1 Reply Latest reply on Oct 15, 2007 7:00 AM by WolliWorld
    Help with syntax for looping and dynamic variables
    WolliWorld
      I'm trying out the new cfimage tag and I'm trying to loop through a query to resize images to create thumbnails. I don't even know how many different combinations I've tried. If you were trying to resize just one image, the first set of lines of code is how you would do it. The second set is what I've ended up trying to do. What I don't understand is why the first image seems to work, but the second one throws an error? I know there's probably a better way of doing this other than using evaluate too. I've added a debugging output just above the image in the first column to make sure there wasn't an error in the variable I was trying to use. This is the page if you want to see it in action: http://67.199.23.10/adopt/dogs.cfm. I really appreciate any help, because I've tried all I know to try at this point. Thanks!!!
