7 Replies Latest reply on Jun 5, 2013 11:07 AM by Colourjam
    relink images from different locations
    DriveFST
      Hi Forum,
      I have a big tricky thing to do with myself...
      i have placed an image inside indesign document from desktop of my system(smb://172.11.11.0/). Saved and closed. and only the indesign file is sent to other person. (the other person  has the same link in his system).
      Can i be able  to link the image placed inside the document automatically through script,
      searching the missed link name, which is also available in other person system (smb://174.12.22.0/).
      subfolder structures matches in both the system. only the IP address of machines changes...
      eg. placed link location of my system (mac) is:
      smb://172.11.11.0/user/Comics/Images/abc.tif
      placed link location in other system (mac):
      smb://174.12.22.0/user/Comics/Images/abc.tif
      Only the IP address of the system is changing all other subfolders following IP address remains same...
      Any help please....
      @Chand.
        • 1. Re: relink images from different locations
          DriveFST Level 1
          Hi Forum,
          I have also tried with this bit in PC system...
          var myFolder = new File("~E:\script_29th_March\in testing");
          //the location mentioned here is other system image folder location..
          //previous  locations of the placed image is
          var myFolder = new File("C:\Documents and Settings\Chand\Desktop\script_29th_March\in testing")
          var new_path = myFolder+ '/'
          imgs = app.activeDocument.allGraphics
          for (i = 0; i < imgs.length; i++)
          img = imgs[i].itemLink
          myFile = File (new_path + img.name);
          if (myFile.exists) {
          img.relink(File (new_path + img.name))
          img.update()
          so the subfolder \script_29th_March\in testing matches in both the system.
          • 2. Re: relink images from different locations
            dln385
            Try this:
            var linksArr = document.links.everyItem().getElements();
            for (var i = 0; i < linksArr.length; i++) {
                      var link = linksArr[i];
                      link.relink(link.filePath.replace("172.11.11.0", "174.12.22.0"));
                      link.update();
                      if (!link.isValid) {
                                throw new Error("Link " + link + " is not valid.");
                      var linkStatus = link.status;
                      if (linkStatus === LinkStatus.LINK_OUT_OF_DATE) {
                                throw new Error("Link " + link + " is out of date.");
                      if (linkStatus === LinkStatus.LINK_MISSING) {
                                throw new Error("Link " + link + " is missing.");
                      if (linkStatus === LinkStatus.LINK_INACCESSIBLE) {
                                throw new Error("Link " + link + " is inaccessible.");
            • 3. Re: relink images from different locations
              DriveFST Level 1
              thanks dln385,
              I'll give a try in my office mac system tomorrow and let you know..
              another question dln385,
              about the second post of mine (Linking in PC).
              when I give var myFolder = Folder.selectDialog("C:\Documents and Settings\Chand\Desktop.
              the link is asking for path and relinked. but if I directly give the path...
              I dont know Y, it is not relinking...
              any clarifications on this please...
              • 4. Re: relink images from different locations
                dln385 Level 2
                Log out new_path + img.name.
                $.writeln(new_path + img.name);
                Check to see if it logs something different depending on whether or not you use the dialog.
                • 6. Re: relink images from different locations
                  DriveFST Level 1
                  thanks to a great Kasayn.
                  for given a poetic script continued to a page, I really stunned at it..
                  thanks G.....
                  I would be greatfull to you, if I can get the solution for this too..
                  where this script ask for folder/subfolders to select the missed file..
                  WHen i tried using to locate the link file directly, it is not working..
                  As, dln385, said i also used. $.writeln(new_path + img.name);, but still the problem persists.
                  please resolve...
                  (\\ instead of Folder.selectDialog, i'm trying to directly locate the link location)
                  img.update()
                  Many thanks to Kasyan & dln385
                  • 7. Re: relink images from different locations
                    Colourjam Level 1
                    Slightly diffent question here. Does anyone know of a script where from the listed images in links on Indesign, I can resize to 300 ppi(effective),  then re-name images so changing the prefix, then resave them all to a new location specific for the hi res images. Then finally indesign relinks to new named files. That would be a great script if there was one.
                    Also is it possible to be selective on  images, so certain directories (ie Stock images) can be left as is. Ie Not effected by script.
                    I have looked around and havent found anything so specific on Adobe, I am running Cs6 on PC. Which script format would be best?
                    I hope you can help
