4 Replies Latest reply on Jun 11, 2013 11:03 PM by @SumitSinghal
    Simple scheduler not working
    @SumitSinghal Level 1
      I have created the bundle and compiled the bundle but i am not able to see the logs in the log file
      Example
      import org.slf4j.Logger;
      import org.slf4j.LoggerFactory;
      * @scr.component
      * @scr.service interface="java.lang.Runnable"
      * @scr.property name="scheduler.expression" value="0/5 * * * * ?"
      public class ScheduledCronJob implements Runnable {
           /** Default log. */
         protected final Logger log = LoggerFactory.getLogger(ScheduledCronJob.class);
           public void run() {
           log.info("Executing a cron job (job#1) through the whiteboard pattern");
      Sumit
        • 1. Re: Simple scheduler not working
          rush_pawan Level 4
          Hi Sumit,
          I hope your bundle is deployed successfully and active. Can you try to set immediate property as true so that this component will immediatly availble as soon as it deployed.
          @scr.component immediate="true" enabled="true"
          Pawan
          • 2. Re: Simple scheduler not working
            Thanks Pawan for the reply
            Bundle is deployed successfully and active .
            I tried with
            @scr.component immediate="true" enabled="true" but still its not working.Logs are not created.
            Sumit
            • 3. Re: Simple scheduler not working
              rush_pawan Level 4
              Hi Sumit,
              I tried this and its perfactly works in my local. can you use below and try
              import org.apache.felix.scr.annotations.Component;
              import org.apache.felix.scr.annotations.Properties;
              import org.apache.felix.scr.annotations.Property;
              import org.apache.felix.scr.annotations.Service;
              @Component
              @Service(value = Runnable.class)
              @Properties({
              @Property(name="scheduler.expression", value="0/5 * * * * ?")})
              public class SchedulerTest implements Runnable {
                   /** Default log. */
                 protected final Logger log = LoggerFactory.getLogger(SchedulerTest.class);
                 @Override
                 public void run() {
              Also watch the log for deployment status of bundle and activation.
              Pawan
              • 4. Re: Simple scheduler not working
                thanks pawan now its working
