1. Re: update fail jun
Noel Carboni Jun 4, 2013 8:44 AM (in response to upd8te)Have you modified your existing installation on disk? Downloaded components yourself or removed/moved components from the location in which Adobe put them? There were, for example, some quick fixes made available for extension panels as I recall that would have replaced components the installer would expect to see.
In the past, others have had this error and reported that an uninstallation of Photoshop, followed by a fresh installation and immediate update, have worked to overcome the problem.
-Noel
2. Re: update fail jun
Curt Y Jun 4, 2013 9:39 AM (in response to upd8te)Just a test to see in post by Noel made an hour ago shows up when I hit reply.
Edit. Yes it did.
3. Re: update fail jun
Noel Carboni Jun 4, 2013 10:01 AM (in response to Curt Y)Curt, I couldn't see your reply. So on a hunch I changed the server name from forums.adobe.com to support.muse.adobe.com (something I only just discovered this morning by accident), and it shows up.
Maybe that's a more direct server address with which to access the forums? Honestly I don't know what it is. I've asked what the difference is over in the forum comments section.
-Noel
4. Re: update fail jun
Curt Y Jun 4, 2013 10:18 AM (in response to Noel Carboni)Noel, Forums having trouble in last few days with responses not showing up. Seems to be particually prevalent today. See this post. http://forums.adobe.com/thread/1225369?tstart=0
Lost PSD file http://forums.adobe.com/thread/1225385?tstart=0 is a current example. Chris's response not seen.
