2 Replies Latest reply on Jun 9, 2013 7:55 PM by teeronline
    movie inside of a loaded external movie
    teeronline Level 1
      how to control a mc inside a loaded external movie?
      so I have a main.swf, loaded a ex.swf into it by using loadMovie, and inside ex.swf there is a mc called 'mc'
      how do I control 'mc' from main.swf? I tried something like newLoader.mc._x +=1;  ( newLoader is ex.swf), it doesn't work?
      Thanks for reply.
        • 1. Re: movie inside of a loaded external movie
          Show the code you use for loading ex.swf and explain how it acquires the identity of newLoader.
          If I create an empty movieclip in the main file and assign it an instance name of "newLoader"... if I load ex.swf into that empty movieclip I am able to target it by that instance name and move the mc within it.
          • 2. Re: movie inside of a loaded external movie
            teeronline Level 1
            Hi Ned
            after I read your reply, i went on make a new sample file just to try it out, and it work, then I went back to my file and found out on these code
            var currentObject = new Object;
            currentObject = newLoader.newLoader2.newLoader3;
            var currentObjectColor = new Object;
            currentObjectColor = currentObject;
            and then I have
            var my_color:Color = new Color(currentObjectColor.mc);
                trace (allowColor);
            for some reason, after I replace currentObjectColor to just currentObject, it work just fine, I don't know if the problem is from putting one object equal another one, but as far as I need this would work for me.
            thanks a lot.
