'm sure something will pop up.
          • 2. Re: Setting variables in the main timeline
            dawndawg Level 1
            I don't want to load text that I've created. I want to load text from the input box. so when someone types an answer into the input, the "output" displays that same text. the reason I can't use the var name in the properties inspector is because the movie clip is loaded from the component, and doesn't actually have an instance name on the stage. So I am looking for a way to set up the variables on the main timeline.
            • 3. Re: Setting variables in the main timeline
              you can use an onChanged method of your textfield (input) and have that assign the text property of input to the text property of output.
