0 Replies Latest reply on May 30, 2013 10:01 AM by Silly-V
    Applescript clicking dialog box.
    Silly-V Adobe Community Professional
      Hey yall!
      I have a strange problem on a Mac OS 10.7.5 .  I am basically trying to make a little applescript to select all the stuff in a document and run a big fat Flatten Transparency menu item on it to make it all nice and flat.  However, while clicking menu items with System Events works to bring up the Flatten Transparency dialog box, clicking inside the box does nothing but flicker the intended item briefly with no real result.  For example, click checkbox "Convert All Text to Outlines" flickers the box with a little blue highlight and does nothing. keystroke return ,though, does press OK and dismisses the box.  The concern here of course is being able to manipulate the dialog boxes properly with applescript and for this particular purpose the fact that not all users would have the appropriate settings for their Flatten Transparency options from their previous uses.
      Here is what I have so far:
      tell application "Adobe Illustrator"
          activate
          set user interaction level to interact with all
          repeat with increment from 1 to count of page items of current document
              set thisItem to page item increment of current document
              if thisItem is editable then
                  set selected of thisItem to true
              end if
          end repeat
      end tell
      tell application "System Events"
          tell process "Adobe Illustrator"
              click menu item 13 of menu "Object" of menu bar 1
          end tell
      end tell
              tell window "Flatten Transparency"
                  keystroke return
              end tell
          end tell
      end tell
      Thanks for any advice!
      --Silly
