1 Reply Latest reply on Jun 11, 2013 10:39 AM by Moshu'
    JS to add url hyperlink to a rectangle shape?
    eboda_snaf Level 1
      Hi there,
      Any JS script to add a url hyperlink to a shape object ?
      Thanks a million....
        • 1. Re: JS to add url hyperlink to a rectangle shape?
          Moshu'
          here's a script that might help you. I made it and tested it only for InDesign CS5.5.
          How to use it: select any object in InDesign then run the script. At first, the script will try to see in the clipboard has valid URL (well, a text startiong with http…) and if so, the clipboard will be take as a good URL for the new created button. If no valid URL in the clipboard, the script will ask for the URL to be entered manually. If the ibject is a text frame, the script will try to take the text from inside the frame as a URL – if not valid, then the dialog pops up.
          // -------------------------------------------- BEGIN SCRIPT ----------------------------------------------
          if (app.selection.length==1) {
          //get the selected object (only one object)
          var xOBJECT = app.selection[0];
          var xPAGE = xOBJECT.parentPage;
          var xBOUNDS = xOBJECT.geometricBounds;
          //create the button
          var xBUTT = xPAGE.buttons.add({geometricBounds:xBOUNDS});
          //add selected object to the normal state
          xBUTT.states.item(0).addItemsToState(xOBJECT);
          //create the gotoURL behavior
          var xGOTOURL = xBUTT.gotoURLBehaviors.add({behaviorEvent:BehaviorEvents.mouseUp});
          //get the clipboard
          var xTEMP = app.documents[0].textFrames.add(); xTEMP.insertionPoints[-1].select(); app.paste(); var xCLIP = xTEMP.parentStory.contents; xTEMP.remove();
          //check the clipboard or text frame's text; if it does not starts with "http" then it's not good and a dialog asking a good URL will popup
          if (xOBJECT.constructor.name!="Rectangle")
              var xURL = xOBJECT.parentStory.contents;
          } else {
              var xURL = xCLIP;
          if (xURL.substring(0, 6)!="http://") {
          // do the dialog here
          var xDIAG = app.dialogs.add();
          with (xDIAG.dialogColumns.add().dialogRows.add()){staticTexts.add({staticLabel:"Enter URL:"}); var xURLTEXT = textEditboxes.add({editContents:xCLIP, minWidth:160});}
          var xRESULT = xDIAG.show({name:"Button creation"});
          if (xRESULT == true){xURL = xURLTEXT.editContents; xDIAG.destroy();} else { xURL="http://"; xDIAG.destroy();}
          // set the URL to the behavior
          xGOTOURL.url=xURL;
          // -------------------------------------------- END SCRIPT ----------------------------------------------
          Have fun!
