3 Replies Latest reply on Jun 3, 2013 12:55 PM by Dave LaRonde
    Using pattern brushes in After Effects
    jacopovecchio
      Hi guys
      I'd like to use a line, in After Effects, drawn with something like a pattern brush because I've to move it a lot (I need to bend it, curve it, move it around).
      I use to do those thing with simple lines with generate>stroke effect, but this time I need a pattern line and I don't know how to do.
      I'm using CS6.
      here are two fast preview of what I mean. I tried also with CC Bend fx, but it doesn't work well.
      Thanx a lot.
      J
        • 1. Re: Using pattern brushes in After Effects
          There's no real easy way to do this in AE directly. You could use Illustrator to create your paths and then reveal them with a track matte. You could use a particle system like Particular to deposit custom shapes along a path. You could use echo. Do you want to bend the paths after they are revealed like a snake or just reveal the pattern on a path? It makes a difference.
          The last option would be to draw a path in illustrator, expand the path with the pattern brush, un-group the expanded path, release to layers, move the released layers to the top of the layer palette, then open in AE as a composition and sequence the layers. Something along the lines of my zillion year old tutorial on morphing Illustrator shapes in AE. You'll find it here.
          • 2. Re: Using pattern brushes in After Effects
            jacopovecchio Level 1
            Well, first of all thankyou for your answer.
            What I'd like to do is to animate pattern along line just like a snake. I want the horizontal lines to be stretched/rotated/morphed along the line I'm drawing.
            Nice tutorial It may be useful.
            Good afternoon
            • 3. Re: Using pattern brushes in After Effects
              Dave LaRonde Level 6
              Here's a thought: don't use Illustrator.  Use AE text, and animate it along an open mask path.  I'd imagine the letter I or l in the proper typeface and point size would work very well.
