1 Reply Latest reply on May 31, 2013 8:03 AM by nkukard
    Using jq waypoints to start animation if using oam file
    nkukard
      ok so is there any suggestions on how i can use jq waypoints to start different animations when i reach certain places on a page if i've embeded the animations using the oam file with dreamweaver?
      in other words does any one know if i can get the js on the main page to interact with the js inside the object
        • 1. Re: Using jq waypoints to start animation if using oam file
          nkukard Level 1
          Well i figured it out me self,
          on the object html page
          function fire(sym,e){
          loadedComps['index-1'].getStage().getSymbol('inde').play(0);
          var loadedComps = {};
                  AdobeEdge.bootstrapCallback(function(compId) {
                      loadedComps[compId] = AdobeEdge.getComposition(compId);
                      // now it is safe to call into the and bind to things like...
                      AdobeEdge.Symbol.bindTimelineAction(compId, "stage", "Default Timeline", "complete", fire(sym, e))
          </script>
          on the page that the object is embeded into
          $('.sectwo').waypoint(function(dir) {
          window[0].fire()
          As far as i can tell
          the object is injected into the window dom by key window[0] window [1] window [2] etc....
          then by changing the bind time line to call a function preregisted
          i can control the objects animation from out side the embeded object
          hope this helps someone
