7 Replies Latest reply on Nov 26, 2013 6:55 PM by Digital Fuel Web
    How do I change a case status?
    chlauin
      When I look at my cases in CRM, all of them have a "new" status. How do I change the status to "closed" or something equivalent?
        • 1. Re: How do I change a case status?
          thetrickster888 Level 4
          Once you are looking at a case in your BC Admin area there should be an edit button in blue on the bottom left of the screen-- edit the case and change the status to closed.
          • 2. Re: How do I change a case status?
            Sidney Mitchell Adobe Employee
            Within the individual case details you'll need to select the edit option and select the update status.  CRM -> Cases -> select the case and click "edit"
            There's no bulk status feature however.
            Kind regards,
            -Sidney
            • 3. Re: How do I change a case status?
              DandyDahlia Level 1
              Hi Sidney,
              Is a bulk status feature being worked on?
              If not, is there any way to assign a case to always closed (ie never let the system save it as opened).
              E.g when consumers sign up on our website a case is made but we don't need to call them to follow up so we'd like it just appear closed.
              And when a retailer joins our wholesale login a case is made and we need to call them to follow up so we need their case to appear open / new.
              As I'm sure you can appreciate going in and manually changing every single status is slow, tedius and painful!.
              Thank you.
              • 4. Re: How do I change a case status?
                I don't think there's a way to setup auto-closing of cases or a timed
                closing of cases after "x" amount of time.  Cases will be "new" until you
                close them.  Manually.
                My recommendation is to review the Customer Service Ticketing feature in
                BC. If you have a BC plan with CRM I think you probably can use Customer
                Service Ticketing.
                The idea is this-- your client sets up an email address that is solely
                dedicated to receiving BC support inquiries.  I use a Google Apps email
                address for most of my clients that's dedicated-- usually it's "support@"
                or "help@".
                You setup CST in BC and use this email address for the ticket agent
                address.  Once you've setup a CST it will appear as a "workflow" which you
                can now use in your forms/processes.
                You'll be able to setup certain BC admin users as customer service reps and
                distribute new cases randomly or by least load over those BC admin users.
                Once a case is made and the CST workflow launched against it, there are
                some hyperlinks in the notification email sent to CST agents assigned to
                the case that will let them close, open, etc. the case.  It's much easier
                than going into the CRM, finding a customer, finding their case, editing
                the case, setting it as closed and saving the case.
                Instead, you just refer back to your email from the CST, click the "Close"
                link and the case gets closed.  Also, you can reply directly by email
                without having to login to the CRM and the conversation is recorded against
                the case.
                The downside is that all the customer service agents being dealt cases MUST
                be BC admin users and I'm not sure how many users your client wants to pay
                for.  But it's a lot easier to keep on top of cases when you can click a
                link in an email when you are actively working on the case via email.
                Here's some more information about the CST feature on BC:
                http://kb.worldsecuresystems.com/kb/customer-service-ticketing.html
                Keep in mind it's technically "beta" but I haven't seen any bugs in a few
                years on my end.
                • 5. Re: How do I change a case status?
                  DandyDahlia Level 1
                  Thanks thetrickster888.
                  Ok that's one option but it's just so messy (it's so manual meaning room for error). I'd just hoped after all this time BC might have a simpler more automated system!
                  • 6. Re: How do I change a case status?
                    Not at the moment as BC is currently working on migrating to Amazon.
                    - http://www.businesscatalyst.com/bc-blog
                    Kind regards,
                    -Sidney
                    • 7. Re: How do I change a case status?
                      Digital Fuel Web Level 2
                      This would be a very helpful addition to cases.
                      I have a customer that uses the BC CRM extensively and this would speed things up for them alot.
                      Cheers Daniel
