0 Replies Latest reply on Jun 10, 2013 2:58 PM by Balance
    Parsing links
    Balance Level 1
      I have a utility that lets users store custom fields (first name, favorite color, address, URL, etc).
      One of those fields is used to store the contact's work/personal URL.
      In addition, users can send their contacts an email including these fields. So an email might say: "Dear *fname*, Your *URL* is pretty cool!"
      Now my client wants to re-write the URL so they can track it using Google Analytics, and that's where I'm stuck.
      Basically, I'm struggling with how to re-write the URLs since there can be other fields for one contact that may need to be re-written.
      In other words, I need to check every field to see if there's an href, and if there is, replace it with another href, for *every contact*.
      The code below re-writes the URL only for one field and for one contact, but not if there's more than one field with an href and/or more than one contact being returned.
      Here is the code I'm using:
      <!---get user defined field info--->
      <cfquery name="getUDFields" datasource="#attributes.dsn#">
      SELECT field_id, field_name, column_name
      FROM contacts_fields
      ORDER BY field_order
      </cfquery>
      <!--- grab the user-defined fields --->
      <cfloop query="getUDFields">
                <cfscript>
                          tmpHTMLcontent = attributes.content;
                          tmpHTMLcontent = ReplaceNoCase(tmpHTMLcontent,"*"&getUDFields.column_name&"*", "##getRecpsGroupHTML['"&getUDFields.column_name&"'][currentRow]##","ALL");
                </cfscript>
      <cfoutput query="getRecpsGroupHTML"> <!--- query object returning contacts that will receive the email --->
                <cfset arrHTMLcontentLinks = getLinks(evaluate(de(tmpHTMLcontent)))><!--- returns an associative array with hrefs stripped out --->
                          <cfloop from="1" to="#arrayLen(arrHTMLcontentLinks)#" index="i">
                                    <cfloop collection="#arrHTMLcontentLinks[i]#" item="j">
                                              <cfif j is "href">
                                                        <cfset URLtoInsert = arrHTMLcontentLinks[i][j]>
                                                        <cfquery name="insertlinks" datasource="#attributes.dsn#">
        INSERT INTO links (url, email_id)
        VALUES ('#trim(urltoinsert)#', #last_email_ID#)
                                                        </cfquery>
                                                        <cfquery name="getMax" datasource="#attributes.dsn#">
        SELECT IDENT_CURRENT('links') AS MaxID
                                                        </cfquery>
                                                        <cfset last_link_ID = getMax.MaxID>
                                                        <cfset newlink = "http://"&clientDomain&"/test.cfm?"&last_link_ID>
                                                        <cfset HTMLcontent = ReplaceNoCase(evaluate(de(tmpHTMLcontent)),URLtoInsert,newlink)>
                                                        <cfscript>
        //added so the de() doesn't choke in cfmail
        variables.HTMLcontent = replace(variables.HTMLcontent,"##","####","ALL");
                                                        </cfscript>
                                                        <!--- replace user-defined fields in the HTML with their literal values --->
                                                        <cfscript>
        variables.HTMLcontent = ReplaceNoCase(variables.HTMLcontent,"*"&getUDFields.column_name&"*", "##getRecpsGroupHTML['"&getUDFields.column_name&"'][currentRow]##","ALL");
                                                        </cfscript>
                                                        </cfloop>
                               <!--- CFMAIL CODE WOULD GO HERE, ONCE THE DATA IS PARSED PROPERLY --->
                                              </cfif>
                                    </cfif>
                          </cfloop>
                </cfloop>
                </cfoutput>
      </cfloop>
