This content has been marked as final.
Show 1 reply
1. Re: Can't edit graph value axis when there are multiple graph types in one chart
alanomaly May 30, 2013 4:44 AM (in response to alanomaly)I've figured it out. Like everything to do with Illustrator's horrible ancient neglected graph tool, it's absurdly clumsy and involves tiptoeing around what is shamefully bad programming for an expensive professional product.
It's all about timing - you have to do things in one rigid counter-intuitive order that appears to not be working then comes together at the end:
- Create the graph but, for now, keep it all the same graph type. If you've already set it to have different graph types, set them to be the same for now.
- Select the whole graph, and in Graph Types main window, set Value Axis to 'Both sides'
- In the drop-down there should be a Left and Right Axis (or top and bottom...). Set Value Axis settings for these now. It'll look like it only works for one axis, because the other axis won't change - bare with it...
- Select the data series you want to use the other axis using Group Selection. Go to Graph Type and set the Value Axis to the other one, and set the graph type to the one you want. It should suddenly all fall into place.
- If you need to edit one of the Value Axis settings, select the whole graph, set the whole graph to one graph type, edit the appropriate value axis by choosing it from the drop down, and the re-apply the graph types as above.
(the bug is - you shouldn't need to set the graph object to have only one graph type in order to access the value axis options for the two seperate value axis)
