23 Replies Latest reply on Jun 30, 2013 12:16 PM by redbourn
    please comment on this laptop
    redbourn Level 1
      http://www.laptopmag.com/review/laptops/lenovo-ideapad-y580.aspx
      Please comment on the pluses and minuses of the above laptop for use with CS5 or CS6
      Am thinking of buying it to use when travelling.
      Michael
        • 1. Re: please comment on this laptop
          Harm Millaard Level 7
          Areas for improvement:
          1. Faster CPU, like the i7-37xx or i7-38xx
          2. Increase memory to 16 GB
          3. Remove the 5400 RPM disk altogether and replace it with a Samsung 840 Pro 256 GB SSD and add 1 or 2 7200 RPM HDD's internally.
          4. Make sure it has an eSATA and/or an USB3 connection.
          • 2. Re: please comment on this laptop
            redbourn Level 1
            Thanks very much.
            Better to know before I order it.
            Anything better in same price range?
            I have a very hi-spec pc but want the laptop for doing on the run (not from jail ;-) kind of things.
            Won't be heavy duty kind of work.
            Michael
            • 3. Re: please comment on this laptop
              Biggles Lamb Level 3
              I have an Asus N56 running Windows 8, it has a quad core i7 3630QM 2.4GHz CPU with 8Gb RAM and a 2Tb hard drive partitioned into two.  Graphics are nVidia 650 with full 1920x1080 native resolution
              It now has m/soft Office plus Edius and CS5.5 Production Premium installed on it and it runs all programmes just fine.
              No it does not have a 7200rpm drive as standard but it does have 4 USB3 ports, HDMI output and I know that on the Asus forums guys have swapped over the optical drive for a second hard drive.
              But, it works, it is far better made than Lenovo, the sound quality is also great (it has its own plug in subwoofer).
              In the UK this cost me £830 three months ago.
              Just to re-iterate, it works for editing straight out of the box, yes for very complex edits it may struggle but for day to day straightforward tasks it works just fine.
              After Effects does not seem to struggle with what I have been doing with it so far.
              The laptop spec that Harm has given you is very good, but in a laptop you do get what you pay for.
              If you have a look at Asus G75 gaming laptops you will find a spec more like Harm has described, the downside, in the UK that these are about £1500
              Good luck and please let us know how you get on.
              • 5. Re: please comment on this laptop
                Jeff Bellune Level 6
                [moved to hardware forum]
                • 6. Re: please comment on this laptop
                  Bill Gehrke Most Valuable Participant
                  Michael,  unless you are in a hurry there will soon be the next generation laptops with the i7-47xx CPU's.  If you do a little searching for the Asus G750 series as an example.  Performance difference will be a small increment better but for instance:
                  1. With the new Intel series 8 chipsets all SATA ports are SATA III.
                  2. The nVidia card in the units are the newer GTX 7xx series.
                  3. Memory is expandable  to 32 GB.
                  4. This new CPU/chipset is supposed to be more power efficient = more battery time.
                  5. Of course this might make the current Lenovo's or Asus G75's available at bargain prices when the new one's appear.  I am sure Lenovo will also have this new next generation processor/chipset across the laptop lineup very soon
                  • 7. Re: please comment on this laptop
                    RopeChoker Level 1
                    Should I decide not to build my own desktop, I checked out one of these next-genearation laptops as a possbility. However, to configure it right, things sure got expensive in a hurry.
                    The one I was looking at:
                    Built on the Clevo P170SM chassis
                    17.3" Full HD Glossy 90% Gamut Screen
                    Intel Core I7-4800MQ 2.7 Ghz
                    32GB 1600 RAM
                    Nvidia 780M 4GB
                    6x BD-R / 6X BD-ROM / 8X DVD-RW Combo Drive
                    1 x Samsung 840 Pro 256GB SSD
                    2 x Seagate Momentus 750GB 7200 RPM HDD
                    Win 7 Pro 64bit
                    After the 3% cash discount, plus shipping, it's right at US$3k -- ouch!
                    • 8. Re: please comment on this laptop
                      JFPhoton Level 3
                      ....soon other vendors will offer similar for cheaper.....like Asus,MSI,etc. Although, that rig will smoke EXCEPT for the slow speed of the XT HDD,compared to a Marvell controlled SSD....
                      • 9. Re: please comment on this laptop
                        RopeChoker Level 1
                        Those SSDs can really increase the cost, though. I guess you could leave the two 750GB/7200 Sata2 HDDs out (save $266), then buy a couple of 1TB/7200 Sata3 HDDs and put them in yourself. That would actually be cheaper by $56, assuming you went with Hitachi HDDs, although I'm not sure about Hitachi's drive quality.
                        • 10. Re: please comment on this laptop
                          JFPhoton Level 3
                          .....Iread your post wrong......if the two hdds can be raided together as raid 0,  it would be very fast......for a laptop. However, for the same money,you could build a much faster desktop system using the 3930k CPU with many PCI ,gen.3 lanes available and beefier components
                          • 11. Re: please comment on this laptop
                            RopeChoker Level 1
                            Yes, building a desktop is an alternative which I am considering, but I move around a lot and would really like to avoid hauling a mid-or-full tower and big display panel around with me if I can avoid it.
                            • 12. Re: please comment on this laptop
                              JFPhoton Level 3
                              ...be advised any beefy laptop will weigh 8-9lbs. and will require a constant 120v connection......as the battery wont last long editing ....and the CPU may throttle back on battery power with the new Haswell,( not sure if you would have control). In addition.....even a 17.3 in screen is really small and taxing on the eyes.....I am ALWAYS hooked to an external monitor with my laptop, and even use hotel HDTVs as an external monitor with my HDMI cable if editing on road. Sometimes I will make the big TV the GUI display and use the laptopscreen as the monitor ....this allows plenty of space to see all the timeline and audio waveforms,etc.
                                  Definetly, desktop will give you more for the money....esp. if editing difficult codecs natively like DSLR footage.....using multiple tracks and effects.   However, I would love to see how that Clevo would perform on the PPBM test. If the 2 Momentus drives are in RAID 0 as the " project drive"....that laptop may shatter the current best laptop performance!
                              • 13. Re: please comment on this laptop
                                RopeChoker Level 1
                                I didn't mean to suggest I travel a lot and need to sling a laptop over my shoulder at regular intervals. I do volunteer work and a lot of hiking and I tend to move every year or so and need to travel as light as possible -- my CR-V will only hold so much! So, for the most part, it would remain stationary and always powered by AC. And good point about the screen size and the need for an external display.
                                If I do go with this laptop, I will probably leave the two Sata2 HDDs out and buy two Sata3 HDDs, but figured I'd use one for source files and one for target files. The only real criticism I have read about is inconsistent fan speeds... and fan noise: overall 36 dB... under load 46 dB... stress test 55 dB. Apparently, that's pretty loud.
                                • 15. Re: please comment on this laptop
                                  JFPhoton Level 3
                                  ...if you can wait.....Asus has done a great job in their gaming laptops to control cooling AND they have improved the vent filter system, so the fans dont get clogged and become noisy then burn out....there are serious copper air ducts that cool the CPU and GPU.....maintaining LOW temperatures under HEAVY load.
                                     I am sure they will have a comparable model to that Clevo soon......I believe the Momentus XT 750 GB HDDs ARE SATA III.......these are relatively new drives, with better performance than the older 500GB model, that I also own. I am using a cheaper Crucial M4 SSD as my large project drive....512GB for ~ $390........it has the NECESSARY Marvell controller that handles incompressible data well when writing. The best SSDs for this are Samsung and Plextor PRO models, ( NO Sandforce controlled SSDs!)
                                  • 16. Re: please comment on this laptop
                                    RopeChoker Level 1
                                    Well, looks like those noise levels aren't as bad as it sounded in the review. Thanks, Harm.
                                    And I'm not up against the clock with this purchase by any means, so I can wait. Heck, it took me six months to finally pull the trigger on my Canon 60D!
                                    I did check out the ASUS G75VW-DH72 laptop, but it couldn't handle three internal drives. Plus, I've read so many bad comments about how Asus quality control has tanked, including an older thread on this board, it kind of scared me off ASUS.
                                    Also, you are correct about the Seagate HDD being Sata3. I totally missed the "XT" when I was looking at the Clevo specs. But the reviews I've read on Seagate make me cautious about their drives.
                                    Okay, don't want to take up any more of your time or overstay my welcome. I do want to say "thanks" for all your help and advice. I'll give it another month or so and see what ASUS offers.
                                    Again, I thank you for your time.
                                    George
                                    • 17. Re: please comment on this laptop
                                      If you have some patience, you could wait for the Dell Alienware 18".
                                      It comes (optionally) with a Haswell i7-4930MX overclocked to 4.3 GHz, memory up to 32 GB, a GTX 780M video card, even in SLI configuration, 18" full HD PLS screen and up to 4 storage drives. Prices are not yet announced.
                                      New Dell Alienware laptops, but only in Dutch.
                                      • 18. Re: please comment on this laptop
                                        RopeChoker Level 1
                                        Sounds interesting... and expensive. I'll see what becomes available over the next few weeks and will check the Alienware when it becomes available here in the US. Thanks for the heads-up Harm.
                                        • 19. Re: please comment on this laptop
                                          redbourn Level 1
                                          I got busy for a few days as I'm preparing to move to Portugal.
                                          Thanks for all the replies! I didn't expect so many!
                                          Going to start working my way through them and checking out some specs.
                                          I have a a fabulous desktop but I doubt I will ever buy another one.
                                          There are so many great laptops in the pipeline.
                                          Packing and shipping my desktop took some planning but I did find this great packaging.
                                          https://www.youtube.com/watch?feature=player_embedded&v=5mIGpKRNMc4
                                          Thanks again,
                                          Michael
                                          • 20. Re: please comment on this laptop
                                            redbourn Level 1
                                            How about this?
                                            I'm not talking about heavy duting editing with CS5 or CS6 but only video clips and similar.
                                            I did the heavy duty stuff for over 30 years!
                                            http://www.notebookcheck.net/Dell-Inspiron-17R-SE-7720.76609.0.html
                                            Well I crossed this one off of the list because several people said that the motherboard failed and there were several comments such as "Very good if you get lucky".
                                            • 21. Re: please comment on this laptop
                                              redbourn Level 1
                                              They are already on sale in Israel but cost about 4-6 times what I want to spend. But thanks for the tip.
                                              The i7-2960XM = $7,600
                                              • 22. Re: please comment on this laptop
                                                redbourn Level 1
                                                I know that laptops can't yet compete with desktops, but check out why MS introduced Windows 8 and why Windows  8.1 will soon replace it for free!
                                                http://pcinfo.us/#pc-crash
                                                • 23. Re: please comment on this laptop
                                                  redbourn Level 1
                                                  Just to let you know I bought the Lenovo IdeaPad Y580 a week ago and am pleased with it.
                                                  I've only done fairly simple editing on it up until now but it performed well.
                                                  It's not going to be like my desktop but will hopefully take up the slack when I'm travelling.
                                                  Thanks for all the feedback!  :-)
