4 Replies Latest reply on Jun 29, 2013 4:17 AM by VDOSurfer
    need square video 960x960 px
    ulrich1000
      Hello,
      I need a Video 960x960 px.
      How to set up the project?
        • 1. Re: need square video 960x960 px
          A.T. Romano Level 7
          ulrich1000
          What version of Premiere Elements are you using and on what computer operating system is it running (including 32 or 64 bit system)?
          And, to what format do you intend to export in?
          ATR
          • 2. Re: need square video 960x960 px
            ulrich1000 Level 1
            Adobe Premiere Elements 10.0
            20110902.MO
            11.B123.280463
            Windows 7 Professional 64
            System
            Gesamter Systemspeicher16,0 GB RAM
            Systemtyp64 Bit-Betriebssystem
            Anzahl der Prozessorkerne6
            Grafik
            GrafikkartentypATI FirePro V7800 (FireGL)
            Insgesamt verfügbarer Grafikspeicher9981 MB
            Dedizierter Grafikspeicher2048 MB
            Dedizierter Systemarbeitsspeicher0 MB
            Gemeinsam genutzter Systemspeicher7933 MB
            Grafikkarten-Treiberversion8.982.8.3000
            Auflösung des primären Monitors2560x1440
            Auflösung des sekundären Monitors1920x1200
            DirectX-VersionDirectX 10
            • 3. Re: need square video 960x960 px
              A.T. Romano Level 7
              ulrich1000
              You set your Premiere Elements 10 project preset to match the properties of your source media. So, what are the properties of your source media?
              That project preset will direct the program to establish the correct space in the Monitor from which you edit your import.
              When you decide on your Share/Computer/ export, you can change the settings under the Advanced Button/Video Tab. of the preset selected. In the Export Settings dialog, the essentials would be:
              Frame Width = 960 pixels
              Pixel Aspect Ratio = Square Pixels (1.0)
              I am not giving you a guarantee that the above will work for your specific exporting and player needs. But is something for you to rule in or out.
              ATR
              • 4. Re: need square video 960x960 px
                VDOSurfer Level 3
                As ATR suggests, you can go to the Advanced tab and change it to the required resolution, but the output will not really be a good one in terms of quality, there will be pillar boxing and/or letter boxing. I say this because Adobe clarified that the project preset should match the export preset for a good quality output. If your only concern is the resolution, then the suggestion will work straightaway.
                http://forums.adobe.com/thread/1100554?start=40&tstart=0 has details on the issues and the correct method to be used for selecting the project and the output from a given source file.
