Hi Swanley,
This is ABSOLUTELY achievable!
I'm in the same boat; we develop Presenter content for
deployment on third-party LMS systems, including Docent,
KnowlegePlanet, and a couple others...and the fix is pretty easy
too! Here's how:
Using the Presenter menu, what you want to do is get into the
Quiz Manager. From there, simply add a quiz
without adding any questions! I'd also recommend setting the
reporting as SCORM. You can do this at any time--since the quiz
element acts as a "container" for question slides (even though
there aren't any question slides), you can still benefit from the
data being sent to the LMS which will indicate course completion.
Bottom line: there's no need to worry about having a quiz
element at the end of your presentation; again, the quiz acts as a
"container"...this is evidenced by the fact that as soon as you
publish your content, you'll end up with SCORM data (look for the
SCORM support folder and it's associated files)--and all of that
will happen automatically for you.
From there, if you're familiar with running an ADL test on
your content, you'll be able to see SCO verification as you
progress through the course, including completion. If not, you can
still easily test your material by posting to your LMS; from there,
run the content, go through the course and check for completion.
Hope that helps!
Rob
