5 Replies Latest reply on Oct 13, 2007 8:05 AM by FlashLobo
    Trouble with variable scope or reference (AS2)
      Hello !
      The simple code below maps onRelease functions to 8 buttons.
      The goal is to load the corresponding image into a single central imagePanel whenever a button is clicked.
      There are 8 instances of the same MC on the scene (named g0 to g7), each containing a button (btnShow)
      The "downloadImage()" function loads the image when triggered by the onRelease event.
      The path to each image file is taken from the _global.paintings Array (url property).
      The problem:
      It looks like that, during the assignment, a link is made to the "reference" of the 'i' variable, instead of its VALUE.
      So, at run time, 'i' equals 8 (value at the end of the loop) for EVERY downloadImage function, instead of the incremented value ( 0 to 7)...
      Thus resulting on every button loading the same image, instead of the corresponding image (taken from the url property in _global.paintings[0] to [7])
      Well, not easy to explain properly, I hope you'll understand what I mean...
      Thanks a lot for your help, I'm pretty lost here !
