1 Reply Latest reply on Jun 5, 2013 1:51 PM by Devendra Kumar
    Incomplete installation of downloaded flash player update
    obioputa
      A required file (C:Windows\SysWOW64\Macromed\Flash\flahplayer.xpt:5) could not be written while I was installing downloaded flash player update in Windows 7 due to insufficient permissions. how do I get sufficient permissions?
        • 1. Re: Incomplete installation of downloaded flash player update
          Devendra Kumar Adobe Employee
          Administrative permissions are necessary so that the Adobe Flash Player installer can access the Windows system registry and the following folder:
          C:\WINDOWS\system32\Macromed\Flash folder for a 32-bit machine
          C:\WINDOWS\SysWOW64\Macromed\Flash folder for a 64-bit machine
          In Windows Vista® and Windows 7®, regardless of your permissions, you can run any application as an administrator. To run an application as an administrator, right-click the filename and select Run As Administrator. Provide the administrator ID and password when prompted.
          If you need more help, contact your system administrator.
