• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Some drop-down hotspots not dropping down
Explorer ,
Oct 16, 2007 Oct 16, 2007
Hi all,
I have a bit of a problem with my chm file in that about 6 of the many drop-down hotspots aren't opening when the user clicks on them. I took a look at the True Code to see what was happening and I can't see any difference between the ones that work and those that don't. Is there a maximum number of DHTML items you can include in a chm file? Or can anybody think of what else might be going on here?
Thanks in advance,
darkagn
Views
409
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor ,
I've seen this when the ID on the hyperlink and hidden div don't match. Viewing the code, check that "x-use-popup" code matches the id on the hidden div.
It will looks something like "a class=dropspot x-use-popup=#POPUP320846813" and "div class=x-popup-text
id=POPUP320846813"
The other thing to check is that there aren't multiple divs with the same number.
I've found RH6 sometimes gets confused if you have something like:
Dropspot 1
Dropspot 2
Dropspot 3
And have at some point had them all in one paragraph and pressed Enter to separate them. That gives some really funky results.
Votes
Translate
Translate
Report
Report
Engaged ,
Oct 17, 2007 Oct 17, 2007
Have you tried recreating the dropdowns? We ran into a situation much like Amebr's and redoing the dropdowns typically fixed the problem. If that works, then fixing half a dozen instances shouldn't be too bad.
G
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 18, 2007 Oct 18, 2007
Thanks for the responses Amebr and Gravenstein!
I followed your advice and it appears to have fixed the problem.
Cheers,
darkagn
Votes
Translate
Translate
Report
Report
New Here ,
Nov 02, 2007 Nov 02, 2007
LATEST
I found the same problem, though after searching long and hard, what I realised is that the dropdown's style is suddenly set to "none". As soon as I changed it to normal or heading 1 or whatever else, deleted a space or 2, it worked.
Try this, hope it helps.
r
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
