2 Replies Latest reply on Jun 3, 2013 9:42 AM by sibr
    Parallaxe with Edge
      I promised you I'll be back with an other internet site, designed and very pure this time (after the www.muscade-palais-royal.com). This time I worked for a consulting agency and I simulated the parallaxe effect. I let you see by yourself.
      Do not hesitate to send me your comments
        • 1. Re: Parallaxe with Edge
          Zaxist Level 4
          i liked your design, its cool, but there is some problems...
          First : your menu's images are not sharp enough like low resolution pictures
          Second : your total edge project have the first time load problem, users should refresh to page load
          you can check it in incognito mode of google chrome or private window in firefox, to fix this
          An easy solution for this problem was first to replace the MIME- / content- type for every script content in the .html file with "application/javascript" or "application/x-javascript" so that it will look like this: <script type="application/javascript" charset="utf-8" src="yourScript.js"></script>. Furthermore, and this was the solution in my case, create a new file named ".htaccess" and put it in the root directory of your Edge project. The content of this file should contain "AddType application/x-javascript .js" or "AddType application/javascript .js". That did it for me.
          Link : http://forums.adobe.com/message/5318464#5318464
          • 2. Re: Parallaxe with Edge
            sibr Level 1
            Thank you for your answer )
            I will try your recommendations. Iy was very kind of you to share your experience with me.
            Best regards
            De : Zaxist forums_noreply@adobe.com
            Envoyé : lundi 3 juin 2013 18:09
            À : sibr
            Objet : Parallaxe with Edge
            created by Zaxist <http://forums.adobe.com/people/Zaxist>  in Edge Animate - View the full discussion <http://forums.adobe.com/message/5375206#5375206
