2 Replies Latest reply on Jun 8, 2013 3:06 PM by teeronline
    Drop Down Menu manipulation problem
    teeronline Level 1
      Hi, I have a dropdown Menu code for AS2 as the follow, this code is applied to a buttonOne on stage, and the buttonOne's next frame is the menu content.** No stop(); at any frame in the button movie.
      onClipEvent(enterFrame){        // if the mouse IS over the menu ...
          if (this.hitTest(_root._xmouse, _root._ymouse, true)) {     // if the menu is NOT fully open
              if (this._currentframe<this._totalframes) {
                  nextFrame();        // go to the next frame of the menu opening sequence
          } else {            // if the mouse is NOT over the menu
              if (this._currentframe>1) {               // if the menu is NOT fully closed
                  prevFrame();               // play the previous frame of the menu opening sequence
      ***on the next frame, I have  a buttonUp and a movie text1, buttonUp has code as the follow:
      on(rollOver) {
          onEnterFrame = function (){
          text1._y -=4;}    // so text1 would move up when pressed.
      on(rollOut) {
          delete this.onEnterFrame;
      ****NOW****, what I need is to make buttonOne work as a Press button instead of Rollover button, and when pressed, next frame will remain on stage even when mouse move away ( I will apply a close window button later on).
      My problem right now is, I can change the first part of the code to :
           gotoAndStop(2);  //or something like that
      while put stop();  on both frames in the movie, but then by doing this would remove the funtionality on
          text1._y -=4;}
      so text1 don't move at all if there is a stop(); applied to that current frame. I tried a few methods but none work, tried to search the web but all the tutorials I found are all Rollover type drop down menu.
