3 Replies Latest reply on Jun 3, 2013 7:33 AM by betha56
    Older photos use old menu in camera raw
    betha56
      I just installed cs6 and love the basic menu in camera raw! I opened some older photos from just days ago and the old camera raw menu comes up. Is there a way to access this new menu with older photos?
      Beth
        • 1. Re: Older photos use old menu in camera raw
          Your older photos were edited with a previous version of Camera Raw which used an older process version. The new version of Camera Raw will respect and preserve those adjustments. If you want to change to the new process version go to the calibration tab in the adjustment panel and choose PV 2012.  This could alter your image significantly depending on the adjustments you have made in the previous version. Sometimes those changes are unacceptable. That is one of the reasons why Camera Raw respects those earlier adjustments. This gives you the opportunity to choose which images you want to switch to the new process version.
          • 2. Re: Older photos use old menu in camera raw
            Robert Shomler Level 4
            Camera raw 7 (CS6) will display a small white square with an exclamation point when it opens a raw file that processed with an older camera raw process version.  Click on this square to have camera raw use the new process version (PV2012) and the new menu sliders will be there.
            You may want to retain the earlier settings and rendering by creating a snapshot before you convert to pv2012:  Click the New Snapshot button at the bottom of the Snapshots Tab, type a snapshot name name in the New Snapshot dialog box and click OK.  Create a second snapshot after converting to pv2012.  You can go back and forth between the two to assess the changes from the newer process version.
            • 3. Re: Older photos use old menu in camera raw
              betha56 Level 1
              Hi Robert:
              Thanks for the quick response. I found the white square and am using it when I want to.
              Take care,
              Beth
