3 Replies Latest reply on Jun 5, 2013 12:48 PM by rush_pawan
    Jackrabbit search jcr repository on multiple paths using single query
    cqexperiment
      I have been trying to work this out: using either xpath or SQL or SQL2, to perform a full text search on multiple paths.
      i.e.
      Search for 'promotion' under '/content/mysite/products/%' and '/content/dam/articles/pdfs/products' etc.
      Tried using the following but none worked so far:
      SQL2:
      SELECT * FROM [nt:base] AS s
      WHERE  ISDESCENDANTNODE([/content/mysite/products]) or                ISDESCENDANTNODE([/content/dam/articles/pdf/products])
      and CONTAINS(s.*, 'promotion')
      SQL:
      select * from nt:base where (jcr:path like '/content/mysite/products/%' or jcr:path like '/content/dam/articles/pdf/products/%') and contains (., 'promotion')
      xpath:
      /jcr:root/content/[fn:name()='/mysite/products' or fn:name()='/dam/articles/pdf/products]//*[jcr:like(text, '%promotion%')]
      The reason for making a query like this is because we can than sort the result by jcr:score. If separate queries were used on each path then we need to work out how to consolidate and sort everything according to the score.
      Already tried predicateGroup but:
      1. Very slow
      2. 'lower' function isn't working on fulltext search
      Appreciate any advice or suggestions.
