2 Replies Latest reply on Oct 15, 2007 10:22 AM by emmim44
    CF,Ajax
    emmim44 Level 1
      Hi all.
      I am using Ajax on my table row...but some select box prevent it to be visible...It div goes under the select box when I start type in....Help
      [code]
      <input name="ConTNo" type="text" id="ConTNo" size="20" maxlength="30" onKeyUp="showHint(this.value)" onBlur="setTimeout('gosterme(this)',125)">
      <tr><td> </td><td colspan="6"><div id="txtHint" style="position:absolute; z-index:1 " ></div></td></tr>
      <TR align="left" valign="top">
      <TD height="24"><span class="style15"><strong>Discipline:</strong></span></TD>
      <TD colspan="2">
      <select NAME="Discipline" SIZE="1" >
      <option value=""></option>
      <option value="A">Architectural</option>
      <option value="C">Civil</option>
      <option value="E">Electrical</option>
      <option value="G">General</option>
      <option value="J">Geotechnical</option>
      <option value="M">Mechanical</option>
      <option value="S">Structural</option>
      <option value="T">Traffic</option>
      <option value="U">Utility</option>
      <option value="V">Environmental</option>
      </select>
      [/code]
        • 1. Re: CF,Ajax
          Level 7
          "I am using Ajax on my table row...but some select box prevent it to be
          visible...It div goes under the select box when I start type in....Help"
          If I understand your issue correctly, you have a select control and it
          is inappropriately covers other content on the site. If so, this is a
          browser issue, particularly with some version of one from Redmond
          Washington.
          It basically behaves as the select control has an infinite z index and
          it can not be controlled. There are solutions out there. The basic
          idea is to use some JavaScript to hide and show the select control so
          that is does not interfere with other sections of the site.
          HTH
          Ian
          • 2. Re: CF,Ajax
            emmim44 Level 1
            that could be another solution ..thnx
