3 Replies Latest reply on Jun 7, 2013 7:40 AM by kglad
    How to change the transparency of a grid square using attachMovie
    Pippa01
      I've used a couple of 'for' loops to create a grid of squares using attachMovie. I want to be able to roll over one of those squares and only have that square decrease in transparency by 50%. What's happening instead, is that if I rollover any of the squares, only the alpha of the bottom right square is affected.
      Below is the code (I did try to insert it as an image, but I wasn't able to).
      onEnterFrame = function() {
      //set up grid for solid array
      SPACING = 1;
      COLS2 = 6; // number of columns in grid
      ROWS2 = 6; // number of rows in grid
      LEFTMARGIN2 = 100;
      TOPMARGIN2 = 100;
      DEPTH = 500; // starting point for depth
      for (m=1; m<=ROWS2; m++) {        //open 1
      for (n=1; n<=COLS2; n++) {        //open 2
      current2 = attachMovie("squareTest_mc", "squareTest_mc"+m+"_"+n, DEPTH++);
      current2._x = LEFTMARGIN2 + ((m-1) * (SPACING + current2._width));
      current2._y = TOPMARGIN2 + ((n-1) * (SPACING + current2._height));
      current2.onRollOver = function() {
                 current2._alpha=50;
      I'm using Mac OS 10.6, CS3
      I'd really appreciate some help.
      Many thanks,
      Philippa
        • 1. Re: How to change the transparency of a grid square using attachMovie
          1.  that should not be in an onEnterFrame loop.
          2. use:
          SPACING = 1;
          LEFTMARGIN2 = 100;
          TOPMARGIN2 = 100;
                     this._alpha=50;
          current2.onRollOut = function() {
                     this._alpha=100;
          • 2. Re: How to change the transparency of a grid square using attachMovie
            Pippa01 Level 1
            Thank you. That was extremely helpful and a very fast response.
