2 Replies Latest reply on Jun 14, 2013 9:58 AM by ghenry20
    Clearing NaN error from form fields.
    ghenry20
      Hey all,
      Working with this script I have and I thought my condition should clear the NaN erro but it does not.  Does anyone have a clear for the NaN error that might work better.  Basicully,  all the script does is the person using it puts military time into 2 different areas.  One "On" and one "Off".  The NaN error stays in the field until they person using the form puts in the 2 times.
      (function () {
          // Get the field values, as numbers
          var v1 = getField("HoursOFF1").value;
          var v2 = getField("HoursON1").value;
          var v3 = getField("HoursDif1").value;
                var time1 = v1.split(":");
                var time2 = v2.split(":");
                var min1 = time1[0]*60 + time1[1]*1 //
                var min2 = time2[0]*60 + time2[1]*1 ;
          if (v3 !== 0) {
             event.value = ((min1 - min2) / 60);
          } else {
              event.value = "";
      If anyone can spot my error it would be much appreciated.  Thanks in advance!
        • 1. Re: Clearing NaN error from form fields.
          The split command returns strings, which you're then trying to use in a
          mathematical calculation, hence the NaN (Not a Number) errors.
          You need to explicitly convert those strings to numbers, like so:
          Number(time1[0])
          • 2. Re: Clearing NaN error from form fields.
            ghenry20 Level 1
            Thanks for the help!  I still had to twik it just a little bit more.  Final code follows:
            (function () {
                      var min1 = Number(time1[0])*60 + Number(time1[1])*1 //
                      var min2 = Number(time2[0])*60 + Number(time1[1])*1 ;
                if (v1 != 0) {
                } else {
                    event.value = "";
