Based on the fix provided for "Contents not visible in right pane for IE10", I pasted the files (whskin_frmset01.htm and whtbar.js) accordingly. It works fine once i paste them in my compiled folder, but when i copy paste the same folder to a different location or zip the folder and unzip it, the same issue persists. Please can i know how do i get rid of this issue.
Please always start threads with the version of Rh being used.
I didn't mean to start a new thread, simply to add it here and include it in future.
The poster is using Rh9.
If anyone else is seeing this, please advise. I will test later.
The original problem only occurred when the help was published to a web server. It did not occur with the generated help locally.
If you generate and do not apply the fix are you able to move the output locally?
