1 Reply Latest reply on Jun 10, 2013 11:07 AM by Lucia Lao
    Formscentral pasting
    Chess1980
      I am right clicking on the section i want copied and click Copy from drop down menu.  I then select the section i want my 'copied' section to be in front of and right click and select paste.  But nothing happens.  can youhelp?
        • 1. Re: Formscentral pasting
          Lucia Lao Employee Moderator
          It sounds like you like to copy the selected section at the beginning of the form, is that right?
          When you do a paste, it will paste below the selected field (Before pasting you need to select a field and then right click to see the context menu) and in front of the next field.
          So, if you want to paste in front of a field, then you will need to select the field above this field and do the paste, this will make it in front of the field.
          Hope this helps,
          Lucia
