7 Replies Latest reply on Apr 21, 2017 12:15 PM by krishnapreddy_adobe
    .net 4.5 support
    Shad Belcher
      Anyone know if the .net integration will get upgraded to support .net framework 4.5? Tried it out after upgrading to .net 4.5 and get the error "incorrect response header" thrown from com.jnbridge.jnbcore.JNBridgeInternalError.
        • 1. Re: .net 4.5 support
          vadobe11
          Hello, I am from the .NET Framework Compatibility Team. Could you contact us on netfx45compat at microsoft dot com with small project that reproduces this error.
          • 2. Re: .net 4.5 support
            tgorg.com
            I'm having the same/similar problem.  I downgraded to .net 4.0 and the problem went away.
            Here's the error anyways, if it helps.  The assembly it was using was a pretty simple, homegrown dll that talks to MSMQ.
            struct
            Causeundefined
            InnerException
            struct
            Causeundefined
            LocalizedMessageincorrect response header
            StackTrace
            array
            1
            struct
            ClassNamecom.jnbridge.jnbcore.c.b.a
            FileNameundefined
            LineNumber-1
            MethodNamea
            NativeMethodNO
            2
            struct
            ClassNamecom.jnbridge.jnbcore.DotNetSideProxy
            FileNameundefined
            LineNumber-1
            MethodNameint
            NativeMethodNO
            3
            struct
            FileNameundefined
            LineNumber-1
            MethodNameobjectVirtualCall
            NativeMethodNO
            4
            struct
            ClassNameSpiralMsg.SpiralMsg
            FileName[empty string]
            LineNumber-1
            MethodNamemsgToString
            NativeMethodNO
            5
            struct
            ClassNamesun.reflect.NativeMethodAccessorImpl
            FileNameNativeMethodAccessorImpl.java
            LineNumber-2
            MethodNameinvoke0
            NativeMethodYES
            6
            struct
            LineNumber57
            MethodNameinvoke
            NativeMethodNO
            7
            struct
            ClassNamesun.reflect.DelegatingMethodAccessorImpl
            FileNameDelegatingMethodAccessorImpl.java
            LineNumber43
            MethodNameinvoke
            NativeMethodNO
            8
            struct
            ClassNamejava.lang.reflect.Method
            FileNameMethod.java
            LineNumber601
            MethodNameinvoke
            NativeMethodNO
            9
            struct
            ClassNamecoldfusion.runtime.java.JavaProxy
            FileNameJavaProxy.java
            LineNumber97
            MethodNameinvoke
            NativeMethodNO
            10
            struct
            ClassNamecoldfusion.runtime.dotnet.DotNetProxy
            FileNameDotNetProxy.java
            LineNumber38
            MethodNameinvoke
            NativeMethodNO
            11
            struct
            ClassNamecoldfusion.runtime.CfJspPage
            FileNameCfJspPage.java
            LineNumber2432
            MethodName_invoke
            NativeMethodNO
            12
            struct
            ClassNamecfxml2ecfc1581484751$funcSENDXML
            FileNameM:\Spiral Binding Company\spiralbinding.com\dev10\modules\singletons\xml.cfc
            LineNumber1438
            MethodNamerunFunction
            NativeMethodNO
            13
            struct
            ClassNamecoldfusion.runtime.UDFMethod
            FileNameUDFMethod.java
            LineNumber472
            MethodNameinvoke
            NativeMethodNO
            14
            struct
            ClassNamecoldfusion.filter.SilentFilter
            FileNameSilentFilter.java
            LineNumber47
            MethodNameinvoke
            NativeMethodNO
            15
            struct
            ClassNamecoldfusion.runtime.UDFMethod$ReturnTypeFilter
            LineNumber405
            MethodNameinvoke
            NativeMethodNO
            16
            struct
            ClassNamecoldfusion.runtime.UDFMethod$ArgumentCollectionFilter
            LineNumber368
            MethodNameinvoke
            NativeMethodNO
            17
            struct
            ClassNamecoldfusion.filter.FunctionAccessFilter
            FileNameFunctionAccessFilter.java
            LineNumber55
            MethodNameinvoke
            NativeMethodNO
            18
            struct
            LineNumber321
            MethodNamerunFilterChain
            NativeMethodNO
            19
            struct
            LineNumber220
            MethodNameinvoke
            NativeMethodNO
            20
            struct
            LineNumber2659
            MethodName_invokeUDF
            NativeMethodNO
            21
            struct
            ClassNamecfxml2ecfc1581484751$funcGETALLORDERHISTORY
            LineNumber573
            NativeMethodNO
            22
            struct
            LineNumber472
            MethodNameinvoke
            NativeMethodNO
            23
            struct
            LineNumber47
            MethodNameinvoke
            NativeMethodNO
            24
            struct
            LineNumber405
            MethodNameinvoke
            NativeMethodNO
            25
            struct
            LineNumber368
            MethodNameinvoke
            NativeMethodNO
            26
            struct
            LineNumber55
            MethodNameinvoke
            NativeMethodNO
            27
            struct
            LineNumber321
            NativeMethodNO
            28
            struct
            LineNumber220
            MethodNameinvoke
            NativeMethodNO
            29
            struct
            ClassNamecoldfusion.runtime.TemplateProxy
            FileNameTemplateProxy.java
            LineNumber655
            MethodNameinvoke
            NativeMethodNO
            30
            struct
            LineNumber444
            MethodNameinvoke
            NativeMethodNO
            31
            struct
            LineNumber414
            MethodNameinvoke
            NativeMethodNO
            32
            struct
            LineNumber2432
            MethodName_invoke
            NativeMethodNO
            33
            struct
            ClassNamecforderHistory2ecfm2140766359
            FileNameM:\Spiral Binding Company\spiralbinding.com\dev10\orderHistory.cfm
            LineNumber118
            MethodName_factor12
            NativeMethodNO
            34
            struct
            LineNumber1
            MethodNamerunPage
            NativeMethodNO
            35
            struct
            LineNumber244
            MethodNameinvoke
            NativeMethodNO
            36
            struct
            ClassNamecoldfusion.tagext.lang.IncludeTag
            FileNameIncludeTag.java
            LineNumber444
            MethodNamedoStartTag
            NativeMethodNO
            37
            struct
            LineNumber2799
            MethodName_emptyTcfTag
            NativeMethodNO
            38
            struct
            ClassNamecfthemer2ecfm992586638
            FileNameM:\Spiral Binding Company\spiralbinding.com\dev10\includes\themer.cfm
            LineNumber314
            MethodName_factor7
            NativeMethodNO
            39
            struct
            LineNumber167
            MethodName_factor48
            NativeMethodNO
            40
            struct
            LineNumber1
            MethodNamerunPage
            NativeMethodNO
            41
            struct
            LineNumber244
            MethodNameinvoke
            NativeMethodNO
            42
            struct
            LineNumber444
            NativeMethodNO
            43
            struct
            LineNumber2799
            NativeMethodNO
            44
            struct
            ClassNamecfapplication2ecfc1132292741$funcONREQUEST
            FileNameM:\Spiral Binding Company\spiralbinding.com\dev10\application.cfc
            LineNumber67
            NativeMethodNO
            45
            struct
            LineNumber472
            MethodNameinvoke
            NativeMethodNO
            46
            struct
            LineNumber368
            MethodNameinvoke
            NativeMethodNO
            47
            struct
            LineNumber55
            MethodNameinvoke
            NativeMethodNO
            48
            struct
            LineNumber321
            NativeMethodNO
            49
            struct
            LineNumber220
            MethodNameinvoke
            NativeMethodNO
            50
            struct
            LineNumber655
            MethodNameinvoke
            NativeMethodNO
            51
            struct
            LineNumber444
            MethodNameinvoke
            NativeMethodNO
            52
            struct
            LineNumber414
            MethodNameinvoke
            NativeMethodNO
            53
            struct
            ClassNamecoldfusion.runtime.AppEventInvoker
            FileNameAppEventInvoker.java
            LineNumber108
            MethodNameinvoke
            NativeMethodNO
            54
            struct
            LineNumber300
            MethodNameonRequest
            NativeMethodNO
            55
            struct
            ClassNamecoldfusion.filter.ApplicationFilter
            FileNameApplicationFilter.java
            LineNumber424
            MethodNameinvoke
            NativeMethodNO
            56
            struct
            ClassNamecoldfusion.filter.RequestMonitorFilter
            FileNameRequestMonitorFilter.java
            LineNumber48
            MethodNameinvoke
            NativeMethodNO
            57
            struct
            ClassNamecoldfusion.filter.MonitoringFilter
            FileNameMonitoringFilter.java
            LineNumber40
            MethodNameinvoke
            NativeMethodNO
            58
            struct
            ClassNamecoldfusion.filter.PathFilter
            FileNamePathFilter.java
            LineNumber112
            MethodNameinvoke
            NativeMethodNO
            59
            struct
            ClassNamecoldfusion.filter.LicenseFilter
            FileNameLicenseFilter.java
            LineNumber30
            MethodNameinvoke
            NativeMethodNO
            60
            struct
            ClassNamecoldfusion.filter.ExceptionFilter
            FileNameExceptionFilter.java
            LineNumber94
            MethodNameinvoke
            NativeMethodNO
            61
            struct
            ClassNamecoldfusion.filter.ClientScopePersistenceFilter
            FileNameClientScopePersistenceFilter.java
            LineNumber28
            MethodNameinvoke
            NativeMethodNO
            62
            struct
            ClassNamecoldfusion.filter.BrowserFilter
            FileNameBrowserFilter.java
            LineNumber38
            MethodNameinvoke
            NativeMethodNO
            63
            struct
            ClassNamecoldfusion.filter.NoCacheFilter
            FileNameNoCacheFilter.java
            LineNumber46
            MethodNameinvoke
            NativeMethodNO
            64
            struct
            ClassNamecoldfusion.filter.GlobalsFilter
            FileNameGlobalsFilter.java
            LineNumber38
            MethodNameinvoke
            NativeMethodNO
            65
            struct
            ClassNamecoldfusion.filter.DatasourceFilter
            FileNameDatasourceFilter.java
            LineNumber22
            MethodNameinvoke
            NativeMethodNO
            66
            struct
            ClassNamecoldfusion.filter.CachingFilter
            FileNameCachingFilter.java
            LineNumber62
            MethodNameinvoke
            NativeMethodNO
            67
            struct
            ClassNamecoldfusion.CfmServlet
            FileNameCfmServlet.java
            LineNumber219
            MethodNameservice
            NativeMethodNO
            68
            struct
            ClassNamecoldfusion.bootstrap.BootstrapServlet
            FileNameBootstrapServlet.java
            LineNumber89
            MethodNameservice
            NativeMethodNO
            69
            struct
            ClassNameorg.apache.catalina.core.ApplicationFilterChain
            FileNameApplicationFilterChain.java
            LineNumber305
            MethodNameinternalDoFilter
            NativeMethodNO
            70
            struct
            LineNumber210
            MethodNamedoFilter
            NativeMethodNO
            71
            struct
            ClassNamecoldfusion.monitor.event.MonitoringServletFilter
            FileNameMonitoringServletFilter.java
            LineNumber42
            MethodNamedoFilter
            NativeMethodNO
            72
            struct
            ClassNamecoldfusion.bootstrap.BootstrapFilter
            FileNameBootstrapFilter.java
            LineNumber46
            MethodNamedoFilter
            NativeMethodNO
            73
            struct
            LineNumber243
            NativeMethodNO
            74
            struct
            LineNumber210
            MethodNamedoFilter
            NativeMethodNO
            75
            struct
            ClassNameorg.apache.catalina.core.StandardWrapperValve
            FileNameStandardWrapperValve.java
            LineNumber224
            MethodNameinvoke
            NativeMethodNO
            76
            struct
            ClassNameorg.apache.catalina.core.StandardContextValve
            FileNameStandardContextValve.java
            LineNumber169
            MethodNameinvoke
            NativeMethodNO
            77
            struct
            ClassNameorg.apache.catalina.authenticator.AuthenticatorBase
            FileNameAuthenticatorBase.java
            LineNumber472
            MethodNameinvoke
            NativeMethodNO
            78
            struct
            ClassNameorg.apache.catalina.core.StandardHostValve
            FileNameStandardHostValve.java
            LineNumber168
            MethodNameinvoke
            NativeMethodNO
            79
            struct
            ClassNameorg.apache.catalina.valves.ErrorReportValve
            FileNameErrorReportValve.java
            LineNumber98
            MethodNameinvoke
            NativeMethodNO
            80
            struct
            ClassNameorg.apache.catalina.valves.AccessLogValve
            FileNameAccessLogValve.java
            LineNumber928
            MethodNameinvoke
            NativeMethodNO
            81
            struct
            ClassNameorg.apache.catalina.core.StandardEngineValve
            FileNameStandardEngineValve.java
            LineNumber118
            MethodNameinvoke
            NativeMethodNO
            82
            struct
            ClassNameorg.apache.catalina.connector.CoyoteAdapter
            FileNameCoyoteAdapter.java
            LineNumber414
            MethodNameservice
            NativeMethodNO
            83
            struct
            ClassNameorg.apache.coyote.ajp.AjpProcessor
            FileNameAjpProcessor.java
            LineNumber204
            MethodNameprocess
            NativeMethodNO
            84
            struct
            ClassNameorg.apache.coyote.AbstractProtocol$AbstractConnectionHandler
            FileNameAbstractProtocol.java
            LineNumber539
            MethodNameprocess
            NativeMethodNO
            85
            struct
            ClassNameorg.apache.tomcat.util.net.JIoEndpoint$SocketProcessor
            FileNameJIoEndpoint.java
            LineNumber298
            MethodNamerun
            NativeMethodNO
            86
            struct
            ClassNamejava.util.concurrent.ThreadPoolExecutor
            FileNameThreadPoolExecutor.java
            LineNumber1145
            MethodNamerunWorker
            NativeMethodNO
            87
            struct
            ClassNamejava.util.concurrent.ThreadPoolExecutor$Worker
            LineNumber615
            MethodNamerun
            NativeMethodNO
            88
            struct
            ClassNamejava.lang.Thread
            FileNameThread.java
            LineNumber722
            MethodNamerun
            NativeMethodNO
            Suppressed
            array [empty]
            aundefined
            LocalizedMessageundefined
            Messageundefined
            StackTrace
            array
            1
            struct
            LineNumber-1
            NativeMethodNO
            2
            struct
            LineNumber-2
            MethodNameinvoke0
            NativeMethodYES
            3
            struct
            LineNumber57
            MethodNameinvoke
            NativeMethodNO
            4
            struct
            LineNumber43
            MethodNameinvoke
            NativeMethodNO
            5
            struct
            FileNameMethod.java
            LineNumber601
            MethodNameinvoke
            NativeMethodNO
            6
            struct
            LineNumber97
            MethodNameinvoke
            NativeMethodNO
            7
            struct
            LineNumber38
            MethodNameinvoke
            NativeMethodNO
            8
            struct
            LineNumber2432
            MethodName_invoke
            NativeMethodNO
            9
            struct
            LineNumber1438
            NativeMethodNO
            10
            struct
            LineNumber472
            MethodNameinvoke
            NativeMethodNO
            11
            struct
            LineNumber47
            MethodNameinvoke
            NativeMethodNO
            12
            struct
            LineNumber405
            MethodNameinvoke
            NativeMethodNO
            13
            struct
            LineNumber368
            MethodNameinvoke
            NativeMethodNO
            14
            struct
            LineNumber55
            MethodNameinvoke
            NativeMethodNO
            15
            struct
            LineNumber321
            NativeMethodNO
            16
            struct
            LineNumber220
            MethodNameinvoke
            NativeMethodNO
            17
            struct
            LineNumber2659
            NativeMethodNO
            18
            struct
            LineNumber573
            NativeMethodNO
            19
            struct
            LineNumber472
            MethodNameinvoke
            NativeMethodNO
            20
            struct
            LineNumber47
            MethodNameinvoke
            NativeMethodNO
            21
            struct
            LineNumber405
            MethodNameinvoke
            NativeMethodNO
            22
            struct
            LineNumber368
            MethodNameinvoke
            NativeMethodNO
            23
            struct
            LineNumber55
            MethodNameinvoke
            NativeMethodNO
            24
            struct
            LineNumber321
            NativeMethodNO
            25
            struct
            LineNumber220
            MethodNameinvoke
            NativeMethodNO
            26
            struct
            LineNumber655
            MethodNameinvoke
            NativeMethodNO
            27
            struct
            LineNumber444
            MethodNameinvoke
            NativeMethodNO
            28
            struct
            LineNumber414
            MethodNameinvoke
            NativeMethodNO
            29
            struct
            LineNumber2432
            MethodName_invoke
            NativeMethodNO
            30
            struct
            LineNumber118
            MethodName_factor12
            NativeMethodNO
            31
            struct
            LineNumber1
            MethodNamerunPage
            NativeMethodNO
            32
            struct
            LineNumber244
            MethodNameinvoke
            NativeMethodNO
            33
            struct
            LineNumber444
            NativeMethodNO
            34
            struct
            LineNumber2799
            NativeMethodNO
            35
            struct
            LineNumber314
            MethodName_factor7
            NativeMethodNO
            36
            struct
            LineNumber167
            MethodName_factor48
            NativeMethodNO
            37
            struct
            LineNumber1
            MethodNamerunPage
            NativeMethodNO
            38
            struct
            LineNumber244
            MethodNameinvoke
            NativeMethodNO
            39
            struct
            LineNumber444
            NativeMethodNO
            40
            struct
            LineNumber2799
            NativeMethodNO
            41
            struct
            LineNumber67
            NativeMethodNO
            42
            struct
            LineNumber472
            MethodNameinvoke
            NativeMethodNO
            43
            struct
            LineNumber368
            MethodNameinvoke
            NativeMethodNO
            44
            struct
            LineNumber55
            MethodNameinvoke
            NativeMethodNO
            45
            struct
            LineNumber321
            NativeMethodNO
            46
            struct
            LineNumber220
            MethodNameinvoke
            NativeMethodNO
            47
            struct
            LineNumber655
            MethodNameinvoke
            NativeMethodNO
            48
            struct
            LineNumber444
            MethodNameinvoke
            NativeMethodNO
            49
            struct
            LineNumber414
            MethodNameinvoke
            NativeMethodNO
            50
            struct
            LineNumber108
            MethodNameinvoke
            NativeMethodNO
            51
            struct
            LineNumber300
            MethodNameonRequest
            NativeMethodNO
            52
            struct
            LineNumber424
            MethodNameinvoke
            NativeMethodNO
            53
            struct
            LineNumber48
            MethodNameinvoke
            NativeMethodNO
            54
            struct
            LineNumber40
            MethodNameinvoke
            NativeMethodNO
            55
            struct
            LineNumber112
            MethodNameinvoke
            NativeMethodNO
            56
            struct
            LineNumber30
            MethodNameinvoke
            NativeMethodNO
            57
            struct
            LineNumber94
            MethodNameinvoke
            NativeMethodNO
            58
            struct
            LineNumber28
            MethodNameinvoke
            NativeMethodNO
            59
            struct
            LineNumber38
            MethodNameinvoke
            NativeMethodNO
            60
            struct
            LineNumber46
            MethodNameinvoke
            NativeMethodNO
            61
            struct
            LineNumber38
            MethodNameinvoke
            NativeMethodNO
            62
            struct
            LineNumber22
            MethodNameinvoke
            NativeMethodNO
            63
            struct
            LineNumber62
            MethodNameinvoke
            NativeMethodNO
            64
            struct
            LineNumber219
            MethodNameservice
            NativeMethodNO
            65
            struct
            LineNumber89
            MethodNameservice
            NativeMethodNO
            66
            struct
            LineNumber305
            NativeMethodNO
            67
            struct
            LineNumber210
            MethodNamedoFilter
            NativeMethodNO
            68
            struct
            LineNumber42
            MethodNamedoFilter
            NativeMethodNO
            69
            struct
            LineNumber46
            MethodNamedoFilter
            NativeMethodNO
            70
            struct
            LineNumber243
            NativeMethodNO
            71
            struct
            LineNumber210
            MethodNamedoFilter
            NativeMethodNO
            72
            struct
            LineNumber224
            MethodNameinvoke
            NativeMethodNO
            73
            struct
            LineNumber169
            MethodNameinvoke
            NativeMethodNO
            74
            struct
            LineNumber472
            MethodNameinvoke
            NativeMethodNO
            75
            struct
            LineNumber168
            MethodNameinvoke
            NativeMethodNO
            76
            struct
            LineNumber98
            MethodNameinvoke
            NativeMethodNO
            77
            struct
            LineNumber928
            MethodNameinvoke
            NativeMethodNO
            78
            struct
            LineNumber118
            MethodNameinvoke
            NativeMethodNO
            79
            struct
            LineNumber414
            MethodNameservice
            NativeMethodNO
            80
            struct
            LineNumber204
            MethodNameprocess
            NativeMethodNO
            81
            struct
            LineNumber539
            MethodNameprocess
            NativeMethodNO
            82
            struct
            LineNumber298
            MethodNamerun
            NativeMethodNO
            83
            struct
            LineNumber1145
            MethodNamerunWorker
            NativeMethodNO
            84
            struct
            LineNumber615
            MethodNamerun
            NativeMethodNO
            85
            struct
            FileNameThread.java
            LineNumber722
            MethodNamerun
            NativeMethodNO
            Suppressed
            array [empty]
            • 3. Re: .net 4.5 support
              vadobe11 Level 1
              I am from .NET Framework compatibility team. We would like to understand this better. Could you contact us on netfx45compat at microsoft dot com with sample app/project.
              Varun Gupta
              .NET Framework
              • 4. Re: .net 4.5 support
                tgorg.com Level 1
                I've tried updating to the latest version of .net (At this time 4.5.1) and there are still issues.  I've also noticed that the error seems to be occuring when a .net function returns a large string back to ColdFusion.
                • 5. Re: .net 4.5 support
                  jk23135567
                  I realize this is an old thread, but I'm having the same issues and the last sentence appears to apply to my situation perfectly.  I'm doing some testing to see what kind of effort it'll be to upgrade to CF11.  This is a show stopper..
                  I've been unable to find even any other references to this issue after nearly 6 hours of searching.... Was there ANY kind of resolution to this issue at all?
                  Thanks!
                  • 6. Re: .net 4.5 support
                    krishnapreddy_adobe Level 2
                    Fix for this issue can be taken here.  It would added in the upcoming update of ColdFusion 10.
                    http://blogs.coldfusion.com/assets/content/server/jnbridge-3864336.zip
                    Instructions are there in the same file.
                    Krishna
                    • 7. Re: .net 4.5 support
                      Fix for this issue can be taken from here.
                      For ColdFusion 11 with .Net 4 - http://blogs.coldfusion.com/assets/content/server/jnbridge-3864336.Net4.zip
                      For ColdFusion 11 with .Net 2 - http://blogs.coldfusion.com/assets/content/server/jnbridge-3864336.Net2.zip
                      For ColdFusion 10 with .Net 4 - http://blogs.coldfusion.com/assets/content/server/cf10-jnbridge-3864336.Net2.zip
                      For ColdFusion 10 with .Net 2 - http://blogs.coldfusion.com/assets/content/server/cf10jnbridge-3864336.Net4.zip
