5 Replies Latest reply on Aug 22, 2013 2:08 PM by pgaraway@adobe.com
    Wavy vertical lines distort top and bottom when I use Scale to frame size in CS6
    nikiv1984
      For a few days now, while I import HD footage into SD comp and use Scale to frame size now I have these wavy vertical lines at the bottom and top (instead of black ones). I have this problem when footage is paused, when I play it it is ok, and also the problem appears when I export footage. I have to manually scale down my footage to something like 62% and then it is just the way it should be.
      See the image below (LEFT - when I playback my clip, RIGHT - when it is paused)
