3 Replies Latest reply on Jun 3, 2013 8:25 AM by Peter Spier
    Fonts not showing in InDesign CS6
      Hi there,
      I've seen a similar question to this before through a Google search and I tried the advice listed such as placing the affected fonts in: C:\Program Files(x86)\Adobe\InDesign CS6\Fonts; as well as searching for fonts with a **after its name.  Doesn't work.  The files originated in CS5 and pops up saying there are two missing links (fonts) which are Avenir Book and Avenir Black.  I've done the "Find Font" and the only one that shows is Avenir Book.  Avenir Black isn't even there, even after re-installing and relocating to the new folder.  Secondly, even after I save the file after "finding" Avenir Book, upon re-opening it still says it's missing.  Is there anything else I can try-short of uninstalling InDesign CS6 (I still have CS5 installed)?  Also, I'm not that familiar with InDesign, it isn't a program I use much.
        • 1. Re: Fonts not showing in InDesign CS6
          Is this the same computer where the files started out in CS5?
          There are probably quite a few different cuts of Avenir (certainly over the years it has been available as TT and T1 in both Windows and Mac formats, and I have an OpenType version here from Linotype). Some possibilities for why CS6 might not see a font are that you have installed a different version, you have more than one version installed or it is installed in more than one location, or that it is looking at a different internal name in CS6. Typically, if the fonts are showing as missing, but are, in fact installed, using Find Font and substituting the same font will solve the problem.
          • 2. Re: Fonts not showing in InDesign CS6
            soupyhorses Level 1
            No, our advertising company created the files and saved them to an external which I have.  The problem arose when I sent the files to our printer to have them printed and it was missing all of the links.  But when I open it on my computer, only some of the links are missing.  On my end at least since I've been looking at it for awhile-I think Avenir Black is showing up as Avenir in InDesign. Something I don't understand is that after I replace Avenir Book with itself, save and re-open I'm having the same problem.
            • 3. Re: Fonts not showing in InDesign CS6
              This is not something I think I'm going to be able to figure out without seeing the file and the computer where the fonts are installed, which is not possible unless you happen to be located someplace on Cape Cod. Sorry.
