3 Replies Latest reply on Jun 10, 2013 10:07 AM by Zac Lam
    exporter plugin: How does exporting multiple files work?
    nvenc4everyone Level 1
      I'm trying to get my exporter to simultaneously export 2 separate files (one for audio, one for video):
      (1) *.wav file (for PCM audio)
      (2) *.m4v file (for encoded H264 video)
      The exported WAV & M4V files are readable in external tools - So I have the basic exporting routines writing out correct fileData.
      But so far, I can do ONE at a time -- i.e. I have manually hardcoded the 'supportsAudio' and 'supportsVideo' to to be mutually exclusive, and changed my exDoExport() routine to behave accordingly.
      I want my exporter to support any combination of audio/video exporter: audio-only, video-only, or audio + video
      (1) audio-only   : write out a single *.WAV file
      (2) video-only   : write out a single *.m4V file
      (3) audio+video : write out both files (*.WAV + *.M4V)
      But I can't figure out how to do this through the Premiere Pro CS6 SDK.
      I've tried writing handlers for the selector exSelQueryOutputFileList.  I followed the directions carefully (about PPro calling the selector 3 times in a row.)  I've stepped through my handler using VS2010's debugger, so I *know* that CS6 is calling me 3 times.  And I have also confirmed that I correctly set the numOutputFiles, outputFileRecs.pathLength, and outputFileRecs.path.
      But when the 'export' method is finally engaged, CS6 only calls the exSelExport selector ONCE, and it only passes the first outputFileRec[#0].  So there is no opportunity for my exporter code to utilize the 2 outputFileRecs that were allocated previously.
      ....How is this supposed to work?!?
