8 Replies Latest reply on Jun 9, 2013 3:28 PM by pixxxel schubser
    Dimension Illustrator CS6
    jay fresno Level 2
      Does anyone know of a script that will automatically put dimensions on rectangular shapes in Illustrator CS6?
        • 1. Re: Dimension Illustrator CS6
          vinoth_mannu Level 1
          #target illustrator
          var docRef = app.activeDocument;
          with (docRef) {
               $.writeln(geometricBounds);
               $.writeln(visibleBounds);
          This might be useful.
          • 2. Re: Dimension Illustrator CS6
            StanStill
            I am by no means a programmer/scriptor, but I just recently found and tinkered with a script to do pretty much that.
            This one puts the dimensions in a specified location on the artboard, rounded to hundredths of an inch. It's probably riddled with all kinds of artifacts from the script that it was adapted from which don't do anything, but it works, which is good enough for me. I use it for putting measurements of printing plate files, but it's pretty well commented so you can find the things you need to change.
            Stan's Dimension Script
            #target illustrator
            var myDocument = app.activeDocument;
            var selectedObject = myDocument.selection;
            var activeLayer = app.activeDocument.activeLayer;
            var layerName = activeLayer.name;
            activeLayer.name = "plate";
            // Get position of selection bounds
            var myBounds = selectedObject[0].geometricBounds;
            // Set up X and Y co-ordinates
            var x1 = myBounds[0];
            var x2 = myBounds[2];
            var y1 = myBounds[1];
            var y2 = myBounds[3];
            // Set up data for the Dimensions
            var ptWidth = myBounds[2] - myBounds[0];
            var ptHeight = myBounds[1] - myBounds[3];
            var tmpWidth = (ptWidth / 72);
            var tmpHeight = (ptHeight / 72);
            var finalWidth = tmpWidth.toFixed(2);
            var finalHeight = tmpHeight.toFixed(2);
            //Find Centre of Object
            var xCentre = x1 + (ptWidth / 2);
            var yCentre = y1 - (ptHeight / 2);
            // Find text swatch position
            var origSwatches = myDocument.swatches;
            var swatchesLength = origSwatches.length;
            for (i=0;i<swatchesLength;i++) {
                      if (origSwatches[i].name == "text" || origSwatches[i].name == "text") {
                                var textSwatch = origSwatches[i];
            // Check if text swatch is defined
            if (textSwatch == undefined) {
                      alert("Please create a text swatch");
            else {
                      makeDimensions();
                      releaseLayer();
            function makeDimensions() {
            // Lock the active layer to prevent colour change
            activeLayer.locked = true;
            // Create Dimensions Layer
            //Now moved to separate function
            /*var mLayer = myDocument.layers.add();
            //mLayer.name = "Dimensions";*/
            mLayerCreate();
            // Set Document colors to text
            myDocument.defaultFillColor = textSwatch.color;
            myDocument.defaultStrokeColor = textSwatch.color;
            // Create groups for dimensions
            var yMeasure = mLayer.groupItems.add();
            yMeasure.name = "Height";
            var xMeasure = mLayer.groupItems.add();
            xMeasure.name = "Width";
            // Create Text for X Measurement
            var xText = xMeasure.textFrames.add();
            xText.contents = finalWidth + " in";
            xText.top = 132;
            xText.left = 260;
            xText.paragraphs[0].paragraphAttributes.justification = Justification.CENTER;
            for (i=0;i<xText.textRange.characters.length;i++) {
                      xText.characters[i].characterAttributes.fillColor = textSwatch.color;
            // Create Text for Y Measurement
            var yText = yMeasure.textFrames.add();
            yText.contents = finalHeight + " in";
            yText.top = 132;
            yText.left = 165;
            yText.paragraphs[0].paragraphAttributes.justification = Justification.CENTER;
            for (i=0;i<yText.textRange.characters.length;i++) {
                      yText.characters[i].characterAttributes.fillColor = textSwatch.color;
            function mLayerCreate() {
                      var mLayerNotExists = true;
            try {
                app.activeDocument.layers.getByName("Dimensions").remove();
            } catch (e) {};
            // Check if Dimensions layer exists
            for(i = 0; i < activeDocument.layers.length; i++){
                      if(activeDocument.layers[i].name == "Dimensions"){
                                mLayer = activeDocument.activeLayer = activeDocument.layers[i]; // not using var to declare makes it global
                                mLayerNotExists = false;
            if(mLayerNotExists){
            mLayer = myDocument.layers.add();// not using var to declare makes it global
            function releaseLayer(){
                      for(i = 0; i < activeDocument.layers.length; i++) {
                                if(activeDocument.layers[i].name == "plate") {
                                          activeDocument.layers[i].name = layerName;
                                          activeDocument.layers[i].locked = false;
            • 3. Re: Dimension Illustrator CS6
              jay fresno Level 2
              I couldn't get either the vinosh or stanstill scripts to work. Guess I don't understand how to use them.
              • 4. Re: Dimension Illustrator CS6
                Larry G. Schneider Adobe Community Professional & MVP
                For the first, it will write the dimensions (to 10 decimal points) in the JavaScript Console window accessed from the Window menu in the ESTK. For the second, copy/paste into a new window in the ESTK and save it. Make sure you have made a swatch called text in the Swatch panel of your file and have an item selected. Then run the script. This is what happens
                • 5. Re: Dimension Illustrator CS6
                  pixxxel schubser MVP & Adobe Community Professional
                  @StanStill,
                  you can start your script in many places accelerate and optimize.
                  for example change this:
                            yText.textRange.characterAttributes.fillColor = textSwatch.color;
                  to:
                  yText.textRange.paragraphAttributes.justification = Justification.CENTER;
                  also you can this:
                  else {
                            makeDimensions();
                            releaseLayer();
                  change to:
                  try {
                      var swatchName = "text";
                      var textSwatch = myDocument.swatches.getByName (swatchName);
                      makeDimensions();
                      releaseLayer();
                  catch (myError) {
                      // better as an alert: you can define your text swatch here
                  There is still much more to optimize. Good luck
                  • 6. Re: Dimension Illustrator CS6
                    StanStill Level 1
                    Jay, I have my artboard set up kind of screwy, and by the time I figured out how to change the origin point of the artboard, I had already been using the script for a while and have decided to just leave it like it is. It is probably putting the dimensions way off the artboard for you, so zoom out and see if you find it. Also, the rectangle has to be selected when you run the script.
                    Under // Create text for X Measurement (and Y Measurement) there are top and left values that situate the width and height on the artboard. If you play with those, you should be able to move where the numbers appear.
                    But first, are you saving the files as .jsx files?
                    • 7. Re: Dimension Illustrator CS6
                      StanStill Level 1
                      Wow... that looks so much simpler than the way it was! Thanks.
                      • 8. Re: Dimension Illustrator CS6
                        My pleasure.
                        You are on the right way. But there is still much to be done.
