5 Replies Latest reply on Jun 9, 2013 4:51 PM by alfonsodev
    Iterate over all document layers applescript
    alfonsodev
      Hi,I have experience as programmer but not in applescript or photoshop scritpting,
      Basically I want to apply some actions to layers, but only to those layers that are named ending in '-changeMe' e.g ( 'Layer 1-changeMe', 'Background-changeMe')
      I'm trying to convert the pseudocode below to applescript
      foreach layer in CurrentDocument.layers
         if layer.name contains '-changeMe'
             do something
         end if
      end foreach
      In the pseudocode above I'm inveting the notation, but I hoppe you get the idea.
      it's posible?
      Thanks!
        • 1. Re: Iterate over all document layers applescript
          c.pfaffenbichler Level 9
          Would you be willing to use JavaScript instead?
          I think at least one of the regulars in this Forum is AppleScript savvy, but most people seem to avoid it for Photoshop Scripting purposes.
          • 2. Re: Iterate over all document layers applescript
            alfonsodev Level 1
            Yes, I love javascript, but I'm wondering if it's posible to launch javascript  actions from actionscript.  Because I want to have some actions integrated at the OS level, to have the posibility for example to right click on a folder or file and launch the script from there, passing the folder path or file as an argument.
            Not sure if I can call javascript from applescript.
            Apart of that I'm intresting to see javascript solutions to the same problem, I may still change my mind while practicing.
            • 3. Re: Iterate over all document layers applescript
              Muppet Mark Level 5
              Yes you can call any JavaScript syntax including Action Manager syntax from AppleScript… You pass the command a string or file to the JS and it also takes arguments…
              • 4. Re: Iterate over all document layers applescript
                pixxxel schubser MVP & Adobe Community Professional
                I can't help you with AppleScript.
                But this JavaScript works.
                // FindStringInLayersName.jsx
                // http://forums.adobe.com/thread/1227665?tstart=0
                // find layers which have "-changeMe" in the name
                var theLayers = app.activeDocument.layers;
                var LayersName, result;
                var searchString = /[-]changeMe/;
                for (i=0; i<theLayers.length; i++) {
                    LayersName = theLayers[i].name;
                    result = LayersName.search(searchString);
                    if (result != -1) {
                        alert("Found in layer: "+LayersName);
                        // or do something else
                Perhaps someone else can translate this.
                Good luck
                • 5. Re: Iterate over all document layers applescript
                  alfonsodev Level 1
                  Thanks guys for the help, I finally manage to mix applescript and javascript, simply awesome.
                  --target Photoshop CS6
                  tell application "Adobe Photoshop CS6"
                  do javascript "
                      if (result != -1) {
                          alert('Found in layer: '+LayersName);
                  end tell
