4 Replies Latest reply on Oct 12, 2007 9:38 PM by cf_dev2
    Q of Q question
    Level 7
      I have a function that joins 7 csv files via cfhttp. I want to be able to
      use that master query and search against it.
      In another function I attempted to set the value of a variable to the result
      of that fuction and then use QofQ to refine it but I am getting this error:
      Message Complex object types cannot be converted to simple values.
      Detail The expression has requested a variable or an intermediate expression
      result as a simple value, however, the result cannot be converted to a
      simple value. Simple values are strings, numbers, boolean values, and
      date/time values. Queries, arrays, and COM objects are examples of complex
      values.
      The most likely cause of the error is that you are trying to use a complex
      value as a simple one. For example, you might be trying to use a query
      variable in a cfif tag.
      I know the JoinRes works but don't know how to set it to a variable to use
      again elsewhere in the web site.
      Here are my functions:
      <cffunction name="JoinedRes" access="public" returntype="query"
      output="false" hint="I join all the Residentials">
      <cfset files = getFileNames('ResFiles')>
      <cfset i = 1>
      <cfloop query="files">
      <cfoutput>
      <cfhttp
      url=" http://www.bpoprosonline.com/assets/property/residential/#files.FileName#"
      method="GET" name="Res#i#"
      delimiter="|" textqualifier="" firstrowasheaders="yes" />
      </cfoutput>
      <cfset i = i + 1>
      </cfloop>
      <cfquery name="JoinedRes" dbtype="query">
      SELECT * From Res1
      <cfif isDefined('Res2')>
      UNION
      Select * From Res2
      </cfif>
      <cfif isDefined('Res3')>
      UNION
      Select * From Res3
      </cfif>
      <cfif isDefined('Res4')>
      UNION
      Select * From Res4
      </cfif>
      <cfif isDefined('Res5')>
      UNION
      Select * From Res5
      </cfif>
      <cfif isDefined('Res6')>
      UNION
      Select * From Res6
      </cfif>
      <cfif isDefined('Res7')>
      UNION
      Select * From Res7
      </cfif>
      ORDER BY City ASC
      </cfquery>
      <cfreturn JoinedRes>
      </cffunction>
      <cffunction name="ourListedProps" access="public" returntype="query"
      output="false" hint="I return all BPO Pros Property from MLS">
      <cfset residential = JoinedRes()>
      <cfquery name="ourListedProps" dbtype="query">
      Select DISTINCT(MLSNumber),PhotoURL,ListPrice,City,ListOfficeId FROM
      #residential# WHERE ListOfficeId = 340169
      </cfquery>
      <cfreturn ourListedProps>
      </cffunction>
      Wally Kolcz
      MyNextPet.org
      Founder / Developer
      586.871.4126
