1 Reply Latest reply on Aug 29, 2014 8:24 AM by OneLove
    CF10: Consuming SOAP-Service - Axis2 Enumeration
      Hi all,
      Im trying to call a webservice with a complex-within-complex structure. Here an extract form the wsdl:
      <simpleType name="ProductType">
          <restriction base="xsd:string">
           <enumeration value="Car"/>
           <enumeration value="Truck"/>
      <complexType name="Product">
           <element name="id" type="xsd:string"/>
           <element name="type" type="impl:ProductType"/>
      If i call the webservice with a structure as Parameter
      <cfset local.ws.addProduct( {
          type: 'Truck'
      I get an Error.
      Cannot perform web service invocation addProduct.
      The fault returned when invoking the web service operation is:
      org.apache.axis2.AxisFault: product cannot be null!!
      If i change the wsdl file, so the Type of the element "type" is also "xsd:string", then it works perfectly. Problem is, changing the wsdl file by myself is a absolute no-go, since i have to consume it form our customers.
      Based on reserches i've found that older Axis2 version didn't implement the Enumeration-Type, but the one shipped with CF10 should (Axis2 v1.7).
      I've found this Thread: http://forums.adobe.com/thread/88154
      I tried to copy the generated stubs for productType in the cfusion/wwwroot/WEB-INF/classes and create a object with createObject("java","productType") which -of course- generated an Error saying that i cannot create from abstract classes. sigh.
      Did anyone managed to call an Webservice with Enumerations in WSDL?
      Best regards,
