4 Replies Latest reply: Jun 7, 2013 5:28 AM by joe bloe premiere RSS
    Unable to export audio when source is 44100 Hz
    Howard Hoffman Community Member
      CS6 lastest on Windows
      I just got a problem with audio.  Video clips are from AVCHD camcorder and has audio with 48000 Hz sampling rate
      I added a track for some background music, which is 44100 Hz 16-bit WAV.
      Now Export will stuck.  As soon as I remove the music track, it will work again.  Then I removed all other audio track except the music track.  It will stuck.
      Is there a problem if source audio does not match sequence sampling rate?  If so, what can I do to work around this problem?
