3 Replies Latest reply on Nov 3, 2017 9:58 PM by christinem78287574
    The license key is damaged
    camelias086d Level 1
      Hi, one of my French customer is getting this error message:
      'The license key is damaged' (la cle de license est endommagee).
      Any suggestions any one?
      Much appreciated
        • 1. Re: The license key is damaged
          sjpt Level 4
          Is this
          1. on running ADE?
          2. on trying to open a .acsm file?
          3. on trying to read a .epub or .pdf file?
          One thing that can help is to reset the authorization of ADE.
          When it gets it confused, it seems to throw out fairly random error messages.
          1. ctrl-shift-D to remove any old (possibly corrupt) authorization. (cmd-shift-D on Mac)
          2. restart ADE
          3. try again to authorize with the correct AdobeID.
          4. then try again to read the book.
          I think this is pretty unlikely to help if it is just one book giving problems.
          Probably best to try to get a new version of the file giving problems in that case.
          • 2. Re: The license key is damaged
            Hi there,
            Thank you very much for your suggestion. The customer is a bit 'narrow' and doesn't give me the information I'm asking for. It happens a lot with doctors...they want everything to work straight away and they are very impatient.
            But I will advice this and see if it works.
            Again, thank you!
            • 3. Re: The license key is damaged
              christinem78287574
              thank you
              it worked
