7 Replies Latest reply on Jun 7, 2013 8:21 AM by Peter Spier
    InDesign CS3 crashes on certain commands
    gawool
      I have Indesign Cs3. It was doing strange things so refreshed my preferences which solved the issue.
      Since then, I cannot create a pdf from a new document, it crashes. But I can from a document created prior to the preferences refresh.
      It also crashes when I do the find and change command?
      If anyone has any ideas it would be much appreciated. Thanks
        • 1. Re: InDesign CS3 crashes on certain commands
          See Replace Your Preferences and try again. If you used one of the methods listed there the first time, use the other, otherwise use either one.
          • 2. Re: InDesign CS3 crashes on certain commands
            gawool Level 1
            Thanks Peter but still having the same issue.
            Crash report below, if you or anyone can let me know if there is anything I can do from this?
            Identifier:  com.adobe.InDesign
            Version:     5.0.3.662 (5030)
            Code Type:   X86 (Native)
            Parent Process:  launchd [136]
            User ID:     502
            Date/Time:   2013-06-07 11:15:04.591 +0100
            OS Version:  Mac OS X 10.8.3 (12D78)
            Report Version:  10
            Interval Since Last Report:      73619 sec
            Crashes Since Last Report:       25
            Per-App Interval Since Last Report:  10541 sec
            Per-App Crashes Since Last Report:   25
            Anonymous UUID:                  7D109B11-263A-3C52-46C4-0D054699313E
            Crashed Thread:  0  Dispatch queue: com.apple.main-thread
            Exception Type:  EXC_BAD_ACCESS (SIGBUS)
            Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
            VM Regions Near 0:
            --> __PAGEZERO         0000000000000000-0000000000001000 [4K] ---/--- SM=NUL  /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Adobe InDesign CS3
            __TEXT             0000000000001000-0000000000004000 [   12K] r-x/rwx SM=COW  /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Adobe InDesign CS3
            Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
            0   com.adobe.InDesign.Find and Change Panel0x0fe0d54f GetPlugIn + 367961
            1   com.adobe.InDesign.Find and Change Panel0x0fe0d5d2 GetPlugIn + 368092
            2   com.adobe.InDesign.Find and Change Panel0x0fe24141 0xfd85000 + 651585
            3   com.adobe.InDesign.Find and Change Panel0x0fe0ddf8 GetPlugIn + 370178
            4   com.adobe.InDesign.Find and Change Panel0x0fddec33 GetPlugIn + 177213
            5   WidgetBinLib.dylib        0x0232421b CDialogController::InitializeDialog(IActiveContext*) + 61
            6   com.adobe.InDesign.Widgets0x14acdd4e 0x14ac8000 + 23886
            7   com.adobe.InDesign.Widgets0x14acc43a 0x14ac8000 + 17466
            8   com.adobe.InDesign.Find and Change Panel0x0fd8ba66 0xfd85000 + 27238
            9   WidgetBinLib.dylib        0x0239e23c CActionComponent::DoAction(IActiveContext*, IDType<ActionID_tag>, SysPoint, IPMUnknown*) + 34
            10  com.adobe.InDesign.Actions0x106cb867 GetPlugIn + 5787
            11  com.adobe.InDesign.Actions0x106c095b 0x106be000 + 10587
            12  WidgetBinLib.dylib        0x0239c1bf MDefaultEH::KeyboardShortcut(IEvent*) + 473
            13  WidgetBinLib.dylib        0x0239ba46 CDefaultEH::KeyDown(IEvent*) + 150
            14  WidgetBinLib.dylib        0x0239bfca MDefaultEH::KeyDown(IEvent*) + 162
            15  PublicLib.dylib           0x00f25ad5 CEventDispatcher::DispatchToEventHandlers(IEvent*) + 157
            16  PublicLib.dylib           0x00f25724 CEventDispatcher::DispatchEvent(IEvent*, IEvent::SystemHandledState) + 24
            17  com.adobe.InDesign.Application UI0x10915fe5 GetPlugIn + 196289
            18  com.adobe.InDesign.Application UI0x109144ab GetPlugIn + 189319
            19  com.apple.HIToolbox       0x905519bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
            20  com.apple.HIToolbox       0x903d9394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
            21  com.apple.HIToolbox       0x903d8780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
            22  com.apple.HIToolbox       0x903ec655 SendEventToEventTarget + 88
            23  com.apple.HIToolbox       0x9040c6c2 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 2392
            24  com.apple.HIToolbox       0x903d983f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2538
            25  com.apple.HIToolbox       0x903d8780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
            26  com.apple.HIToolbox       0x903ec655 SendEventToEventTarget + 88
            27  com.apple.HIToolbox       0x903cde77 SendTSMEvent + 75
            28  com.apple.HIToolbox       0x903cd90b SendUnicodeTextAEToUnicodeDoc + 745
            29  com.apple.HIToolbox       0x903cd504 TSMKeyEvent + 980
            30  com.apple.HIToolbox       0x9041cff5 TSMProcessRawKeyEvent + 3102
            31  com.apple.HIToolbox       0x9045dd15 HandleCompatibilityKeyEvent + 323
            32  com.apple.HIToolbox       0x903d58ba HIApplication::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 7318
            33  com.apple.HIToolbox       0x905519bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
            34  com.apple.HIToolbox       0x903d9394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
            35  com.apple.HIToolbox       0x903d8780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
            36  com.apple.HIToolbox       0x903d85ca SendEventToEventTargetWithOptions + 94
            37  com.apple.HIToolbox       0x9040c19c ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1074
            38  com.apple.HIToolbox       0x903d983f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2538
            39  com.apple.HIToolbox       0x903d8780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
            40  com.apple.HIToolbox       0x903ec655 SendEventToEventTarget + 88
            41  com.adobe.InDesign.AppFramework0x107272af 0x10725000 + 8879
            42  com.adobe.InDesign.AppFramework0x10744750 GetPlugIn + 10840
            43  com.adobe.InDesign        0x0000277b main + 115
            44  com.adobe.InDesign        0x0000209e start + 258
            45  com.adobe.InDesign        0x00001fc5 start + 41
            Thread 1:: Dispatch queue: com.apple.libdispatch-manager
            0   libsystem_kernel.dylib    0x9a7489ae kevent + 10
            1   libdispatch.dylib         0x9686bc71 _dispatch_mgr_invoke + 993
            2   libdispatch.dylib         0x9686b7a9 _dispatch_mgr_thread + 53
            Thread 2:
            0   libsystem_kernel.dylib    0x9a7478e2 __psynch_cvwait + 10
            1   libsystem_c.dylib         0x962f12e9 _pthread_cond_wait + 938
            2   libsystem_c.dylib         0x962f1572 pthread_cond_timedwait_relative_np + 47
            3   com.apple.CoreServices.CarbonCore0x91b836ad TSWaitOnConditionTimedRelative + 177
            4   com.apple.CoreServices.CarbonCore0x91acfb8b MPWaitOnQueue + 261
            5   PMRuntime.dylib           0x000129b3 GetAvailContiguous() + 165
            6   com.apple.CoreServices.CarbonCore0x91b56a7b PrivateMPEntryPoint + 68
            7   libsystem_c.dylib         0x962ec5b7 _pthread_start + 344
            8   libsystem_c.dylib         0x962d6d4e thread_start + 34
            Thread 3:
            0   libsystem_kernel.dylib    0x9a7457d2 mach_msg_trap + 10
            1   libsystem_kernel.dylib    0x9a744cb0 mach_msg + 68
            2   com.apple.CoreServices.CarbonCore0x91b8035b TS_exception_listener_thread + 89
            3   libsystem_c.dylib         0x962ec5b7 _pthread_start + 344
            4   libsystem_c.dylib         0x962d6d4e thread_start + 34
            Thread 4:
            1   libsystem_c.dylib         0x962f1280 _pthread_cond_wait + 833
            2   libsystem_c.dylib         0x96377095 pthread_cond_wait$UNIX2003 + 71
            3   com.apple.CoreServices.CarbonCore0x91b83492 TSWaitOnCondition + 128
            4   com.apple.CoreServices.CarbonCore0x91b8368e TSWaitOnConditionTimedRelative + 146
            5   com.apple.CoreServices.CarbonCore0x91acfb8b MPWaitOnQueue + 261
            6   AdobeACE                  0x0004a743 0x1a000 + 198467
            7   AdobeACE                  0x00049f71 0x1a000 + 196465
            8   com.apple.CoreServices.CarbonCore0x91b56a7b PrivateMPEntryPoint + 68
            9   libsystem_c.dylib         0x962ec5b7 _pthread_start + 344
            10  libsystem_c.dylib         0x962d6d4e thread_start + 34
            Thread 5:
            Thread 6:
            Thread 7:
            3   com.apple.Foundation      0x96c7a9b6 -[NSCondition waitUntilDate:] + 404
            4   com.apple.Foundation      0x96c7a7dd -[NSConditionLock lockWhenCondition:beforeDate:] + 282
            5   com.apple.Foundation      0x96c7fd10 -[NSConditionLock lockWhenCondition:] + 69
            6   PublicLib.dylib           0x0113f4e9 devtech_private::ZString::BackDoorGetUnicode(unsigned short*, unsigned long, bool) const + 397
            7   PublicLib.dylib           0x01133f5d devtech::ZString::GetInternalData(unsigned short const**, unsigned long*) const + 2503
            8   PublicLib.dylib           0x0113d100 devtech::ZString::GetInternalData(unsigned short const**, unsigned long*) const + 39786
            9   com.apple.Foundation      0x96c4c7c8 -[NSThread main] + 45
            10  com.apple.Foundation      0x96c4c74b __NSThread__main__ + 1396
            11  libsystem_c.dylib         0x962ec5b7 _pthread_start + 344
            12  libsystem_c.dylib         0x962d6d4e thread_start + 34
            Thread 8:
            2   libsystem_c.dylib         0x9637eaf0 pthread_cond_wait + 48
            3   TINthread.dylib           0x152eb7a5 ThreadUtils::ThreadPool::Dispatcher() + 277
            4   TINthread.dylib           0x152eb83f ThreadUtils::ThreadPool::ThreadProc(void*) + 17
            5   libsystem_c.dylib         0x962ec5b7 _pthread_start + 344
            6   libsystem_c.dylib         0x962d6d4e thread_start + 34
            Thread 9:
            0   libsystem_kernel.dylib    0x9a7458e6 mach_wait_until + 10
            1   libsystem_c.dylib         0x9637dc10 nanosleep + 375
            2   com.adobe.InDesign.Support for JavaScript0x1416fbff TerminateConnection + 238555
            3   com.adobe.InDesign.Support for JavaScript0x1416163d TerminateConnection + 179737
            4   com.adobe.InDesign.Support for JavaScript0x1416fce9 TerminateConnection + 238789
            Thread 10:
            0   libsystem_kernel.dylib    0x9a745826 semaphore_timedwait_trap + 10
            1   com.apple.CoreServices.CarbonCore0x91b56810 MPWaitOnSemaphore + 106
            2   MultiProcessor Support    0x22cad06b ThreadFunction(void*) + 77
            3   com.apple.CoreServices.CarbonCore0x91b56a7b PrivateMPEntryPoint + 68
            4   libsystem_c.dylib         0x962ec5b7 _pthread_start + 344
            5   libsystem_c.dylib         0x962d6d4e thread_start + 34
            Thread 11:
            Thread 12:
            Thread 13:
            0   libsystem_kernel.dylib    0x9a7480ee __workq_kernreturn + 10
            1   libsystem_c.dylib         0x962ef0ac _pthread_workq_return + 45
            2   libsystem_c.dylib         0x962eee79 _pthread_wqthread + 448
            3   libsystem_c.dylib         0x962d6d2a start_wqthread + 30
            Thread 14:
            Thread 15:
            Thread 0 crashed with X86 Thread State (32-bit):
              eax: 0x00000014  ebx: 0x0fe0d90f  ecx: 0x000001c4  edx: 0x00000000
              edi: 0x00000000  esi: 0x02e9d070  ebp: 0xbfffd4d8  esp: 0xbfffd440
               ss: 0x00000023  efl: 0x00010286  eip: 0x0fe0d54f   cs: 0x0000001b
               ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
              cr2: 0x00000000
            Logical CPU: 3
            Binary Images:
            0x1000 - 0x3fff +com.adobe.InDesign (5.0.3.662 - 5030) <934558B7-7DB8-45BB-9493-E5EA9E80FAEE> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Adobe InDesign CS3
            0x8000 - 0x8fff +InDesignModel (0) <40D79185-3619-4F05-82AE-68B9A4386725> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
            0xc000 - 0xcfff +InDesignModelAndUI (0) <B42DD96C-21E7-4933-8656-24339222F36B> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
               0x10000 -0x14fef +PMRuntime.dylib (1) <8456288B-55CD-4156-9E22-0526003C0A83> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/PMRuntime.dylib
               0x1a000 -   0x11afe7 +AdobeACE (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
              0x139000 -   0x5b7fff +AdobeAGM (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
              0x70d000 -   0x74cfff +AdobeARE (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
              0x756000 -   0x76ffff +AdobeBIB (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
              0x779000 -   0x79aff7 +AdobeBIBUtils (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
              0x7a7000 -   0xa0cfc7 +AdobeCoolType (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
              0xa89000 -   0xda5fef +AdobeMPS (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
              0xe1c000 -   0xe89fef +ObjectModelLib.dylib (1) <05CB4C4E-A973-45B8-84FA-287F24A2C4DA> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/ObjectModelLib.dylib
              0xeab000 -   0xedbfcf +DataBaseLib.dylib (1) <E9E5BDCB-F6EB-4ACA-878A-87EF825ECB5B> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/DataBaseLib.dylib
              0xeea000 -  0x137aff8 +PublicLib.dylib (1) <C5C5E7DF-4322-4C2D-BAF6-D8E00AA1C7E4> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/PublicLib.dylib
            0x1595000 -  0x15b9fea +AdobeAFL (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
            0x15d5000 -  0x1684fd7 +AdobeSVGExport (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
            0x16b7000 -  0x16bdfdf +com.adobe.AdobeCrashReporter (2.5 - 2.5.03072007) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
            0x16c3000 -  0x1f30fff +libicudata.dylib.34.0 (34) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/ICUData.framework/Versions/3.4/libicudata.dylib.34.0
            0x1f33000 -  0x1ff39fb +libicui18n.dylib.34.0 (34) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.4/libicui18n.dyl ib.34.0
            0x207b000 -  0x2143387 +libicuuc.dylib.34.0 (34) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.4/libicuuc.dylib.34.0
            0x2193000 -  0x220aff7 +libboost_regex-mt-1_33.dylib (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/libboost_regex-mt-1_33.dylib
            0x2264000 -  0x22abfc7 +com.adobe.adobe_caps (adobe_caps 0.0.120.0 - 0.0.120.0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
            0x22b1000 -  0x22edff7  com.apple.vmutils (4.2.1 - 108) <6918860D-B24F-356C-9374-025BFFEA66A3> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
            0x2307000 -  0x245fffd +WidgetBinLib.dylib (1) <5CE6C3B2-C5A5-4894-B72A-EB711B9AD299> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/WidgetBinLib.dylib
            0x256d000 -  0x26d8ff7 +AdobeOwl (1) <C917D2C5-55F5-4B51-ABCA-5AC6BBE781D8> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
            0x27a8000 -  0x27a9ffd  com.apple.textencoding.unicode (2.5 - 2.5) <4E2ABBEB-1F0D-3C06-BA0C-C3CEDDF17BD2> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
            0x27e5000 -  0x27f3fff  libSimplifiedChineseConverter.dylib (61) <60899F9C-A79F-3BC2-855E-DC5C78B98FEB> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
            0x2ff6000 -  0x2ffafff +com.adobe.InDesign.Data Services UI (5.0.0.458 - 0) <9A295EDB-5CEB-4081-9ADF-223F526A6034> /Applications/Adobe InDesign CS3/*/Data Services UI
            0x7596000 -  0x75c3ff3  com.apple.audio.CoreAudioKit (1.6.4 - 1.6.4) <5F0E55AF-BDA6-36B3-86F2-8A84A8F5D089> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
            0x77f1000 -  0x77f7ffd +com.adobe.InDesign.Data Services (5.0.0.458 - 0) <74B57DC9-3E39-44BF-B892-4A0262B836F1> /Applications/Adobe InDesign CS3/*/Data Services
            0xcd48000 -  0xcd5affd  libTraditionalChineseConverter.dylib (61) <519CAA3F-715E-3CAE-B158-57EC95D916B1> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
            0xcd5e000 -  0xcd61fff +com.adobe.InDesign.PNG Import Filter UI (5.0.0.458 - 0) <219F77F4-FB2C-4967-9D25-60C4198DB153> /Applications/Adobe InDesign CS3/*/PNG Import Filter UI
            0xcdb9000 -  0xcdbffc3 +CSLinguist.dylib (1) /Library/Application Support/Adobe/*/WRLiloPlugin1.0.bundle/Contents/SharedSupport/CSLinguist.dylib
            0xcdc5000 -  0xcdd0fe3 +com.adobe.InDesign.DTTransform (5.0.0.458 - 0) <35B9AEBF-242C-43AF-9935-348B718CC5A7> /Applications/Adobe InDesign CS3/*/DTTransform
            0xcdd8000 -  0xcdd9fff +com.adobe.InDesign.Help (5.0.0.458 - 0) <59C676A7-D46D-4BF8-A44B-5649E240AA35> /Applications/Adobe InDesign CS3/*/Help
            0xcdf7000 -  0xcdf8ff8  ATSHI.dylib (341.1) <7FD74F4D-E42A-30CB-8863-1832BFADFE5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
            0xcfc4000 -  0xcfe5ff7 +com.adobe.InDesign.Dictionary Editor Dialog (5.0.3.662 - 0) <16755191-AA6C-41EC-918C-008CA14DB9A7> /Applications/Adobe InDesign CS3/*/Dictionary Editor Dialog
            0xcffa000 -  0xcffcfff +com.adobe.InDesign.SimpleTextImportFilter (5.0.0.458 - 0) <AFC35B5D-6977-498F-A6C0-7378C24ADC69> /Applications/Adobe InDesign CS3/*/SimpleTextImportFilter
            0xe3ee000 -  0xe3f5ffc +com.adobe.InDesign.SaveBack (5.0.0.458 - 0) <D60DB5DD-9133-410D-AEED-96E225D0E4FE> /Applications/Adobe InDesign CS3/*/SaveBack
            0xe700000 -  0xe72afef +TextPanelLib.dylib (1) <47B64D3E-4DAF-4EEA-A02F-A7A52601B6CD> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/TextPanelLib.dylib
            0xe74d000 -  0xe769fe7 +com.adobe.InDesign.LILO (5.0.3.662 - 0) <36BA6BB5-EA76-4E84-AF8D-848801EDE21C> /Applications/Adobe InDesign CS3/*/LILO
            0xe776000 -  0xe801fdf +com.adobe.linguistic.LinguisticManager (3.1.3 - 3.1.3.5196) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
            0xe821000 -  0xe839fcb +com.adobe.InDesign.Media Import Filter (5.0.0.458 - 0) <A9690264-1641-415C-BBA2-C375E797A7C2> /Applications/Adobe InDesign CS3/*/Media Import Filter
            0xe842000 -  0xe859fff +com.adobe.InDesign.Sangam Preferences UI (5.0.0.458 - 0) <D884A939-E2F9-4D90-82DA-0119ADEC4802> /Applications/Adobe InDesign CS3/*/Sangam Preferences UI
            0xe866000 -  0xe8cafe4 +com.adobe.AdobeSangam (AdobeSangam 4.2 - 4.2.0.22) <8E741406-E3AC-48E9-AB85-7A17F88160BB> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
            0xe93c000 -  0xe98cfef +com.adobe.InDesign.SangamExport (5.0.0.458 - 0) <B232AC96-4293-430C-995A-D6D38F837D6C> /Applications/Adobe InDesign CS3/*/SangamExport
            0xe9ae000 -  0xea9bffb +com.adobe.InDesign.SangamServicer-Mapper (5.0.0.458 - 0) <9FBB1DFE-14A7-434E-94A5-CA2E7EB0309D> /Applications/Adobe InDesign CS3/*/SangamServicer-Mapper
            0xeae3000 -  0xeb4efc7 +com.adobe.InDesign.Tagged Text Attributes (5.0.0.458 - 0) <7891C8E0-A157-4C1F-B34E-A9A71E74DA36> /Applications/Adobe InDesign CS3/*/Tagged Text Attributes
            0xeb75000 -  0xeb80fff +com.adobe.InDesign.Tagged Text Filters UI (5.0.0.458 - 0) <07BBA8CB-F137-4516-B875-6541797DACA4> /Applications/Adobe InDesign CS3/*/Tagged Text Filters UI
            0xeb87000 -  0xec0afe7 +com.adobe.InDesign.Tagged Text Filters (5.0.3.662 - 0) <51B1F580-0FC8-431B-9B04-D81C437F7259> /Applications/Adobe InDesign CS3/*/Tagged Text Filters
            0xec18000 -  0xec1ffe7 +com.adobe.InDesign.Clipping Path Dialog (5.0.0.458 - 0) <6EC2FCEB-F6E9-41AE-8CBD-DD882CF36A83> /Applications/Adobe InDesign CS3/*/Clipping Path Dialog
            0xec28000 -  0xec4afff +com.adobe.InDesign.Color Management UI (5.0.0.458 - 0) <52D35082-41CB-4186-927F-12A69C7E90A5> /Applications/Adobe InDesign CS3/*/Color Management UI
            0xec55000 -  0xec9cfef +com.adobe.InDesign.Color Picker Panel (5.0.0.458 - 0) <9E669EF1-81DB-4240-B92C-764C2FBA1A58> /Applications/Adobe InDesign CS3/*/Color Picker Panel
            0xecb5000 -  0xecbcfef +com.adobe.InDesign.EPS UI (5.0.0.458 - 0) <DFE7643E-A510-47AB-810D-E8E094B45DF2> /Applications/Adobe InDesign CS3/*/EPS UI
            0xecc2000 -  0xecc8fe7 +com.adobe.InDesign.Generic Style Editor (5.0.0.458 - 0) <9F984289-52ED-4391-B49D-AA1A14FD69E4> /Applications/Adobe InDesign CS3/*/Generic Style Editor
            0xecd1000 -  0xecf1ff3 +com.adobe.InDesign.Gradient Panel (5.0.0.458 - 0) <8C4509AB-8290-4124-B33B-7664AADDA2DC> /Applications/Adobe InDesign CS3/*/Gradient Panel
            0xed00000 -  0xed41ff3 +com.adobe.InDesign.Graphic Panels (5.0.0.458 - 0) <ADC596C1-A326-4D9F-A330-B17892050B98> /Applications/Adobe InDesign CS3/*/Graphic Panels
            0xed59000 -  0xed5dfef +com.adobe.InDesign.JPEG Export UI (5.0.0.458 - 0) <BE6487F3-62A9-4889-BC0C-D9EC282365B5> /Applications/Adobe InDesign CS3/*/JPEG Export UI
            0xed63000 -  0xed7cfff +com.adobe.InDesign.JPEG Export (5.0.3.662 - 0) <BADB524B-D0B7-43F0-86A0-243195CA4065> /Applications/Adobe InDesign CS3/*/JPEG Export
            0xed8d000 -  0xedbcffb +com.adobe.InDesign.Output Preview (5.0.3.662 - 0) <D4AC4E3F-6DD5-45F1-B036-5B187957E6D1> /Applications/Adobe InDesign CS3/*/Output Preview
            0xedcd000 -  0xedd9fef +com.adobe.InDesign.OutputMiscUI (5.0.0.458 - 0) <BB613486-4008-40E8-99C3-5BDB31A02392> /Applications/Adobe InDesign CS3/*/OutputMiscUI
            0xede5000 -  0xee31feb +com.adobe.InDesign.PDF UI (5.0.0.458 - 0) <0AE9202C-D879-4AEB-9F76-415A21421BF4> /Applications/Adobe InDesign CS3/*/PDF UI
            0xee49000 -  0xee9effd +AdobeXMP (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
            0xeeac000 -  0xeeb9fff +com.adobe.InDesign.Printer Styles (5.0.0.458 - 0) <66BF4E9B-9AAA-4E59-BAC2-222F78A7A9AC> /Applications/Adobe InDesign CS3/*/Printer Styles
            0xeec2000 -  0xef60fef +com.adobe.InDesign.PrintUI (5.0.0.458 - 0) <B9E289D4-F24D-4215-8F37-EED83FCC42A9> /Applications/Adobe InDesign CS3/*/PrintUI
            0xef96000 -  0xef9ffef +com.adobe.InDesign.PS Import UI (5.0.0.458 - 0) <16038163-C648-4332-8CC6-02C31913BAAD> /Applications/Adobe InDesign CS3/*/PS Import UI
            0xefa8000 -  0xefaeff7 +com.adobe.InDesign.SVG Export UI (5.0.0.458 - 0) <01BBCFBC-A0E4-4593-8D17-D337DF0022CF> /Applications/Adobe InDesign CS3/*/SVG Export UI
            0xefb4000 -  0xf039fff +com.adobe.InDesign.SVG Export (5.0.0.458 - 0) <F1A1DFCA-22A2-4EBC-9BB9-05014D447CD0> /Applications/Adobe InDesign CS3/*/SVG Export
            0xf066000 -  0xf078fff +com.adobe.InDesign.Swatch Library Panel (5.0.0.458 - 0) <EEE63A20-73E7-430E-BF01-86BE03DA7B6B> /Applications/Adobe InDesign CS3/*/Swatch Library Panel
            0xf080000 -  0xf0ddff7 +com.adobe.InDesign.Swatches Panel (5.0.0.458 - 0) <56EBE10D-2DC0-4FA7-B070-286D676158B0> /Applications/Adobe InDesign CS3/*/Swatches Panel
            0xf0fa000 -  0xf159ffb +com.adobe.InDesign.Transparency UI (5.0.0.458 - 0) <4AE9180A-FF7A-4B57-9201-A456B7EF89B2> /Applications/Adobe InDesign CS3/*/Transparency UI
            0xf179000 -  0xf1adff3 +com.adobe.InDesign.Assignment UI (5.0.0.458 - 0) <F6A8746C-9B69-4976-8E68-DB324E27E387> /Applications/Adobe InDesign CS3/*/Assignment UI
            0xf1c2000 -  0xf1d3fc7 +com.adobe.InDesign.InCopy Bridge UI (5.0.0.458 - 0) <2F896ACD-EEA3-4CB2-95C5-AF85352EF339> /Applications/Adobe InDesign CS3/*/InCopy Bridge UI
            0xf1da000 -  0xf1feff7 +com.adobe.InDesign.InCopy Bridge (5.0.3.662 - 0) <118ACCF3-8E0E-414F-9CB3-711B598E9342> /Applications/Adobe InDesign CS3/*/InCopy Bridge
            0xf20a000 -  0xf20efeb +com.adobe.InDesign.InCopyExport (5.0.0.458 - 0) <0F2363BB-C116-4132-B79D-71FC78AA140C> /Applications/Adobe InDesign CS3/*/InCopyExport
            0xf214000 -  0xf218fff +com.adobe.InDesign.InCopyExportUI (5.0.0.458 - 0) <77C291BC-EF06-43EB-827C-50769B3C3890> /Applications/Adobe InDesign CS3/*/InCopyExportUI
            0xf21e000 -  0xf22300e +com.adobe.InDesign.InCopyImport (5.0.0.458 - 0) <DB270045-C915-4D59-96DE-22BDAE988898> /Applications/Adobe InDesign CS3/*/InCopyImport
            0xf228000 -  0xf22cfff +com.adobe.InDesign.InCopyWorkflow UI (5.0.0.458 - 0) <6955319C-2E61-413B-A4BE-6F0D2583D10B> /Applications/Adobe InDesign CS3/*/InCopyWorkflow UI
            0xf232000 -  0xf264feb +com.adobe.InDesign.Note (5.0.0.458 - 0) <A274D200-D554-4003-84BF-365B89216A93> /Applications/Adobe InDesign CS3/*/Note
            0xf278000 -  0xf27fff6 +com.adobe.InDesign.NotePref (5.0.0.458 - 0) <93AF7AF8-5C16-4C42-98D0-A4F7CC1CA713> /Applications/Adobe InDesign CS3/*/NotePref
            0xf28a000 -  0xf28cfff +com.adobe.InDesign.Username UI (5.0.0.458 - 0) <7946FF7E-3349-498D-93F5-1F0D51D25707> /Applications/Adobe InDesign CS3/*/Username UI
            0xf292000 -  0xf2befe3 +com.adobe.InDesign.BehaviorUI (5.0.0.458 - 0) <48EE4200-9EE9-4CCA-9803-C7656C9C4C89> /Applications/Adobe InDesign CS3/*/BehaviorUI
            0xf2d3000 -  0xf2f6fef +com.adobe.InDesign.FormFieldUI (5.0.0.458 - 0) <9A08E8F7-0E6A-42C4-AD70-0450F43DDB1A> /Applications/Adobe InDesign CS3/*/FormFieldUI
            0xf30a000 -  0xf31fff3 +com.adobe.InDesign.MediaUI (5.0.0.458 - 0) <BCBB8E8F-066F-4145-9E05-1D7319C69C6C> /Applications/Adobe InDesign CS3/*/MediaUI
            0xf32b000 -  0xf33406f +com.adobe.InDesign.Alignment Panel (5.0.0.458 - 0) <4DCFC50C-0539-45A8-B31A-110E269B1E56> /Applications/Adobe InDesign CS3/*/Alignment Panel
            0xf33a000 -  0xf360ff7 +com.adobe.InDesign.Asset Library Panel (5.0.0.458 - 0) <CBE05090-A4BD-47A4-BC63-A5E8DF5EA954> /Applications/Adobe InDesign CS3/*/Asset Library Panel
            0xf376000 -  0xf3b4feb +com.adobe.InDesign.Asset PubLibrary (5.0.0.458 - 0) <5AC83352-A68B-4D23-BA8B-2758AD4994B6> /Applications/Adobe InDesign CS3/*/Asset PubLibrary
            0xf3c8000 -  0xf3f2fe3 +com.adobe.InDesign.Book Panel (5.0.0.458 - 0) <5A3B41C3-C92C-4BC0-9374-29D727C5DB0A> /Applications/Adobe InDesign CS3/*/Book Panel
            0xf406000 -  0xf415fff +com.adobe.InDesign.Bookmark Panel (5.0.0.458 - 0) <7C19089F-6F87-44A8-AAAC-48BFE95E8340> /Applications/Adobe InDesign CS3/*/Bookmark Panel
            0xf422000 -  0xf443ffb +com.adobe.InDesign.Control Panel (5.0.0.458 - 0) <E7BFB649-A78D-4662-A286-C0781B7F52C3> /Applications/Adobe InDesign CS3/*/Control Panel
            0xf453000 -  0xf458fff +com.adobe.InDesign.Create Guides Dialog (5.0.0.458 - 0) <729142B6-15CB-4EEA-8733-F6FA07B99EF2> /Applications/Adobe InDesign CS3/*/Create Guides Dialog
            0xf45e000 -  0xf484fff +com.adobe.InDesign.Eyedropper Tool (5.0.0.458 - 0) <2535B820-564C-4C39-B27A-88E1535953B2> /Applications/Adobe InDesign CS3/*/Eyedropper Tool
            0xf492000 -  0xf4c9fcf +com.adobe.InDesign.Hyperlinks Panel (5.0.0.458 - 0) <3EE1A146-D8FE-4559-B808-D0089BF10448> /Applications/Adobe InDesign CS3/*/Hyperlinks Panel
            0xf4dc000 -  0xf519fe7 +com.adobe.InDesign.Index Panel (5.0.0.458 - 0) <A4E8B0AD-35F2-44FE-83F8-EB92F029B2A1> /Applications/Adobe InDesign CS3/*/Index Panel
            0xf52c000 -  0xf561feb +com.adobe.InDesign.Info Panel (5.0.0.458 - 0) <ECDFE5E2-C8DA-4467-A887-1A6E86405CCB> /Applications/Adobe InDesign CS3/*/Info Panel
            0xf572000 -  0xf5c9ffe +com.adobe.InDesign.Knowledge Base (5.0.0.458 - 0) <A9DD1BD0-11E0-4BE0-BF4E-A7CFD6EDE2C8> /Applications/Adobe InDesign CS3/*/Knowledge Base
            0xf5de000 -  0xf5fdfff +com.adobe.InDesign.Layers Panel (5.0.0.458 - 0) <BBF94334-3847-4986-BA31-77CAC4098878> /Applications/Adobe InDesign CS3/*/Layers Panel
            0xf60d000 -  0xf60ffe7 +com.adobe.InDesign.Layout Adjustment Panel (5.0.0.458 - 0) <0051EC6E-8721-4CCE-9EE7-183BE332A566> /Applications/Adobe InDesign CS3/*/Layout Adjustment Panel
            0xf615000 -  0xf626fff +com.adobe.InDesign.Layout Adjustment (5.0.0.458 - 0) <5AFF3870-C739-4809-AC10-698FA2F8A477> /Applications/Adobe InDesign CS3/*/Layout Adjustment
            0xf62f000 -  0xf677fff +com.adobe.InDesign.Links Panel (5.0.0.458 - 0) <AA77F9D7-4D11-43FD-B74D-2464EDC391E5> /Applications/Adobe InDesign CS3/*/Links Panel
            0xf69a000 -  0xf6affff +com.adobe.InDesign.Navigator Panel (5.0.0.458 - 0) <DC1A41DE-1496-459A-AEC7-E5B2015DC5BB> /Applications/Adobe InDesign CS3/*/Navigator Panel
            0xf6bd000 -  0xf71cff7 +com.adobe.InDesign.ObjectStylesUI (5.0.0.458 - 0) <60B2DF59-3AE3-4621-93A2-FEA00D4FB356> /Applications/Adobe InDesign CS3/*/ObjectStylesUI
            0xf739000 -  0xf74cfeb +com.adobe.InDesign.Page Setup Dialog (5.0.0.458 - 0) <B7C99FC8-A354-459F-BD69-9DA89C5668CD> /Applications/Adobe InDesign CS3/*/Page Setup Dialog
            0xf753000 -  0xf7affef +com.adobe.InDesign.Pages Panel (5.0.0.458 - 0) <CC82F2DE-CE0B-4B33-B19F-270899D413AD> /Applications/Adobe InDesign CS3/*/Pages Panel
            0xf7c9000 -  0xf7d1fff +com.adobe.InDesign.Sections UI (5.0.0.458 - 0) <00E5FB32-30B7-489A-AE52-D5E07512ABD9> /Applications/Adobe InDesign CS3/*/Sections UI
            0xf7d7000 -  0xf7dbfff +com.adobe.InDesign.StepRepeat (5.0.3.662 - 0) <28C98507-6B14-4600-86D5-523DEFF404C2> /Applications/Adobe InDesign CS3/*/StepRepeat
            0xf7e2000 -  0xf80bff7 +com.adobe.InDesign.Text Wrap Panel (5.0.3.662 - 0) <4FB1A1FF-9FD3-43DA-B22B-A3C3CDDE48CE> /Applications/Adobe InDesign CS3/*/Text Wrap Panel
            0xf81b000 -  0xf83ffff +com.adobe.InDesign.TOC UI Dialog (5.0.0.458 - 0) <B8E6A83A-FF73-453B-82FB-222EBEEB830F> /Applications/Adobe InDesign CS3/*/TOC UI Dialog
            0xf84e000 -  0xf86afff +com.adobe.InDesign.Transform Panel (5.0.0.458 - 0) <DDEF092A-D5F5-4060-A589-B03C9BBDF052> /Applications/Adobe InDesign CS3/*/Transform Panel
            0xf876000 -  0xf887ff3 +com.adobe.InDesign.Image Import UI (5.0.0.458 - 0) <A06818D0-6F36-49A8-A92F-FDCD3321C466> /Applications/Adobe InDesign CS3/*/Image Import UI
            0xf892000 -  0xf89fff2 +com.adobe.InDesign.Scotch Rules (5.0.0.458 - 0) <07E253C0-4878-4CFD-8C7E-E57435DBAAFB> /Applications/Adobe InDesign CS3/*/Scotch Rules
            0xf8a6000 -  0xf8d7ffb +com.adobe.InDesign.BNUI (5.0.0.458 - 0) <E1728ECE-0E11-463E-98AA-82F47FEB528F> /Applications/Adobe InDesign CS3/*/BNUI
            0xf8ec000 -  0xf8f3fff +com.adobe.InDesign.CropTool (5.0.0.458 - 0) <E7CA52B1-4EE9-4158-A275-1319ADEFF1FD> /Applications/Adobe InDesign CS3/*/CropTool
            0xf8fb000 -  0xf967fff +com.adobe.InDesign.DataMerge (5.0.3.662 - 0) <1EEB0DCE-4CB0-4F88-ABA3-49B271CAFEE1> /Applications/Adobe InDesign CS3/*/DataMerge
            0xf991000 -  0xf9aeff7 +com.adobe.InDesign.DataMergeUI (5.0.0.458 - 0) <D5A1FEE2-E803-4A65-853E-62CA36E172A5> /Applications/Adobe InDesign CS3/*/DataMergeUI
            0xf9bf000 -  0xf9cd05f +com.adobe.InDesign.PMToolBar (5.0.0.458 - 0) <01EFA9E7-5891-4CAE-A0E1-E1BCC7270045> /Applications/Adobe InDesign CS3/*/PMToolBar
            0xf9d8000 -  0xf9e5ff2 +com.adobe.InDesign.PMWelcomeScreen (5.0.0.458 - 0) <D235E4C3-BBCF-40A3-88B2-3E91C664269D> /Applications/Adobe InDesign CS3/*/PMWelcomeScreen
            0xf9f2000 -  0xf9f6fd8  com.apple.carbonframeworktemplate (1.1 - 1.1.0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
            0xf9fb000 -  0xfa2cfef +com.adobe.InDesign.Package and Preflight UI (5.0.0.458 - 0) <9C7AC64E-8372-4590-952B-F72B5AD479AD> /Applications/Adobe InDesign CS3/*/Package and Preflight UI
            0xfa3f000 -  0xfa8ffef +com.adobe.InDesign.Package and Preflight (5.0.3.662 - 0) <F7EA9D0C-78BD-4C6E-8FB9-C756C6F051F3> /Applications/Adobe InDesign CS3/*/Package and Preflight
            0xfa98000 -  0xfabbff6 +AdobeAXE8SharedExpat (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
            0xfac3000 -  0xfb89fef +com.adobe.InDesign.JBX (5.0.0.458 - 0) <16ABA433-3F98-465D-B35B-AA6AAF5B48A4> /Applications/Adobe InDesign CS3/*/JBX
            0xfbcd000 -  0xfbd0fff +com.adobe.InDesign.Script Label Panel (5.0.0.458 - 0) <0A69FDDC-C3A6-4356-BC47-0A255E91675B> /Applications/Adobe InDesign CS3/*/Script Label Panel
            0xfbd7000 -  0xfbdeff3 +com.adobe.InDesign.Scripts Panel (5.0.0.458 - 0) <E40BF92F-6275-4C9F-BF25-2016C5021CFD> /Applications/Adobe InDesign CS3/*/Scripts Panel
            0xfbe6000 -  0xfc73fe7 +com.adobe.InDesign.Tables UI (5.0.0.458 - 0) <20BE7B63-0947-45E7-BD3F-8E332E701D5F> /Applications/Adobe InDesign CS3/*/Tables UI
            0xfc96000 -  0xfcf7ffb +com.adobe.InDesign.TableStylesUI (5.0.0.458 - 0) <0E2577DB-0D37-450A-B63E-67BD3B36BD26> /Applications/Adobe InDesign CS3/*/TableStylesUI
            0xfd16000 -  0xfd5304b +com.adobe.InDesign.Character Panel (5.0.3.662 - 0) <87BC3F60-7F4B-4457-99AB-646FAA427EDE> /Applications/Adobe InDesign CS3/*/Character Panel
            0xfd6d000 -  0xfd7dfff +com.adobe.InDesign.Create Outlines (5.0.0.458 - 0) <C7D6CA71-EF03-4A40-8E3A-C3123E8335B7> /Applications/Adobe InDesign CS3/*/Create Outlines
            0xfd85000 -  0xfe31fef +com.adobe.InDesign.Find and Change Panel (5.0.3.662 - 0) <1D76D5B0-373B-492E-8FA6-DB13D6EA7DDF> /Applications/Adobe InDesign CS3/*/Find and Change Panel
            0xfe5d000 -  0xfe7cfe7 +com.adobe.InDesign.Find Change Format Panel (5.0.0.458 - 0) <7671FB52-74A6-4DFF-B1BE-B54E1A8FB313> /Applications/Adobe InDesign CS3/*/Find Change Format Panel
            0xfe87000 -  0xfe9e01f +com.adobe.InDesign.Font Usage Dialog (5.0.0.458 - 0) <C10CFFAE-C33D-4F8A-A174-9334C975953A> /Applications/Adobe InDesign CS3/*/Font Usage Dialog
            0xfea9000 -  0xff08ffb +com.adobe.InDesign.Glyphs Panel (5.0.0.458 - 0) <7E2FECBE-E228-4F60-B315-0A07EAB77612> /Applications/Adobe InDesign CS3/*/Glyphs Panel
            0xff1e000 -  0xff23fef +com.adobe.InDesign.Hyphenation Panel (5.0.0.458 - 0) <A18BA408-B78C-41C7-966E-F000F8F6F914> /Applications/Adobe InDesign CS3/*/Hyphenation Panel
            0xff2c000 -  0xff36fff +com.adobe.InDesign.Indents and Tabs (5.0.0.458 - 0) <A2E4E50D-050C-4273-8EAB-57672EAD1644> /Applications/Adobe InDesign CS3/*/Indents and Tabs
            0xff3f000 -  0xff44fff +com.adobe.InDesign.Justification Panel (5.0.0.458 - 0) <8A6E8BE4-2F92-4D6D-B4B1-6C51C751E859> /Applications/Adobe InDesign CS3/*/Justification Panel
            0xff4a000 -  0xff4eff7 +com.adobe.InDesign.Keeps Panel (5.0.0.458 - 0) <CDB33F72-0447-42FE-81EC-D0799FB2CD6E> /Applications/Adobe InDesign CS3/*/Keeps Panel
            0xff53000 -  0xff6cff3 +com.adobe.InDesign.Optical Kerning (5.0.0.458 - 0) <B0780089-D891-4294-9881-8237BB949911> /Applications/Adobe InDesign CS3/*/Optical Kerning
            0xff75000 -  0xff8dfef +com.adobe.InDesign.Paragraph Panel (5.0.0.458 - 0) <EFD65207-5E95-456F-8E6F-3D70B5367C4E> /Applications/Adobe InDesign CS3/*/Paragraph Panel
            0xff99000 -  0xffa2fff +com.adobe.InDesign.Paragraph Rules Panel (5.0.0.458 - 0) <C3BD8CD8-9B50-4241-9499-56BEE7C8C8A5> /Applications/Adobe InDesign CS3/*/Paragraph Rules Panel
            0xffa9000 -  0xffb7fff +com.adobe.InDesign.Path Type UI (5.0.0.458 - 0) <B464FA77-E6AF-476E-8AE1-7E98B158DF14> /Applications/Adobe InDesign CS3/*/Path Type UI
            0xffc1000 -  0xffc9ffc +PathTypeLib.dylib (1) <18C15E31-C72D-4EEA-8452-2444772CFC43> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/PathTypeLib.dylib
            0xffd0000 -  0xffdcfe7 +com.adobe.InDesign.RunIn Styles Panel (5.0.0.458 - 0) <DBEE6188-6AF7-4366-A800-77D5CC719BEE> /Applications/Adobe InDesign CS3/*/RunIn Styles Panel
            0xffe6000 -  0xfff6fff +com.adobe.InDesign.SING (5.0.0.458 - 0) <101E0AF3-FCAF-4902-8E7E-331A176E61DD> /Applications/Adobe InDesign CS3/*/SING
            0xffff000 - 0x10026fe3 +com.adobe.InDesign.Spelling Panel (5.0.0.458 - 0) <56460421-FF84-45E6-92AA-43626E38B270> /Applications/Adobe InDesign CS3/*/Spelling Panel
            0x10038000 - 0x10041fef +com.adobe.InDesign.Story Panel (5.0.0.458 - 0) <8BE56D0B-F057-455C-BC0C-A596BE9D2DA6> /Applications/Adobe InDesign CS3/*/Story Panel
            0x10049000 - 0x10082fff +com.adobe.InDesign.Style Panel (5.0.0.458 - 0) <CBFB03D6-5E53-46FA-BB0D-9E7AA49727A1> /Applications/Adobe InDesign CS3/*/Style Panel
            0x1009c000 - 0x100a2feb +com.adobe.InDesign.Text Color Panel (5.0.0.458 - 0) <072591AA-A2E0-44CA-8982-056229E9598A> /Applications/Adobe InDesign CS3/*/Text Color Panel
            0x100a7000 - 0x100bbff3 +com.adobe.InDesign.Text Frame Options (5.0.0.458 - 0) <EA8842D0-DABF-4980-83C4-4507A204C3D8> /Applications/Adobe InDesign CS3/*/Text Frame Options
            0x100c6000 - 0x100f6fff +com.adobe.InDesign.Text Panel (5.0.0.458 - 0) <4DDA3134-B6AC-45D0-B61E-DE2C1773E545> /Applications/Adobe InDesign CS3/*/Text Panel
            0x10108000 - 0x1011904b +com.adobe.InDesign.Text Preferences (5.0.0.458 - 0) <EB96C5F6-B8BE-4FB3-B237-D6164EE82930> /Applications/Adobe InDesign CS3/*/Text Preferences
            0x10123000 - 0x10138fff +com.adobe.InDesign.Text Ruler (5.0.0.458 - 0) <76836CAF-DF72-48FD-BC22-AB712DEDBB18> /Applications/Adobe InDesign CS3/*/Text Ruler
            0x10142000 - 0x1014ffff +com.adobe.InDesign.Text Style Panel (5.0.0.458 - 0) <F6F81FD7-63CA-4FB2-90B4-EC9E5BEE2177> /Applications/Adobe InDesign CS3/*/Text Style Panel
            0x10157000 - 0x102d4ffb +com.adobe.InDesign.Text Walker (5.0.0.458 - 0) <04A3777D-DC3E-4DB8-9B73-7848892730A1> /Applications/Adobe InDesign CS3/*/Text Walker
            0x1036b000 - 0x10385ff3 +com.adobe.InDesign.Galley Preferences (5.0.0.458 - 0) <04484DC8-FF4B-40CB-8841-B42A76CF3BF5> /Applications/Adobe InDesign CS3/*/Galley Preferences
            0x10395000 - 0x1039afef +com.adobe.InDesign.General Preferences Panel (5.0.0.458 - 0) <97415234-1B28-4D38-8A96-E19DDDF95DE6> /Applications/Adobe InDesign CS3/*/General Preferences Panel
            0x103a0000 - 0x103adffb +com.adobe.InDesign.Performance UI (5.0.0.458 - 0) <4F3DE808-3ADE-4B7D-B292-DCD3DF5D7103> /Applications/Adobe InDesign CS3/*/Performance UI
            0x103b9000 - 0x103cafff +com.adobe.InDesign.Shortcut Editor Dialog (5.0.0.458 - 0) <FD95270C-FF81-4FF6-BE64-10ADAE2ED53F> /Applications/Adobe InDesign CS3/*/Shortcut Editor Dialog
            0x103d4000 - 0x103dfff7 +com.adobe.InDesign.Tool Box (5.0.0.458 - 0) <9D3C3D9F-933B-4C8F-B378-A7804711C6A4> /Applications/Adobe InDesign CS3/*/Tool Box
            0x103e9000 - 0x103f0feb +com.adobe.InDesign.Tool Tips (5.0.0.458 - 0) <4B227DB1-BCC1-4A6C-A703-CE507D59F6BF> /Applications/Adobe InDesign CS3/*/Tool Tips
            0x103f9000 - 0x10414fff +com.adobe.InDesign.Plugin Manager (5.0.0.458 - 0) <6D0D804D-2F29-46BC-BF82-ED25ABB6086B> /Applications/Adobe InDesign CS3/*/Plugin Manager
            0x10423000 - 0x10435ffd +com.adobe.InDesign.Metadata UI (5.0.0.458 - 0) <A99A4A16-A956-498D-B742-1E2761E80487> /Applications/Adobe InDesign CS3/*/Metadata UI
            0x10440000 - 0x104f6fcc +FileInfo (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
            0x10524000 - 0x10529fff +com.adobe.InDesign.Workgroup UI (5.0.3.662 - 0) <7713F6A6-73BD-4950-BE33-A633D29EE0B5> /Applications/Adobe InDesign CS3/*/Workgroup UI
            0x1052e000 - 0x1055cfef +com.adobe.InDesign.Snippet (5.0.0.458 - 0) <F5B61D86-528B-4993-8C23-E9B06DB32979> /Applications/Adobe InDesign CS3/*/Snippet
            0x1056a000 - 0x10658fff +com.adobe.InDesign.XMedia UI (5.0.3.662 - 0) <ED5A265D-DC74-4943-A19C-2AE786C99D06> /Applications/Adobe InDesign CS3/*/XMedia UI
            0x106be000 - 0x10709fdf +com.adobe.InDesign.Actions (5.0.0.458 - 0) <6B80AA4C-EFB8-4E46-BA47-1E14791702F7> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
            0x10725000 - 0x1084afe3 +com.adobe.InDesign.AppFramework (5.0.3.662 - 0) <32293AA8-DA9B-4B05-AF72-B74BEF5BE4ED> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
            0x108b6000 - 0x10a39fef +com.adobe.InDesign.Application UI (5.0.3.662 - 0) <5F2CD8E2-39F2-4302-86AD-13F54ADDD6A5> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
            0x10ac6000 - 0x10b4bfff +AdobeExtendScript (3.7) <EF6B3A34-C43A-45D3-BCD3-D7D450B5C6CD> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
            0x10b87000 - 0x10c03fef +AdobeScCore (3.7) <17A0DA14-E4D4-42B0-81B4-B75E4CB2DD8C> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
            0x10c41000 - 0x10c9dfff +com.adobe.InDesign.Assignments (5.0.0.458 - 0) <D4826E20-6A7D-468C-A000-B1D7AF126C22> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
            0x10cc4000 - 0x10d0dffb +com.adobe.InDesign.AWS (5.0.0.458 - 0) <3CC41036-743E-4B6D-A6AB-743D69A85613> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
            0x10d2e000 - 0x10d60ff7 +com.adobe.InDesign.AWSUI (5.0.0.458 - 0) <C2460D67-B740-41E6-8C4C-CD97929F158F> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
            0x10d7b000 - 0x10d9fff3 +com.adobe.InDesign.Basic Tools (5.0.0.458 - 0) <8E39B721-DB99-4577-ADB9-BA32A7C11822> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Basic Tools.InDesignPlugin/Basic Tools
            0x10db1000 - 0x10ddaff3 +com.adobe.InDesign.Behavior (5.0.0.458 - 0) <895A9202-2E6A-43CC-BAF3-D814F261695C> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
            0x10df0000 - 0x10e50fff +com.adobe.InDesign.BNCore (5.0.0.458 - 0) <F425FD82-7BBA-45E4-90F8-61DB5F5A91A9> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
            0x10e66000 - 0x10e9dff7 +com.adobe.InDesign.Book (5.0.0.458 - 0) <A67FE031-3654-4DF2-8117-219C9829B264> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
            0x10eab000 - 0x10eccffb +com.adobe.InDesign.CellStyles.rpln (5.0.0.458 - 0) <0BE3E0A6-0ED8-489C-B886-C4C9F8AFD184> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/CellStyles.rpln.InDesignPlugin/CellStyles.rpln
            0x10ed9000 - 0x10f32fef +com.adobe.InDesign.CJK Text Attributes (5.0.0.458 - 0) <DCE49BEA-5BE0-4156-BE7F-147494C71A5F> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
            0x10f4b000 - 0x10f9afeb +com.adobe.InDesign.CJKGrid (5.0.3.662 - 0) <E1D6C839-AB72-4A96-8E67-1A62C128BEB7> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
            0x10fae000 - 0x1104fffb +com.adobe.InDesign.Color Management (5.0.0.458 - 0) <D0F8049B-EB18-44BC-AB25-22F1595F3247> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
            0x1107a000 - 0x110b3fef +com.adobe.InDesign.CompFontMgr (5.0.3.662 - 0) <C547BB1D-628B-4BFF-A315-995A7AF84AD6> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
            0x110c3000 - 0x110e3ffb +com.adobe.InDesign.Dialog Layout (5.0.0.458 - 0) <4B8B24B4-5CD3-44C7-9131-EBDF292A07BC> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Dialog Layout.InDesignPlugin/Dialog Layout
            0x110f4000 - 0x11108fef +com.adobe.InDesign.Document Actions (5.0.0.458 - 0) <495400EB-B390-4A66-9B6D-81C0A841058F> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
            0x11110000 - 0x11219fdf +com.adobe.InDesign.Document Framework (5.0.3.662 - 0) <C7393400-C07D-4FF5-AC6D-0D8360101392> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
            0x1123e000 - 0x11243fef +com.adobe.InDesign.Document UI (5.0.3.662 - 0) <F0D6F2FA-B15E-4538-AF6C-258FD532D703> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Document UI.InDesignPlugin/Document UI
            0x11249000 - 0x112e7fcf +com.adobe.InDesign.EPS Page Item (5.0.0.458 - 0) <B94445DF-2DCE-42AE-9D5B-CD37E0FB5D3C> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
            0x11309000 - 0x113adfeb +com.adobe.InDesign.Font Manager (5.0.3.662 - 0) <1149F2CB-682E-4B96-ADD1-78D2B43953AF> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
            0x113c2000 - 0x11421fff +com.adobe.InDesign.FormField (5.0.0.458 - 0) <423AA6D9-1ACF-4819-8806-BA5B7343B7F3> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
            0x1144a000 - 0x1155bff7 +com.adobe.InDesign.Galley (5.0.3.662 - 0) <6F2E05D4-DBF9-4798-87ED-500E65DD46A3> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
            0x115a7000 - 0x116b7ffb +com.adobe.InDesign.Generic Page Item (5.0.3.662 - 0) <AFBDF0F3-30F0-4AFF-AFB1-2C6F0C050F26> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
            0x116ec000 - 0x116f2ff7 +com.adobe.InDesign.GenericSettings (5.0.0.458 - 0) <0B8E02A0-5809-4DC7-B773-3F6B8B1B2048> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
            0x116f8000 - 0x116f9fff +com.adobe.InDesign.Global Preferences Panel (5.0.0.458 - 0) <693EF424-C046-4F46-B986-0F363C59468B> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
            0x116fd000 - 0x1173efef +com.adobe.InDesign.Gradient Fill (5.0.0.458 - 0) <F4F2DFF0-5C9D-49C4-A651-0F1F02A9428F> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
            0x11751000 - 0x117d5feb +com.adobe.InDesign.Graphics (5.0.3.662 - 0) <008237F3-BEE7-4CF1-B66C-0F847D3359A2> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
            0x117f1000 - 0x117f7fef +com.adobe.InDesign.Group (5.0.0.458 - 0) <E2AF24EB-31F4-404F-8D0A-C65BAAB62D6B> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
            0x117fe000 - 0x1180efff +com.adobe.InDesign.Guides (5.0.3.662 - 0) <B57B05D2-F646-4D72-AA27-24673A634EFC> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
            0x11818000 - 0x11873ffb +com.adobe.InDesign.Hyperlinks (5.0.0.458 - 0) <1359AA1D-E4EA-4BF7-8D8F-7BCA8AB2AB61> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
            0x11887000 - 0x118d0fc3 +com.adobe.InDesign.Image Filters (5.0.3.662 - 0) <53264B65-17E3-412A-9A0D-6CB5BD116E89> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
            0x118d8000 - 0x119aeffb +com.adobe.InDesign.Image (5.0.3.662 - 0) <45716586-0767-48CB-9E18-1D2B483E033D> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
            0x119f3000 - 0x11a05ff3 +com.adobe.InDesign.IME (5.0.3.662 - 0) <B61130D3-1C20-4ADE-B4CB-2F2AB58BD590> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
            0x11a0f000 - 0x11a3bff7 +com.adobe.InDesign.Import Export UI (5.0.0.458 - 0) <0D90A717-9DF4-4DF0-9F1C-9EEA4889E11C> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
            0x11a56000 - 0x11b0bff7 +com.adobe.InDesign.InCopyShared (5.0.3.662 - 0) <6A5EB84E-2E05-4444-80FA-217772B844DE> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
            0x11b51000 - 0x11b57fff +com.adobe.InDesign.InCopySharedUI (5.0.0.458 - 0) <322B8FCA-C43A-4B73-93EA-0B44B4B82640> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/InCopySharedUI.InDesignPlugin/InCopySharedUI
            0x11b5f000 - 0x11bf1ff7 +com.adobe.InDesign.InCopyWorkflow (5.0.0.458 - 0) <6639A154-67A2-4BD0-A74C-C607BCF4DC0A> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
            0x11c33000 - 0x11cecfe1 +com.adobe.InDesign.Indexing (5.0.3.662 - 0) <DCB29360-84FF-4CDA-8F4B-01782253D04A> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
            0x11d24000 - 0x11d6cfef +com.adobe.InDesign.INXCore (5.0.3.662 - 0) <BB334DD4-3916-4E57-B810-CF6A1DB64D7C> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
            0x11d7f000 - 0x11d96fff +com.adobe.InDesign.Layer (5.0.0.458 - 0) <CBAE5E62-4ECC-44C2-AFFB-8C0425D6E75D> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
            0x11da2000 - 0x11eb6fe7 +com.adobe.InDesign.Layout UI (5.0.3.662 - 0) <0AA2D873-FD6B-4D3E-BB25-0F32090471AA> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
            0x11f1f000 - 0x11f34fff +com.adobe.InDesign.Layout (5.0.3.662 - 0) <987B619E-E374-4A9D-B454-4BEDC99A2C42> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
            0x11f3e000 - 0x11f86ffb +com.adobe.InDesign.Linguistics (5.0.3.662 - 0) <22BEB69E-E7E9-4BB9-B618-9B739B3C0948> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
            0x11fa9000 - 0x12037fef +com.adobe.InDesign.Links (5.0.3.662 - 0) <9FC1F48D-8E7C-4CB4-B57E-6DAE21CCADDD> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
            0x1206a000 - 0x120aeffb +com.adobe.InDesign.Master Page (5.0.3.662 - 0) <CEFFC434-A035-43C8-BE24-2CE054991269> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
            0x120bf000 - 0x120dcfff +com.adobe.InDesign.Media (5.0.0.458 - 0) <171C2E82-1AB9-40C8-8BBA-13C6FFEBAA8A> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
            0x120e6000 - 0x120e7fff +com.adobe.InDesign.Metadata Database Filter (5.0.0.458 - 0) <CC8859BB-C15A-4709-B912-FD85C537F6EC> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
            0x120eb000 - 0x12148ff7 +com.adobe.InDesign.Metadata (5.0.0.458 - 0) <5FB6CA73-600B-4225-B823-753E0F5AFB10> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
            0x1216f000 - 0x1217cffb +com.adobe.InDesign.Movie (5.0.0.458 - 0) <CFFA5F71-7E72-412D-B6B3-E3CFBAB0C573> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
            0x12185000 - 0x121acfef +com.adobe.InDesign.Open Place (5.0.3.662 - 0) <80624A30-72ED-4E26-AF78-79BFD7D0254A> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
            0x121c0000 - 0x12241fcb +com.adobe.InDesign.Paragraph Composer (5.0.3.662 - 0) <2C1E626B-498A-4858-8525-FEE5C66E4351> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
            0x1224b000 - 0x12274fff +com.adobe.InDesign.Path Type (5.0.0.458 - 0) <AD456B86-9F34-4347-BE93-F6071C1CD914> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
            0x12285000 - 0x12406fff +com.adobe.InDesign.PDF (5.0.3.662 - 0) <6229F027-1F10-4608-8011-5D8B7BAD2987> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
            0x1247b000 - 0x1255cfdf +AdobePDFPort (1) <FDB3F36A-4646-4BCD-A916-D1B474ADA69E> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
            0x125a0000 - 0x125bbff9 +AdobePDFSettings (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
            0x125d4000 - 0x12abd053 +AdobePDFL (1) <E38E0313-B32B-4E1B-8698-73B902B95CDF> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
            0x12bcd000 - 0x12bfbffb +com.adobe.InDesign.Photoshop Import Filter (5.0.3.662 - 0) <C1C3FF45-5B6A-4DB5-867E-13E88512AE20> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
            0x12c0f000 - 0x138b6feb +com.adobe.psl (10.312765.46.313722 - 10.312765.46.313722) <C0C4D40C-B84D-4740-BF61-35D5FBFC00FF> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
            0x13bd5000 - 0x13be9fff +com.adobe.InDesign.Rulers (5.0.3.662 - 0) <C4619DFA-27A2-4CE8-831C-F881927C1688> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Rulers.InDesignPlugin/Rulers
            0x13bf5000 - 0x13bfbfff +com.adobe.InDesign.Workgroup Client UI (5.0.3.662 - 0) <2D2435BF-FA08-4722-A02F-F0F48AEFE8DC> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Workgroup Client UI.InDesignPlugin/Workgroup Client UI
            0x13d00000 - 0x13d2dfdf +com.adobe.InDesign.PNG Import Filter (5.0.0.458 - 0) <90BD2E5C-CDB7-497F-B55F-A1F0ABA23DAA> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
            0x13d35000 - 0x13e50fe3 +com.adobe.InDesign.Print (5.0.0.458 - 0) <0C7F8380-7B66-4126-BD7A-B5E764C84833> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
            0x13ea6000 - 0x13eedfe3 +com.adobe.InDesign.Scripting (5.0.0.458 - 0) <1C747E70-9A78-45B1-8584-D10BFD3D697D> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
            0x13efe000 - 0x13f0dfef +com.adobe.InDesign.Sections (5.0.0.458 - 0) <F69DEDDF-551C-4C94-9291-B2A11FF191C0> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
            0x13f17000 - 0x13f20ffb +com.adobe.InDesign.Sound (5.0.0.458 - 0) <4849CC5C-CF16-4456-8F3D-8931110CAD86> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
            0x13f29000 - 0x13f31fe7 +com.adobe.InDesign.Spelling Service (5.0.0.458 - 0) <382FA24B-0747-43D2-AA15-745E9911A56A> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
            0x13f39000 - 0x13f68fff +com.adobe.InDesign.Spline UI (5.0.0.458 - 0) <BFD4A9F1-6791-4AED-BA9E-2075B75437FB> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Spline UI
            0x13f83000 - 0x13fb9ff0 +com.adobe.InDesign.Spline (5.0.0.458 - 0) <375E9524-DCC7-4261-8602-796322796346> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
            0x13fd2000 - 0x13ff4ffb +com.adobe.InDesign.Spread UI (5.0.0.458 - 0) <F7A0FA24-F846-44F7-8236-95A411E83EE5> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
            0x14000000 - 0x1408cfff +com.adobe.InDesign.Spread (5.0.3.662 - 0) <1CE54277-1B61-4558-BC24-9A5C2B91EF38> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
            0x140a9000 - 0x140e3feb +com.adobe.InDesign.Stroke and Fill (5.0.0.458 - 0) <8A29824D-3A5E-4A27-A588-D7D6935FD86D> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
            0x140f2000 - 0x14115fef +com.adobe.InDesign.Support for AppleScript (5.0.0.458 - 0) <F1AF5EC7-0041-47A2-B8B5-F5060616FDDD> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
            0x1411f000 - 0x1418cfff +com.adobe.InDesign.Support for JavaScript (5.0.0.458 - 0) <655233A4-8990-482C-8266-6A056D94494F> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
            0x141b7000 - 0x14370ffc +com.adobe.InDesign.Table Model (5.0.0.458 - 0) <E7338D64-7690-45CE-94B2-8CC508842208> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
            0x143e9000 - 0x14415feb +com.adobe.InDesign.TableStyles (5.0.0.458 - 0) <50C17913-20DB-4EC6-B1E1-637487823E88> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
            0x14422000 - 0x1444bfef +com.adobe.InDesign.Text Attributes (5.0.0.458 - 0) <5EB4606D-80FD-49EF-A016-4B4F03C7BBC6> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
            0x1445f000 - 0x14468feb +com.adobe.InDesign.Text Editor Model (5.0.0.458 - 0) <58F9DD41-B1CA-4370-BF3C-AA70E0C38A43> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
            0x1446f000 - 0x144e8ff3 +com.adobe.InDesign.Text Editor (5.0.0.458 - 0) <7677E1F3-26C7-43BB-8655-B41C08310052> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
            0x14507000 - 0x1452fff6 +com.adobe.InDesign.Text Wrap Path (5.0.0.458 - 0) <2321E474-F5B3-4BBA-A674-1FFB81BFAD46> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
            0x1453b000 - 0x14578ffb +com.adobe.InDesign.Text Wrap (5.0.3.662 - 0) <E228228D-5CA7-49BA-8735-F2140E8C4357> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
            0x1458a000 - 0x14895fef +com.adobe.InDesign.Text (5.0.3.662 - 0) <5148E0CE-EF5E-490C-89B0-DFBF553325E7> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
            0x1491f000 - 0x14955fff +com.adobe.InDesign.TOC (5.0.3.662 - 0) <A0947811-3117-4BBE-8F22-9C32A0C85A6C> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
            0x14962000 - 0x14a4dff3 +com.adobe.InDesign.Transparency (5.0.3.662 - 0) <D7D50980-B048-407C-AEBC-E2F80E4A8C5F> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
            0x14a96000 - 0x14ab3fef +com.adobe.InDesign.Utilities (5.0.3.662 - 0) <09C68DC0-14AB-4D21-8236-875FC422FD1C> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
            0x14ac8000 - 0x14b7bff2 +com.adobe.InDesign.Widgets (5.0.3.662 - 0) <879FA3A8-3958-4E98-BDBA-9C749C8A1BAE> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Widgets.InDesignPlugin/Widgets
            0x14bc4000 - 0x14bd2fff +com.adobe.InDesign.Workgroup Client (5.0.3.662 - 0) <B5726BC1-8AD6-4445-8F4B-5976E68E87CE> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
            0x14bd9000 - 0x14bf700f +com.adobe.InDesign.Workgroup (5.0.0.458 - 0) <A2AF6FDB-FEE3-4E68-B2A1-A1324372D789> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
            0x14c00000 - 0x14dbcfff +com.adobe.InDesign.XML (5.0.3.662 - 0) <73737F36-402F-41FE-93CD-AEDBB4940A9E> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
            0x14e57000 - 0x14f28fef +AdobeAXEDOMCore (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
            0x14f5a000 - 0x14fbeff7 +com.adobe.InDesign.XMLParser (5.0.0.458 - 0) <72EA1124-4504-4E5F-8C28-B470D381BA5D> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
            0x14ff1000 - 0x15054fff +AdobeAXEParser (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeAXEParser.framework/Versions/A/AdobeAXEParser
            0x15070000 - 0x1512dfff +AdobeAXSLE (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
            0x152b6000 - 0x152d8ffe  libssl.0.9.7.dylib (106) <FC1F6C04-EAD3-39D1-8E25-B1192E89D98B> /usr/lib/libssl.0.9.7.dylib
            0x152ea000 - 0x152edfff +TINthread.dylib (1) /Library/Application Support/Adobe/*/TINthread.dylib
            0x152f4000 - 0x15303fe7 +PACLib.dylib (1) <282B0EF8-6943-426B-BC69-0153E0E7E13D> /Library/Application Support/Adobe/*/WRLiloPlugin1.0.bundle/Contents/SharedSupport/PACLib.dylib
            0x15700000 - 0x15b34077 +com.adobe.versioncue (3.0.0.78 - 3.0.0.78) /Library/Application Support/Adobe/*/VersionCue.framework/VersionCue
            0x15f0d000 - 0x15fb8fff  libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
            0x15ffc000 - 0x160baff3  ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
            0x161f7000 - 0x16251fe7 +com.adobe.SING.bundle (11.4.0 - 11.4.0) <B4FBAE4D-E332-4E95-821E-C7E39BFDEE50> /Library/Application Support/Adobe/*/SING.bundle/Contents/MacOS/SING
            0x16362000 - 0x163bcfe7 +com.adobe.SING.bundle (11.4.0 - 11.4.0) <B4FBAE4D-E332-4E95-821E-C7E39BFDEE50> /Library/Application Support/Adobe/*/SING.bundle/Contents/MacOS/SING
            0x1650e000 - 0x1650effd  com.apple.applescript.component (2.2.4 - 2.2.4) <5CBCAFAE-FEBD-3110-B5E8-D75E418E6D82> /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
            0x167a9000 - 0x167b8ffe +CNSLib.dylib (1) /Library/Application Support/Adobe/*/WRLiloPlugin1.0.bundle/Contents/SharedSupport/CNSLib.dylib
            0x17000000 - 0x170d2fcf +com.adobe.TIN (1.3.0 - 1.3.0) /Library/Application Support/Adobe/*/TIN.bundle/Contents/MacOS/TIN
            0x177a8000 - 0x177b8fe7 +com.adobe.epic (adobe_registration 2.0.1.1082 - 2.0.1.1082) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/adobe_registration.framework/adobe_registration
            0x180b0000 - 0x180bdff7 +com.adobe.asneu.framework (asneu version 1.6.2f01 - 1.6.2) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/asneu.framework/asneu
            0x180c1000 - 0x180eeffa +com.winsoft.wrliloplugin (1.0rc7 - 1.0rc7) <396F5FC6-A698-4EC8-9581-F41119129A5B> /Library/Application Support/Adobe/*/WRLiloPlugin1.0.bundle/Contents/MacOS/WRLiloPlugin1.0
            0x1823d000 - 0x18264fc3 +HSNFT.dylib (1) <8C6B1963-5120-4802-88B5-446461BAD6A3> /Library/Application Support/Adobe/*/WRLiloPlugin1.0.bundle/Contents/SharedSupport/HSNFT.dylib
            0x18689000 - 0x186acfd3 +MORPHLibs.dylib (1) <98B00167-ADA9-4864-B80E-1F48A0519C68> /Library/Application Support/Adobe/*/WRLiloPlugin1.0.bundle/Contents/SharedSupport/MORPHLibs.dylib
            0x187b4000 - 0x187bcff3  com.apple.URLMount.AFPPlugin (5.0 - 5.0) <31264941-3336-3668-B5FA-885F025B724F> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
            0x187c3000 - 0x187d0ffb  com.apple.KerberosHelper (4.0 - 1.0) <6CB4B091-3415-301A-87B2-D9D374D0FC17> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
            0x187da000 - 0x187edfff +com.adobe.AdobeSFL (AdobeSFL 1.1 - 1.1.0.12) <9A014AEE-FC48-4000-A00C-EB2C6FD72795> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
            0x198d8000 - 0x198e1fff  com.apple.AppleSRP (5.0 - 1) <3B64757C-2F3F-327D-A7C1-9FCBAC4AB684> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
            0x1a3ec000 - 0x1a3f8fe3 +com.adobe.epic (adobe_eula 2.0.1.1082 - 2.0.1.1082) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/adobe_eula.framework/adobe_eula
            0x1b3cb000 - 0x1b3eefe3 +PMFileReader.dylib (1) <D1DB58A4-61B8-42AA-8211-D7BD076E9985> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/PMFileReader.dylib
            0x1b55f000 - 0x1b5ebfff  com.apple.applescript (2.2.4 - 2.2.4) <E3B635BE-0198-3B38-8671-A52CF89DE904> /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
            0x1b6df000 - 0x1b726ff3  com.apple.AppleShareClientCore (3.0 - 3.0) <51846A19-3354-34FD-8AEF-C4247B800B13> /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
            0x1c700000 - 0x1c735fd3 +com.adobe.epic (adobe_epic 2.0.1.1082 - 2.0.1.1082) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/adobe_epic.framework/adobe_epic
            0x1c7d8000 - 0x1c7e6fc5 +com.adobe.epic (adobe_personalization 2.0.1.1082 - 2.0.1.1082) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/adobe_personalization.framework/adobe_personalization
            0x1d300000 - 0x1d358ff2 +com.adobe.ESD.AdobeUpdaterLibFramework (AdobeUpdater 5.1.0.1082 - 5.1.0.1082) <CA913CDD-FA7B-4435-8BEB-052BB879AED6> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeUpdater.framework/AdobeUpdater
            0x1d7a2000 - 0x1d7e2ff6 +com.adobe.Reader for DOCX (Reader for DOCX 4.2 - 4.2.0.12) <6201D195-4683-47BA-9543-55494376F940> /Applications/Adobe InDesign CS3/*/Reader for DOCX
            0x1e51b000 - 0x1e591fe2 +com.adobe.AdobeSangamML (AdobeSangamML 4.2 - 4.2.0.22) <FD1F9BE0-1ADF-42FF-AC1F-39735664F171> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeSangamML.framework/Versions/A/AdobeSangamML
            0x1e901000 - 0x1e965fdf +com.adobe.Reader for Excel (Reader for Excel 4.2 - 4.2.0.12) <991C393D-11B4-4FB5-9FFB-A0FFEFAB6394> /Applications/Adobe InDesign CS3/*/Reader for Excel
            0x1f103000 - 0x1f183fff +com.adobe.Reader For PageMaker (Reader For PageMaker 4.2 - 4.2.0.12) <9D8B62D4-A92E-4CAB-9A4E-933EA03AA35D> /Applications/Adobe InDesign CS3/*/Reader For PageMaker
            0x1f1d8000 - 0x1f2d1fd3 +com.adobe.Reader for Quark (Reader for Quark 4.2 - 4.2.0.12) <1B5A40E4-E978-4AD4-9A11-C884A155A12C> /Applications/Adobe InDesign CS3/*/Reader for Quark
            0x1f320000 - 0x1f37dfe8 +com.adobe.Reader for RTF (Reader for RTF 4.2 - 4.2.0.12) <4531A104-2B9D-4677-80AE-4A48362123E4> /Applications/Adobe InDesign CS3/*/Reader for RTF
            0x1f3a8000 - 0x1f413fcf +com.adobe.Reader for Word (Reader for Word 4.2 - 4.2.0.12) <5A81923E-87EB-4714-AB38-AC04546F505E> /Applications/Adobe InDesign CS3/*/Reader for Word
            0x1f43b000 - 0x1f4aaff8 +com.adobe.Reader for XLSX (Reader for XLSX 4.2 - 4.2.0.12) <F9479706-A7C2-4F81-AC81-C4057E9383BF> /Applications/Adobe InDesign CS3/*/Reader for XLSX
            0x1f4fa000 - 0x1f501fff +com.adobe.ZTextReader (ZTextReader 4.2 - 4.2.0.12) <6B001DB3-AA5E-499B-9447-B5FFD3D5A81F> /Applications/Adobe InDesign CS3/*/ZTextReader
            0x1f70a000 - 0x1f829ffb  com.apple.WebKit (8536 - 8536.28.10) <C181C3FB-91E3-38AB-A709-6B61935B3AD8> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
            0x1f8da000 - 0x2056dffb  com.apple.WebCore (8536 - 8536.28.10) <AA738A8C-808D-302A-B58D-404C58075C45> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
            0x20e44000 - 0x212bcfeb +AdobeLM_libFNP.dylib (1) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/MacOS/AdobeLM_libFNP.dylib
            0x22b74000 - 0x22bd9ff3 +MMXCore (???) <8056FC74-FDA9-45C1-8B65-59511D058757> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobePSL.framework/PlugIns/mmxcore.plugin/Contents/MacOS/MMXC ore
            0x22c77000 - 0x22cc3ffb +MultiProcessor Support (???) <C426E399-55FE-4EB1-B202-FEB044EEEDA5> /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobePSL.framework/PlugIns/multiprocessor support.plugin/Contents/MacOS/MultiProcessor Support
            0x25a2b000 - 0x25fd2fd7 +com.macromedia.Flash Player.authplaylib (9.0.43.0 - 1.0.4f43) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeOwl.framework/Resources/AuthPlayLib.bundle/Contents/MacO S/AuthPlayLib
            0x40000000 - 0x400a6fe0 +AdobeJP2K (0) /Applications/Adobe InDesign CS3/Adobe InDesign CS3.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
            0x8fe94000 - 0x8fec6e57  dyld (210.2.3) <23516BE4-29BE-350C-91C9-F36E7999F0F1> /usr/lib/dyld
            0x90007000 - 0x90010ff9  com.apple.CommonAuth (3.0 - 2.0) <34C4768C-EF8D-3DBA-AFB7-09148C8672DB> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
            0x903a5000 - 0x90788fff  com.apple.HIToolbox (2.0 - 626.1) <ECC3F04F-C4B7-35BF-B10E-183B749DAB92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0x9078c000 - 0x90948ffd  libicucore.A.dylib (491.11.2) <59A23F06-16AD-35F8-BA58-D17305232402> /usr/lib/libicucore.A.dylib
            0x90949000 - 0x90966fff  libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
            0x90967000 - 0x90968fff  libquarantine.dylib (52) <D526310F-DC77-37EA-8F5F-83928EFA3262> /usr/lib/system/libquarantine.dylib
            0x90969000 - 0x90975ff7  com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
            0x90976000 - 0x90980fff  libCSync.A.dylib (331.0.4) <71A7B331-C8A2-322C-AFB0-062EE9C3B848> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
            0x90981000 - 0x90985fff  com.apple.OpenDirectory (10.8 - 151.10) <A1858D81-086F-3BF5-87E3-9B70409FFDF6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
            0x909ba000 - 0x90a14fff  com.apple.Symbolication (1.3 - 93) <D327EEFF-F2F5-39C4-B1EC-32E259DC04F1> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
            0x9129e000 - 0x913a9ff7  libJP2.dylib (849) <B2D0E844-C390-376C-91D9-F3501B5C7A83> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
            0x913aa000 - 0x91401ff7  com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
            0x9145f000 - 0x914a3ff7  libGLU.dylib (8.7.25) <0CC1A4D8-C095-3F2B-B55C-FDEBEA0E9CFE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
            0x914a4000 - 0x914aefff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
            0x914af000 - 0x914fdff3  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <6E858B9F-337A-314E-88B7-24A274ACE568> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
            0x914fe000 - 0x91596fff  com.apple.CoreServices.OSServices (557.6 - 557.6) <E1600639-3EEC-3DF8-BD40-747BB2117988> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
            0x91883000 - 0x918b8fff  libTrueTypeScaler.dylib (84.6) <B7DB746B-7A61-38EF-8CA7-408ED9C14A02> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
            0x919d0000 - 0x91a6bfff  com.apple.CoreSymbolication (3.0 - 117) <F705A8CD-A04A-3A84-970A-7B04BC05DA97> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
            0x91a6c000 - 0x91aaeff7  libcups.2.dylib (327.3) <C7A4A315-FA15-354B-8BC9-BE824C4EFF6D> /usr/lib/libcups.2.dylib
            0x91aaf000 - 0x91abfff2  com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
            0x91ac0000 - 0x91dc5ff7  com.apple.CoreServices.CarbonCore (1037.5 - 1037.5) <356AE2DF-ABB0-319C-8B5B-2F33D693889F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
            0x91df9000 - 0x91dfdffc  libGIF.dylib (849) <2F1DE1C6-4779-35A6-8ED5-BBF8ADD5962A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
            0x91e41000 - 0x91e49fff  libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
            0x91e4a000 - 0x9228cff3  com.apple.CoreGraphics (1.600.0 - 331.0.4) <BC041647-FB5A-3D07-A253-F3D34E25BF6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
            0x9228d000 - 0x922cfff7  libauto.dylib (185.1) <B2B5B639-6778-352A-828D-FD8B64A3E8B3> /usr/lib/libauto.dylib
            0x92404000 - 0x92404fff  com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
            0x92414000 - 0x9241bffb  libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
            0x9241c000 - 0x92440fff  com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
            0x924a8000 - 0x924a8fff  libSystem.B.dylib (169.3) <4F99C03B-BBFF-3BF8-8CC2-2DA764447446> /usr/lib/libSystem.B.dylib
            0x924a9000 - 0x924b0fff  libsystem_dnssd.dylib (379.37) <49A44FB3-559D-3C7E-AA40-23F5A8E612AC> /usr/lib/system/libsystem_dnssd.dylib
            0x924b1000 - 0x925a9ff9  libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
            0x925aa000 - 0x92659ff7  com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
            0x92773000 - 0x929ccff8  com.apple.JavaScriptCore (8536 - 8536.28.10) <B02A662A-7DE6-3C9D-AB08-AA746D48FF2B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
            0x929cd000 - 0x929ebff3  com.apple.openscripting (1.3.6 - 148.3) <F3422C02-5ACB-343A-987B-A2D58EA2F5A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
            0x92c5f000 - 0x92c74fff  com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
            0x92d17000 - 0x92d1dfff  com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
            0x92d69000 - 0x92dcbfff  libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
            0x92e0d000 - 0x92e1cfff  libGL.dylib (8.7.25) <818E3E6B-9B00-3117-8157-9E95CB59A47B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
            0x92e1d000 - 0x92e1effd  com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
            0x92e1f000 - 0x92e2dfff  com.apple.opengl (1.8.7 - 1.8.7) <0631EC1D-833B-39D2-A907-A9F7617E5504> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
            0x92e2e000 - 0x92f02ff3  com.apple.backup.framework (1.4.2 - 1.4.2) <0473EB45-E9BF-3C10-B235-A6E2B960A88F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
            0x92f03000 - 0x92f2cff7  libRIP.A.dylib (331.0.4) <FE496AFC-420A-3712-BC79-FC8C63ADB73D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
            0x92f2d000 - 0x93049ffb  com.apple.desktopservices (1.7.3 - 1.7.3) <7157C51D-C695-3C9E-B532-F551E7E55B56> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
            0x9304a000 - 0x93261fff  com.apple.CoreData (106.1 - 407.7) <17FD06D6-AD7C-345A-8FA4-1F0FBFF4DAE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
            0x932be000 - 0x932bffff  libsystem_sandbox.dylib (220.2) <61A79095-1978-3AAA-B0E0-658BC8E5F045> /usr/lib/system/libsystem_sandbox.dylib
            0x934f1000 - 0x934f4ff9  libCGXType.A.dylib (331.0.4) <981B13D6-4E8B-3468-92D3-FE436B48C0DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
            0x93532000 - 0x935a1ffb  com.apple.Heimdal (3.0 - 2.0) <964D9952-B0F2-34F6-8265-1823C0D5EAB8> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
            0x935a2000 - 0x935e1ff7  com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
            0x935e2000 - 0x9360fffe  libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
            0x93610000 - 0x93612ffb  libRadiance.dylib (849) <EAF7C74F-2A71-3A07-82E1-4FADEAFCF201> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
            0x93613000 - 0x93614fff  libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
            0x93615000 - 0x93706ffc  libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
            0x93707000 - 0x942c3ff7  com.apple.AppKit (6.8 - 1187.37) <6FBB3467-04F9-395F-8EA8-C84347C5BE43> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            0x9463d000 - 0x94682ff7  com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
            0x94683000 - 0x9468aff3  com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
            0x9468b000 - 0x947e3ffb  com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <0D36953C-9897-3E9B-8C70-847E90B203A2> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
            0x947e4000 - 0x947f1ff7  com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
            0x9484c000 - 0x9486cffd  com.apple.ChunkingLibrary (2.0 - 133.3) <FA45EAE8-BB10-3AEE-9FDC-C0C3A533FF48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
            0x9486d000 - 0x9486dfff  com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
            0x9486e000 - 0x9486efff  com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
            0x9486f000 - 0x94885fff  com.apple.CFOpenDirectory (10.8 - 151.10) <56C3F276-BD1F-3031-8CF9-8F4F481A534E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
            0x94886000 - 0x94930fff  com.apple.LaunchServices (539.7 - 539.7) <AF33EBD3-BC0B-30B5-B7DA-5CCCF12D7EDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
            0x94931000 - 0x9493afff  com.apple.DiskArbitration (2.5.2 - 2.5.2) <89822A83-B450-3363-8E9C-9B80CB4450B1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
            0x9493b000 - 0x94946fff  libcommonCrypto.dylib (60027) <8EE30FA5-AA8D-3FA6-AB0F-05DA8B0425D9> /usr/lib/system/libcommonCrypto.dylib
            0x94947000 - 0x9494afff  com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
            0x9494b000 - 0x949a9ff7  com.apple.audio.CoreAudio (4.1.1 - 4.1.1) <953DD669-8C6E-387D-AB3F-D8C8965347DF> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
            0x949aa000 - 0x94af8fff  com.apple.CFNetwork (596.3.3 - 596.3.3) <EC7EF37B-B00E-374D-9E8F-E4E22D741059> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
            0x94af9000 - 0x94d9cff3  com.apple.CoreImage (8.2.4 - 1.0.1) <BA4EE8D7-FE72-3CC3-801F-B69D8A8B426F> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
            0x94d9d000 - 0x94da7ffe  com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
            0x94da8000 - 0x94e66ff3  com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
            0x94e67000 - 0x94ee3ff3  com.apple.Metadata (10.7.0 - 707.5) <F2BC2AB4-A87A-3D37-A496-AC21EF3E1244> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
            0x94eec000 - 0x94ef8ffe  libkxld.dylib (2050.22.13) <ED37AAAA-B1C0-3ADF-A897-3D580A845843> /usr/lib/system/libkxld.dylib
            0x94f82000 - 0x95242ff3  com.apple.security (7.0 - 55179.11) <165A3105-9ADF-329B-93FC-3C8EFAEDDD13> /System/Library/Frameworks/Security.framework/Versions/A/Security
            0x95243000 - 0x95247fff  com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
            0x95281000 - 0x95283fff  libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
            0x95284000 - 0x95309ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
            0x9530a000 - 0x9530affd  com.apple.audio.units.AudioUnit (1.8 - 1.8) <D35BA73D-1E56-3A1D-9F9F-971F3BF8C136> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
            0x9530b000 - 0x95314fff  com.apple.CommerceCore (1.0 - 26.1) <8C28115C-6EC1-316D-9237-F4FBCBB778C5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
            0x95315000 - 0x95318ffc  libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
            0x95319000 - 0x9531ffff  libGFXShared.dylib (8.7.25) <4268BFAF-4529-3B40-A8B9-66F176AC20CF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
            0x95320000 - 0x95333ff9  com.apple.MultitouchSupport.framework (235.29 - 235.29) <451701B6-03CE-3F26-9FF0-92D8DA1467EE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
            0x955fa000 - 0x95651ff3  com.apple.HIServices (1.20 - 417) <561A770B-8523-3D09-A763-11F872779A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
            0x9569a000 - 0x9569cfff  com.apple.securityhi (4.0 - 55002) <15E9B9BC-108F-3416-A0A7-A321A85081F7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
            0x9569d000 - 0x956a9ff8  libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
            0x956ac000 - 0x95824ff5  com.apple.QuartzCore (1.8 - 304.2) <FB737C74-C460-32A3-9107-D2112BAE6EBC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
            0x9582c000 - 0x95830ffe  libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
            0x95993000 - 0x959bfff7  libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
            0x959cc000 - 0x95a41ff7  com.apple.ApplicationServices.ATS (332 - 341.1) <95206704-F9C9-33C4-AF25-FE9890E160B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
            0x95a49000 - 0x95a95fff  libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
            0x95ac2000 - 0x95ad4fff  libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
            0x96271000 - 0x9628efff  libxpc.dylib (140.42) <1E419D55-C5C1-33FF-B52E-6C7FFBEA5E1F> /usr/lib/system/libxpc.dylib
            0x9628f000 - 0x96292ff7  libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
            0x96293000 - 0x962b5fff  libc++abi.dylib (26) <3AAA8D55-F5F6-362B-BA3C-CCAF0D3C8E27> /usr/lib/libc++abi.dylib
            0x962b6000 - 0x962d5ff3  com.apple.Ubiquity (1.2 - 243.15) <E10A2937-D671-3D14-AF8D-BA25E601F458> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
            0x962d6000 - 0x96393feb  libsystem_c.dylib (825.26) <6E35A83F-1A5B-3AF9-8C6D-D7B57B25FB63> /usr/lib/system/libsystem_c.dylib
            0x96480000 - 0x964a5ffb  com.apple.framework.familycontrols (4.1 - 410) <B1755756-BEA2-3205-ADAA-68FCC32E60BD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
            0x964a6000 - 0x964a6fff  libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
            0x964a7000 - 0x964aaffc  libCoreVMClient.dylib (32.3) <35B63A60-DF0A-3FB3-ABB8-164B246A43CC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
            0x964ab000 - 0x964c8ff7  libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
            0x96520000 - 0x96708ffb  com.apple.CoreFoundation (6.8 - 744.18) <68AFEE40-0078-347E-9DEE-32CFE0062A10> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x96709000 - 0x96771fe7  libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
            0x967b8000 - 0x967b8fff  com.apple.Carbon (154 - 155) <604ADD9D-5835-3294-842E-3A4AEBCCB548> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
            0x967b9000 - 0x967d0fff  com.apple.GenerationalStorage (1.1 - 132.3) <DD0AA3DB-376D-37F3-AC5B-17AC9B9E0A63> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
            0x967db000 - 0x96836fff  com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
            0x96867000 - 0x96879ff7  libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
            0x9687a000 - 0x968adffb  com.apple.GSS (3.0 - 2.0) <9566A96D-C296-3ABD-A12A-E274C81C0B25> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
            0x96972000 - 0x96976ff7  libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
            0x96b02000 - 0x96b33fff  com.apple.DictionaryServices (1.2 - 184.4) <0D5BE86F-F40A-3E39-8569-19FCA5EDF9D3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
            0x96b34000 - 0x96b37ff7  com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
            0x96b38000 - 0x96b42fff  libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
            0x96b72000 - 0x96badfef  libGLImage.dylib (8.7.25) <6C0B2148-032A-3911-AB21-2E07606E3D9A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
            0x96bae000 - 0x96eccff3  com.apple.Foundation (6.8 - 945.16) <C4D95341-B4FF-30AC-815A-A23C019C57A3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            0x96ecd000 - 0x96ecdfff  com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
            0x96ece000 - 0x96f36ff7  com.apple.framework.IOKit (2.0.1 - 755.22.5) <F9A70D23-1108-3616-9DE3-6C5730CA7AB2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
            0x9702c000 - 0x9702dffd  libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
            0x9702e000 - 0x9702efff  com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
            0x97132000 - 0x97147fff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
            0x97148000 - 0x971dfff7  com.apple.ink.framework (10.8.2 - 150) <D90FF7BC-6B90-39F1-AC52-670269947C58> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
            0x971f8000 - 0x97615fff  FaceCoreLight (2.4.1) <571DE3F8-CA8A-3E71-9AF4-F06FFE721CE6> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
            0x97616000 - 0x97751ff7  libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
            0x97b4f000 - 0x97bcbffb  libType1Scaler.dylib (101.1) <0D94D786-29F7-33DB-B64B-B264FA5EACD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
            0x97bcc000 - 0x97cd9ff3  com.apple.ImageIO.framework (3.2.0 - 849) <B34C2380-51F6-38B1-BB6C-C2E5185D90EF> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
            0x97ce5000 - 0x97d5fff7  com.apple.securityfoundation (6.0 - 55115.4) <7F614418-F853-3FED-B265-0EA47F309A49> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
            0x97d60000 - 0x97da2ffb  com.apple.RemoteViewServices (2.0 - 80.6) <AE962502-4539-3893-A2EB-9D384652AEAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
            0x97da3000 - 0x97da7fff  com.apple.IOSurface (86.0.4 - 86.0.4) <6431ACB6-561B-314F-9A2A-FAC1578FCC86> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
            0x97da8000 - 0x97daaffd  libCVMSPluginSupport.dylib (8.7.25) <C8FC6227-5209-3138-89CD-03CAD11F3EC3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
            0x97ded000 - 0x97e06fff  com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
            0x97e07000 - 0x97e6bff3  libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
            0x97e6c000 - 0x97e6cfff  libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
            0x97e6d000 - 0x97e6dffd  libOpenScriptingUtil.dylib (148.3) <87895E27-88E2-3249-8D0E-B17E76FB00C1> /usr/lib/libOpenScriptingUtil.dylib
            0x97e6e000 - 0x97e7cff3  libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
            0x97e7d000 - 0x97e7efff  libdnsinfo.dylib (453.19) <3B523729-84A8-3D0B-B58C-3FC185060E67> /usr/lib/system/libdnsinfo.dylib
            0x97e90000 - 0x97f44fff  com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
            0x97f45000 - 0x97f53ff7  libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
            0x97f54000 - 0x97f70fff  libPng.dylib (849) <BF2CB6F5-A2F1-35A4-93F7-ACA6D7F02084> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
            0x97f78000 - 0x97f78fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
            0x97f79000 - 0x97f82ffd  com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
            0x97f83000 - 0x97fe9fff  com.apple.print.framework.PrintCore (8.3 - 387.2) <0F7665F5-33F0-3661-9BE2-7DD2890E304B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
            0x97fea000 - 0x98173ff7  com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
            0x98178000 - 0x9819dff7  com.apple.CoreVideo (1.8 - 99.4) <A26DE896-32E0-3D5E-BA89-02AD23FA96B3> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
            0x981ea000 - 0x98217ffb  com.apple.CoreServicesInternal (154.2 - 154.2) <DCCF604B-1DB8-3F09-8122-545E2E7F466D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
            0x98218000 - 0x98260ff5  com.apple.opencl (2.2.18 - 2.2.18) <004A1DE4-49C6-3938-8B54-CD1DC23BDBE5> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
            0x98261000 - 0x98301ff7  com.apple.QD (3.42 - 285) <1B8307C6-AFA8-312E-BA5B-679070EF2CA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
            0x98302000 - 0x98303fff  liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
            0x98304000 - 0x9835effb  com.apple.AE (645.6 - 645.6) <44556FF7-A869-399A-AEBB-F4E9263D9152> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
            0x9835f000 - 0x983c3fff  com.apple.datadetectorscore (4.1 - 269.2) <B4D53047-C613-32F8-9E08-0154EA81B487> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
            0x98a51000 - 0x98b5e057  libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
            0x98b5f000 - 0x98b6dfff  libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
            0x98c2f000 - 0x98eabff7  com.apple.QuickTime (7.7.1 - 2599.24) <5B1CA228-A6B3-39DF-A5CC-F981E59DAD1D> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
            0x98eac000 - 0x98ed0fff  libJPEG.dylib (849) <CD42C17E-6B13-35BE-B585-9AE69CEA534F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
            0x98ed1000 - 0x98f20ff6  libTIFF.dylib (849) <229EBA67-A2D3-30B7-8177-3CA5503360EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
            0x98f23000 - 0x992dbffa  libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
            0x992dc000 - 0x992e8ffa  com.apple.CrashReporterSupport (10.8.3 - 417) <A4A45B14-8992-3739-82BC-3C5E5C2686F9> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
            0x992e9000 - 0x99337ffb  libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
            0x99338000 - 0x993caffb  libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
            0x993cc000 - 0x994b5ff7  libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
            0x994b6000 - 0x994b7fff  libremovefile.dylib (23.2) <9813B2DB-2374-3AA2-99B6-AA2E9897B249> /usr/lib/system/libremovefile.dylib
            0x994b8000 - 0x994e1fff  libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
            0x9964e000 - 0x99655fff  liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
            0x99656000 - 0x9968cffb  com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
            0x9a634000 - 0x9a732ff7  libFontParser.dylib (84.6) <7D3EB3CC-527E-3A74-816A-59CAFD2260A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
            0x9a733000 - 0x9a74dffc  libsystem_kernel.dylib (2050.22.13) <70C520E8-0394-3DFB-823B-FE8C251C169A> /usr/lib/system/libsystem_kernel.dylib
            0xba300000 - 0xba301fff  libCyrillicConverter.dylib (61) <76630B89-A9CE-376B-B836-B55D8543717B> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
            0xba500000 - 0xba501ffd  libGreekConverter.dylib (61) <8420F227-2783-36D9-997E-39110328F77C> /System/Library/CoreServices/Encodings/libGreekConverter.dylib
            0xba900000 - 0xba91cffd  libJapaneseConverter.dylib (61) <A3F2F55D-E491-3532-A8F6-8D3F2455704F> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
            0xbab00000 - 0xbab21ffc  libKoreanConverter.dylib (61) <39F6BEE7-AE54-3423-B920-2A3573BC9A1A> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
            0xbb500000 - 0xbb500fff  libThaiConverter.dylib (61) <3EE5ABD4-2C9C-3E95-A990-EBE4C715AFF1> /System/Library/CoreServices/Encodings/libThaiConverter.dylib
            External Modification Summary:
              Calls made by other processes targeting this process:
            task_for_pid: 10
            thread_create: 0
            thread_set_state: 0
              Calls made by this process:
            task_for_pid: 0
            thread_create: 0
            thread_set_state: 0
              Calls made by all processes on this machine:
            task_for_pid: 1365
            thread_create: 1
            thread_set_state: 0
            VM Region Summary:
            ReadOnly portion of Libraries: Total=299.2M resident=141.6M(47%) swapped_out_or_unallocated=157.6M(53%)
            Writable regions: Total=345.8M written=110.2M(32%) resident=152.3M(44%) swapped_out=0K(0%) unallocated=193.5M(56%)
            REGION TYPE                  VIRTUAL
            ATS (font support)             33.2M
            CG backing stores              14.6M
            CG raster data                   64K
            CG shared images                192K
            CoreServices                   2832K
            MALLOC                        187.0M
            MALLOC guard page                48K
            MALLOC_LARGE (reserved)        67.6M    reserved VM address space (unallocated)
            Memory tag=240                    4K
            Memory tag=242                   12K
            Memory tag=243                    4K
            Memory tag=249                  156K
            Memory tag=35                  7012K
            Stack                          71.6M
            VM_ALLOCATE                    32.3M
            __DATA                         34.1M
            __DATA/__OBJC                   104K
            __IMAGE                         528K
            __IMPORT                       1224K
            __LINKEDIT                     58.9M
            __OBJC                         2116K
            __OBJC/__DATA                     4K
            __PAGEZERO                        4K
            __TEXT                        240.3M
            __UNICODE                       544K
            __dw                              8K
            mapped file                   123.3M
            shared memory                  20.4M
            TOTAL                         897.9M
            TOTAL, minus reserved VM space830.3M
            • 3. Re: InDesign CS3 crashes on certain commands
              In future, please put your crash reports on pastebin.com and put a link here -- makes the forum a lot easier to read.
              As you might suspect, the crash is happening in the find/change module. I see that you are not fully patched to CS3 version 5.0.4, though, so that would be the first thing to do, and make sure you empty the recovery folder (if ID crashes on launch), or that you immediately export any recovered file to .inx and then open that and save as .indd with a new name. (see Remove minor corruption by exporting)
              • 4. Re: InDesign CS3 crashes on certain commands
                gawool Level 1
                Thanks again. Upgraded. Still crashing on find and change. Also crashes when creating a pdf from a new file but doesn't crash when creating a pdf from an existing file.
                • 5. Re: InDesign CS3 crashes on certain commands
                  Trash the prefs yet again, empty the recovery folder, and try again.
                  Is the find/change crash restricted to one file, old files, all files, new files? How about the PDF export -- all new files, even a simple one-pager with a single text block?
                  • 6. Re: InDesign CS3 crashes on certain commands
                    gawool Level 1
                    Still doing it. find/change crashes on all files. Now crashing when trying to type in a new file, can type on old files. Pdf export crashes only on new files.
                    • 7. Re: InDesign CS3 crashes on certain commands
                      Sounds like things are getting worse, not better, and that there is something seriously wrong someplace.
                      Does it work in a new user account?
