7 Replies Latest reply on Jun 14, 2013 10:54 AM by alpi agarwal
    CC button and Notes Pane
    Michele_Christian
      We are working on making our Adobe Presenter file 508 Accessible. We would like to use the notes pane to provide a Long Description of the Animation along with the transcript text. 2 questions:
      1. Is there a way to remove the CC button or rename it?
      2. Is there a way to remove the date stamp that appears at the bottom of the notes in the Notes pane?
      Thank you!
        • 1. Re: CC button and Notes Pane
          alpi agarwal Adobe Employee
          Hi Michele,
          Your question: Is there a way to remove the CC button or rename it?
          My Answer: There is crrently no way to remove the cc button. When user clicks on the cc button, Notes pane opens up. You may rename the notes pane to something like scripts, captions etc. You cannot rename the cc button.
          To rename the Notes tab, goto Themes->Modify Text labels->Find 'Notes tab text'. change it to whatever you want.
          Is there any specific reason you want to hide\rename the cc button ?
          Your Question : Is there a way to remove the date stamp that appears at the bottom of the notes in the Notes pane?
          My Answer : I do not see any date stamp.. Are you talking about the time remaining text that comes at the bottom of notes pane ?
          If so you may hide it using the following:  goto Themes->Modify Text labels->Elapsed time->delete the text. add one blank using spacebar. Publish.
          You should not see that string again in the published utput.
          Let me know if you need any other assistance.
          Alpi Agarwal
          Adobe Presenter Engineering Team
          • 2. Re: CC button and Notes Pane
            Michele_Christian Level 1
            Thank you for your reply.
            To answer your question about #1, we are attempting to use the Notes pane for the Audio transcript AND a detailed description of the visual elements. This is in an effort to make the Presentation most 508 Accessible.
            We are unable to adjust the highlighting that is activated by the CC function. So we are trying to figure out if we can:
            a. Adjust the automatic highlighted activated by the CC function,
            b. remove the button, or
            c. rename the button.
            Any ideas?
            for #2 - we will try that. Thanks!!
            • 3. Re: CC button and Notes Pane
              Hi Michele,
              The CC is supposed to work like this in presenter:
              Whatever script you write in the notes tab ,the duration of slide is equally divided for highlighting all the lines .
              We as a author  cannot adjust the automatic highlights. It cannot be exactly synched with th eaudio
              Also currently we do not have a way to either remove or rename the cc button.
              Alpi Agarwal
              • 4. Re: CC button and Notes Pane
                Thanks again, Alpi.
                For #1: Could this CC function be fixed to not highlight the lines automatically? Since the notes field may be used for more than just the Audio Transcript. In our case, we are using that Pane for multiple functions. The highlighting text does not make sense in this case.
                For #2: Please see the image below. can you please provide some guidance on removing the date stamp? We did not put this in, it is automatically happening in Presenter:Presenter.png
                • 5. Re: CC button and Notes Pane
                  For f#1:  Currently there is no way to  not highlight the lines automatically. But we are providing the way to do so in the coming Presenter release.
                  For #2: Which powerpoint version and presenter version are you using ?
                  Alpi Agarwal
                  • 6. Re: CC button and Notes Pane
                    RE: Which PowerPoint version and presenter version are you using ?
                    We are currently testing with Adobe Presenter 8.0.1 Build 260 and the current Trial version.
                    PowerPoint 14.0.6123.5001 (32 bit)
                    We are comparing the accessibility features of Adobe Presenter and Articulate Storyline for use in our current project.
                    • 7. Re: CC button and Notes Pane
                      There is no way presenter adds time stamp to your published output automatically.
                      It must be some setting in powerpoint.
                      Could you please check the following:
                      Goto Insert->Date and Time->Select Notes&Handouts tab.
                      Make sure that date and time is unchecked for Notes and handouts.
                      If this do not solve the problem, please send me the presentation or the slide having the problem
                      You can mail me at alpagarw@adobe.com
                      Alpi Agarwal
