5 Replies Latest reply on Jun 7, 2013 9:02 AM by Yogesh Upadhyay
    how to hide the sidekick dialog
    codonvirginia
      I want to hide the sidekick dialog on the publish page so when we click on the link they dont show the sidekick dialog anymore.
      Anyone know, can you help me out.
      Jenny
        • 1. Re: how to hide the sidekick dialog
          orotas Level 4
          The sidekick should never show on a publish page. If sidekick is showing you probably installed your publish instances incorrectly. Check the run modes in your start script and make sure that only publish is listed as a runmode.
          • 2. Re: how to hide the sidekick dialog
            codonvirginia Level 1
            I check but I dont know why, can you help me. This is my start script. can you tell me which start file,  there are two start file, one is start and another is start.bat. These are infomation in start file.
            # TCP port used for stop and status scripts
            CQ_PORT=4505
            # HTTP host name
            CQ_HOST='abc.test.com'
            # interface that this server should listen to
            #CQ_INTERFACE='eth0'
            # runmode(s)
            CQ_RUNMODE='publish'
            # name of the jarfile
            #CQ_JARFILE=''
            # use jaas.config
            # CQ_USE_JAAS='true'
            # config for jaas
            CQ_JAAS_CONFIG='etc/jaas.config'
            # default JVM options
            CQ_JVM_OPTS='-server -Xmx2048m -XX:MaxPermSize=256M -Djava.awt.headless=true'
            # file size limit (ulimit)
            CQ_FILE_SIZE_LIMIT=8192
            # do not configure below this point
            if [ $CQ_FILE_SIZE_LIMIT ]; then
                    CURRENT_ULIMIT=`ulimit`
                    if [ $CURRENT_ULIMIT != "unlimited" ]; then
                            if [ $CURRENT_ULIMIT -lt $CQ_FILE_SIZE_LIMIT ]; then
                                    echo "ulimit ${CURRENT_ULIMIT} is too small (must be at least ${CQ_FILE_SIZE_LIMIT})"
                                    exit 1
                            fi
                    fi
            fi
            BIN_PATH=$(dirname $0)
            cd $BIN_PATH/..
            START_OPTS='start -c . -i launchpad'
            if [ $CQ_PORT ]; then
                    START_OPTS="${START_OPTS} -p ${CQ_PORT}"
            fi
            if [ $CQ_INTERFACE ]; then
                    START_OPTS="${START_OPTS} -a ${CQ_INTERFACE}"
            fi
            if [ $CQ_RUNMODE ]; then
                    START_OPTS="${START_OPTS} -Dsling.run.modes=${CQ_RUNMODE}"
            fi
            if [ $CQ_HOST ]; then
                START_OPTS="${START_OPTS} -Dorg.apache.felix.http.host=${CQ_HOST}"
            fi
            if [ $CQ_USE_JAAS ]; then
                START_OPTS="${START_OPTS} -Djava.security.auth.login.config=${CQ_JAAS_CONFIG}"
            fi
            if [ -z $CQ_JARFILE ]; then
                    CQ_JARFILE=`ls app/*.jar | head -1`
            fi
            java $CQ_JVM_OPTS -jar $CQ_JARFILE $START_OPTS &
                    echo $! > "conf/cq.pid"
            • 3. Re: how to hide the sidekick dialog
              sarwarbhuiyan
              Check the file name of the cq5 jar on publish. Also, did you copy any files from author to publish? Also, check sling.properties file if there is any run mode specified there.
              • 4. Re: how to hide the sidekick dialog
                the jar file is cq5-publish-4503.jar , I did not copy any files from author to publish, I build publish server .The sling.propertiies file are list below.
                #Overlay properties for configuration
                #Fri Jun 07 07:28:44 EDT 2013
                sling.framework.install.incremental=true
                obr.repository.url=http\://sling.apache.org/obr/repository.xml
                org.osgi.framework.system.packages=${osgi-core-packages}, ${osgi-compendium-services}, org.apache.sling.launchpad.api;version\=1.1.0
                , ${jre-${java.specification.version}} ${org.apache.sling.launcher.system.packages}
                org.apache.sling.commons.log.file.number=5
                org.osgi.framework.startlevel.beginning=30
                org.osgi.framework.bundle.parent=framework
                gosh.home=${sling.home}
                org.apache.sling.commons.log.file.size='.'yyyy-MM-dd
                ds.factory.enabled=true
                repository.home=${sling.home}/repository
                sling.bootdelegation.sun.reflect=sun.reflect
                ds.loglevel=warn
                org.apache.sling.commons.log.julenabled=true
                org.osgi.framework.system.capabilities=${eecap-${java.specification.version}}
                osgi-compendium-services=org.osgi.util.tracker;version\="1.4"
                org.osgi.framework.storage=${sling.launchpad}/felix
                org.apache.sling.commons.log.file=${sling.home}/logs/error.log
                granite.product.version=5.5.0
                org.osgi.framework.bootdelegation=com.yourkit.*, ${org.apache.sling.launcher.bootdelegation}
                sling.fileinstall.dir=${sling.home}/install
                org.apache.felix.http.shared_servlet_context_attributes=true
                felix.startlevel.bundle=20
                sling.framework.install.startlevel=1
                sling.installer.dir=${sling.launchpad}/installer
                • 5. Re: how to hide the sidekick dialog
                  Yogesh Upadhyay Level 4
                  Add sling.run.modes=publish in your sling.properties and -Dsling.run.modes=publish as a JVM Param in your start script to see if that helps.
                  To verify go to felix console and check if run mode is set correctly.
                  Yogesh
                  www.wemblog.com
