2 Replies Latest reply on Aug 14, 2013 11:43 PM by 8_BIT_PLATOON
    PDF in Workspace calling a Livecycle Process via SOAP, using LoadXML() script to load result set.
    8_BIT_PLATOON Level 1
      Hi All,
      1) I have a PDF which loads into Workspace.
      2) On a user click, the PDF does a lookup to a Livecycle Process via SOAP (wsdl)
      3) The webservice returns a string (which is an XML).
      4) I take the xml and load it into the relevant "results" subform using the resultsSubform.loadXML() and xfa.form.merge() functions.
      1) This works x number of times and then the x+1'th time the whole Browser PDF plug-in crashes and closes down.
      The popup appears:
      - "Adobe Reader has stopped working"
      Application Name: AcroRd32.exe
      Application Version: (the latest)
      Fault Module Name: AcroForm.api
      1) Is the combination of functions loadXML() and xfa.form.merge() correct - is there something I should be aware of?
      2) Can a LC Process-Webservice return XML as actual an XML complex type that can be interepreted or can it only return an XML string/object
