I have a page that controls our staff directory, including uploading photos of staff members.
I have a form with a browse button, and it successfully uploads the picture. Where it fails is resizing both the photo and the thumbnail.
Here's the code I'm using for the resize:
<cfset source = "D:\Inetpub\staffnet_test\hep\bios\#lcase(filename)#">
<cfset destination = "D:\Inetpub\staffnet_test\hep\bios\thumbs\#lcase(filename)#">
<!--- resize main image --->
<cfimage
action="resize"
height="180"
width="240"
source="#source#"
destination="#source#"
overwrite="yes">
<!--- resize thumb --->
<cfimage
action="resize"
height="90"
width="120"
source="#destination#"
destination="#destination#"
overwrite="yes">
The "source" location is where the fullsize image is first uploaded. The first section of code resizes that pic. The second creates a thumbnail. It fails with the following error:
An exception occured while trying to write the image.
Ensure that the destination directory exists and that Coldfusion has permission to write to the given path or file. cause : java.io.FileNotFoundException: D:\Inetpub\staffnet_test\hep\bios\kevin.adderly.jpg (The system cannot find the file specified)
The error occurred in D:\Inetpub\staffnet_test\hep\admin\hepadmin.cfm: line 100
Line 100 is the first overwrite="yes" line. Any ideas? I'm running CF 8.01
Are you sure the file is successfully reaching the upload folder? Are you sure that the file is being copied to the source folder, if it's different from the upload folder? Do all folders give the user account for CF permissions for write?
^_^
Yep, the file (huge file) successfully uploads to both locations. They're both 2.4MB instead of the 71KB that the older pics are (or 41KB for thumbs). The files are there, but as to whether there are file permissions issues, I have no idea. CF here runs under the system account, so it seems like it should have rights to do just about anything.
File not found is pretty specific. There has to be something preventing CF from "seeing" the files.
^_^
I tried this instead:
<cfset main = ImageNew("D:\Inetpub\staffnet_test\hep\bios\#lcase(filename)#")>
<cfset thumb = ImageNew("D:\Inetpub\staffnet_test\hep\bios\thumbs\#lcase(filename)#")>
<cfset ImageResize(main,"180","")>
<cfset ImageResize(thumb,"90","")>
No error, but no resizing either.
I'm not sure why it wouldn't find the file. It's a Windows machine, so not case sensitive. Let me try to return the path variable names and see what I get. Odd though, because the upload function uses the same variables, and the files upload fine.
Yep, it's got to be a permissions thing, because when I delete the file, I get a completely different error message.
Check to make sure that the CF account also has permissions in IIS (or whatever web server you're utilizing) for those folders.
^_^
